Gyeongmin KimG
Gyeongmin Kim
@Gyeongmin Kim
  • ToF v2 ground level error
    Gyeongmin KimG Gyeongmin Kim
    Any update?
    Hello there!
    I've been trying to change the depth sensor from ToF v1 to v2 because it is't supported anymore. And I've connected ToF v2 on voxl2 successfully.
    But I have been encountering the critical error about the ground level.
    The left red line is showing the pointcloud from the ground. As you can see, the level of ground is higher than the bottom of wall. I think it should be connected with the bottom of wall.
    I've tried the same experience with ToF v1 at the same place and time. It's showing the same ground level as I expected.
    May I have any comment about it? Thank you!
  • Question for GPU Usage
    Thank you Alex!
    According to your reply, Should I use the gpu for large tasks such as Neural Network or large image instead of the task that need to process each frames?
    FAQs
    Thank you for reply Chad!
    I already can run the example without docker.
    My question is why GPU is slower than CPU in the result of image.
    I am using opencv-opencl for my application. But I also got the result that GPU takes much time than CPU
    FAQs
    Hello, I am trying to use the GPU(Adreno 650) in VOXL2.
    In the voxl-docker-opencv-opencl gitlab, It says this is the expected ouput.
    root@0a4f66eee0a6:/opt/workspace/examples/fast_corners# ./fast-corners
    FAST ( 300 x  168), keypoints: 557, time:0.487192 cpu
    [ WARN:0] Using world accessible cache directory. This may be not secure: /var/tmp/
    FAST ( 300 x  168), keypoints: 557, time:6.319238 gpu
    And it says GPU is too much slower than CPU. And I also got slower result compare to CPU.
    Is it expected output? And What kinds of situations GPU is faster than CPU?
    Thank you for your any advices!
    FAQs
  • VOXL2 Opencv with Opencl
    The result of hellocl : OpenCL error: clGetDeviceIDs(-1)
    The result of fast_corners : Enable OpenCL failed!
    I built the opencv again with this file. I could install it but still same error. Is it caused by diff of GPU model?(Adreno 530 vs Adreno 650)
    Hello, Team
    I'd like to run voxl-docker-opencv-opencl example with VOXL2 and no docker.
    I tried to build voxl-opencv with opencl flag and followed docker file.
    But I always got Enable OpenCL failed! from the c++ source.
    I want to use VOXL2 Adreno 650 GPU as needed.
    Please give me some advice?
    Thanks.
  • voxl-docker-opencv-opencl with VOXL2
    Hello.
    I'm trying to use GPU in VOXL platform through opencl. So I followed voxl-docker-opencv-opencl README.
    I am able to use opencl lib with VOXL1. But It didn't work on VOXL2 like below.
    Any advice for this?
    Thanks~
  • VOXL1 PX4 connection issue
    +) I think the flight core doesn't work anymore. There isn't any action when I connect this with QGC, MP with USB. And the part of flight core in the voxl1 is too high to touch it. Is it HW issue??
    Today, I wasn't able to connect VOXL1 & QGC. First screenshot is from VOXL1:voxl-vision-px4. But I think It should shows like second screenshot. How can I connect my VOXL1 with the QGC again?
    Thanks
