Evan DE
Evan D
@Evan D
  • Maximum Connections to Wi-Fi?
    Evan DE Evan D
    Re: Data Collection from Ground Sensors
    I plan on using the setup where the drone is an access point and the ground sensors (Raspberry Pis) connect to it automatically. However, I've been having issues when multiple sensors are in range of the drone, and so they all try to connect. My question is how many devices can connect to the m500's network at once?
  • Controller not recognized in QGC
    Evan DE Evan D
    @Eric-Katzfey Reinstalling px4 solved my problem, thanks for your help!
    Development Drones m500
    Evan DE Evan D
    @Eric-Katzfey
    RC_INPUT_PROTO is set to -1, and RC_PORT_CONFIG is set to 0, so i'm not sure why the rc driver isn't connecting to the receiver.
    Would it be worthwhile to try to reinstall px4?
    Thanks so much for your help.
    Evan DE Evan D
    @Eric-Katzfey Yes, I'm connected to QGC and I can see the camera feed and other data. The spektrum bind command works, so the receiver lights up with a solid led when I turn on the transmitter, but for some reason the data from the receiver isn't making it to QGC. Here's the output to those commands after I have connected the rc transmitter:
    nsh> listener input_rc
    never published
    nsh> dmesg
    HW arch: MODALAI_FC_V1
    HW type: V1001000
    HW version: 0x001
    HW revision: 0x000
    PX4 git-hash: b02a6b4ae93d12fa399673bf442c45087cee0759
    PX4 version: 1.14.0 0 (17694720)
    Vendor version: 2.0.63 0 (33570560)
    OS: NuttX
    OS version: Release 11.0.0 (184549631)
    OS git-hash: 3f77354c0dc88793a47ff3b57595195ab45f7ba9
    Build datetime: Dec 11 2023 20:04:02
    Build uri: localhost
    Build variant: default
    Toolchain: GNU GCC, 9.3.1 20200408 (release)
    PX4GUID: 000200000000203334354d3350140031002c
    MCU: STM32F76xxx, rev. Z
    INFO  [param] selected parameter default file /fs/mtd_params
    INFO  [param] importing from '/fs/mtd_params'
    INFO  [parameters] BSON document size 2043 bytes, decoded 2043 bytes (INT32:23, FLOAT:68)
    INFO  [param] selected parameter backup file /fs/microsd/parameters_backup.bson
    Board architecture defaults: /etc/init.d/rc.board_arch_defaults
    Board defaults: /etc/init.d/rc.board_defaults
    Loading airframe: /etc/init.d/airframes/4001_quad_x
    INFO  [dataman] data manager file '/fs/microsd/dataman' size is 62560 bytes
    Board sensors: /etc/init.d/rc.board_sensors
    ERROR [voxl_esc] Invalid parameter VOXL_ESC_FUNCX.  Only supports motors 1-4.  Please verify parameters.
    ERROR [voxl_esc] Invalid parameter VOXL_ESC_MOTORX.  Please verify parameters.
    ERROR [voxl_esc] Task start failed (-1)
    voxlpm #0 on I2C bus 3 (external) address 0x44
    WARN  [SPI_I2C] Already running on bus 3
    WARN  [SPI_I2C] voxlpm: no instance started (no device on bus?)
    icm20602 #0 on SPI bus 1 rotation 12
    icm42688p #0 on SPI bus 2 rotation 12
    ERROR [SPI_I2C] bmi088: no instance started (no device on bus?)
    bmp388 #0 on I2C bus 4 (external) address 0x76
    qmc5883l #0 on I2C bus 1 (external) address 0xD
    ekf2 [812:237]
    Starting Main GPS on /dev/ttyS0
    Starting MAVLink on /dev/ttyS6
    INFO  [mavlink] mode: Normal, data rate: 1200 B/s on /dev/ttyS6 @ 57600B
    Starting MAVLink on /dev/ttyS4
    INFO  [mavlink] mode: Onboard, data rate: 46080 B/s on /dev/ttyS4 @ 921600B
    INFO  [logger] logger started (mode=all)
    INFO  [uavcan] Node ID 1, bitrate 1000000
    NuttShell (NSH) NuttX-11.0.0
    nsh> INFO  [gps] baudrate set to 9600
    INFO  [gps] Sending initial CFG_VALSET. Attempt: 1
    INFO  [gps] Got ack to initial CFG_VALSET!
