Thanks Alex, Tom and Vinny, this gives us what we need to move forward. We'll share what we learn once a first unit is flying.
jake_eizy
Design review for a 4.5 kg VOXL 2 quad with M0138 on 12-inch props -
Design review for a 4.5 kg VOXL 2 quad with M0138 on 12-inch propsVinny and Tom, thank you so much!! Final Follow up questions below and I should be good
Can a userspace service drive GPIO_46 as a plain output while the kernel SPI driver holds it as CS1 for /dev/spidev14.1, or do we need to remove that chip select from the device tree?
What state are GPIO_46 and the level shifter in from power-on until the SPI driver loads?
On the ESC cables:
Does MCBL-00015-2 replace the kit's UART cable? It's listed as straight-through 1:1, but the M0138 data sheet says to leave J1 pin 1 (3.3 V reference out) unconnected, and our notes show VOXL 2 J18 pin 1 also carries 3.3 V. Is the 1:1 cable fine on the M0138, or should pin 1 be left open?
Can the 150 mm -2 version be ordered for a production build?
Is there a 150 mm version of the kit's VOXL 2 power cable?
- Is a stable SDK planned that includes voxl-px4 1.18.0-1.0.12 or newer?
Design review for a 4.5 kg VOXL 2 quad with M0138 on 12-inch propsThanks @alex-kushleyev , this is very helpful. One correction on my side: the 19 A and 37 A I quoted are per-motor phase currents from our motor model, not battery current. Our modeled battery current is about 38 A at hover (771 W at 20.4 V), about 35 A in survey flight, and about 95 A at the 9,100 rpm cap (about 107 A near 18 V), which we only expect in brief maneuvers. So the sustained load is about half of your 80 to 85 A flight test.
With those numbers:
Do you still see this as risky, and would you still fit heat spreaders on both sides? The ESC sits on the top plate near the center of the airframe, outside the prop wash.
What phase current per motor did your 80 to 85 A flight run at, so we can compare ESC heating?
Would you add external capacitance at this load, and what value would you start with?
Is there a starting value for max_rpm_delta you'd suggest for a 12-inch prop?
Design review for a 4.5 kg VOXL 2 quad with M0138 on 12-inch propsHi ModalAI team,
Hardware: Pre-build design review, so no serial numbers yet. Planned stack:
- VOXL 2 (MDK-M0154-1-00)
- VOXL 4-in-1 ESC (MDK-M0138-11-01, 5.1 V kit with VOXL 2 cables)
- M0130-3 LTE and USB hub add-on on J5
- M0048-2 Microhard USB carrier with pMDDL2450, on an M0130 USB port with its own 5 V supply
- M0226 front end with two M0166 AR0144 tracking cameras (front and down)
- M0184 ELRS receiver and M0224 GNSS on J19
- 4x Unusual Machines UM3115 900 kV motors, APC 12x6E props, 6S Li-ion pack
- About 4.5 kg take-off weight
Software version: Not built yet. We plan to start on SDK 1.8.
Configuration / services: Not built yet. Planned: voxl-px4 with the M0138 in closed-loop RPM mode capped at 9,100 rpm, VIO on the two tracking cameras, Microhard for C2, and a small service that drives J10 GPIO_46 as a 3.3 V camera trigger.
What I am trying to do: Confirm the ESC, power and I/O choices before we build the first airframe. A motor model gives about 19 A per motor at hover (about 6,350 rpm) and about 37 A at the 9,100 rpm cap. Could you help with these?
M0138:
- Is the 40 A rating phase current or bus current?
- What airflow does the 40 A continuous rating assume?
- The board senses total current only. How should each channel be protected at an rpm cap?
- You describe it for 5 to 10 inch airframes. Is a 12-inch prop acceptable, and what ESC tuning does it need?
VOXL 2 and accessories:
5. Is the M0224 supported as the PX4 navigation receiver on SDK 1.8?
6. On J10: what is the drive strength of GPIO_46 for a 3-way star at 3.3 V, which J10 mode does a shipped M0154 boot in, and what state are GPIO_46 and the J10 level shifter in from power-on until our trigger service takes the pin?
7. How much current may the M0130's J5 3.3 V pin supply? We need up to about 0.16 A.
8. Is about 3.3 A steady through VOXL 2 J4's single 5 V Mini-SPOX contact acceptable?
9. How long are the M0138 kit's VOXL 2 power and UART cables? Our runs are about 150 mm.
10. Is a STEP file available for the M0226?Handset:
11. What does the Zorro Blue (MRC-Z0001-1) cost on its own, and is it sold separately?
12. What are the form factor and price of the M0193 transmitter, and does it fit a standard controller module bay?What actually happens: Nothing yet. This is a design review before build.
Steps to reproduce: N/A
Logs / pictures: None yet. Happy to share a block diagram if useful.