    INFO  [gps] u-blox firmware version: SPG 5.10
    INFO  [gps] u-blox protocol version: 34.10
    INFO  [gps] u-blox module: MAX-M10S
    WARN  [health_and_arming_checks] Preflight Fail: Yaw estimate error
    WARN  [health_and_arming_checks] Preflight Fail: Strong magnetic interference
    INFO  [mavlink] Starting mavlink shell
    Evan DE Evan D
    @Eric-Katzfey Thanks for your reply.
    That command returns -- No entries --, i think because I'm on a VOXL flight (m500) so there isn't a voxl-px4 service. Is there a way to view the px4 startup log on voxl?
    Also, I ran voxl-configure-mpa to reset the services, but the status log for voxl-mavlink-server shows that the mavlink buffer is full, as shown below. I don't understand why this would be happening when all the services should be in the default state, but maybe this is causing my problem of QGroundControl not recognizing the controller?
    7eb60947-e822-4aed-950b-a0f811b1f1de-image.png jou
    Output of journalctl -b -u voxl-vision-hub :
    -- Logs begin at Thu 1970-01-01 00:00:04 UTC, end at Thu 2024-03-21 14:17:14 UTC. --
    Jan 01 00:00:08 apq8096 systemd[1]: Started voxl-vision-hub.
    Jan 01 00:00:08 apq8096 voxl-vision-hub[2366]: WARNING: voxl-mavlink-server does not appear to be running
    Jan 01 00:00:08 apq8096 voxl-vision-hub[2366]: make sure it is enabled: systemctl enable voxl-mavlink-server
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: loading our own config file
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: =================================================================
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Parameters as loaded from config file:
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: config_file_version:        1
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: MAVROS / MAVSDK
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_localhost_mavlink_udp    0
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: localhost_udp_port_number:  14551
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: VIO
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_vio:                     1
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: vio_pipe:                   qvio
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: secondary_vio_pipe:         ov
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_reset_vio_if_initialized_inverted: 1
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: vio_warmup_s:               3.000000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: send_odom_while_failed:     1
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: APQ8096-ONLY FEATURES
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_set_clock_from_gps:      1
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_force_onboard_mav1_mode: 1
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_reset_px4_on_error:      1
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: MISC FEATURES
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: horizon_cal_tolerance:      0.500000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: OFFBOARD MODE
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: offboard_mode:              figure_eight
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: follow_tag_id:              0
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: figure_eight_move_home:     1
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: robot_radius:               0.300000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: collision_sampling_dt:      0.100000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: max_lookahead_distance:     1.000000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: FIXED FRAME RELOCALIZATION
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_tag_fixed_frame:         0
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: fixed_frame_filter_len:     5
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_transform_mavlink_pos_setpoints_from_fixed_frame:0
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: COLLISION PREVENTION (VOA)
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: en_voa:                     1
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_upper_bound_m:          -0.150000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_lower_bound_m:          0.150000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_memory_s:               1.000000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_max_pc_per_fusion:      100
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_min_dist_m:         0.250000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_max_dist_m:         20.000000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_under_trim_m:       1.000000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_threshold:          3
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_slices:             36
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_pie_bin_depth_m:        0.150000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_send_rate_hz:           20.000000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_input #0
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: enabled:            1
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: type:               point_cloud
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: input_pipe:         dfs_point_cloud
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: frame:              stereo_l
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: max_depth:          8.000000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: min_depth:          0.300000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: cell_size:          0.080000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: threshold:          4
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: x_fov_deg:          68.000000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: y_fov_deg:          56.000000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: conf_cutoff:        0
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_input #1
    Jan 01 00:00:07 apq8096 systemd[1]: Starting voxl-mavlink-server...
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: conf_cutoff:        125
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: voa_input #4
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: type:               rangefinder
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: input_pipe:         rangefinders
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: frame:              body
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: loading extrinsics config file
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: loading horizon cal file
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting geometry module
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting autopilot monitor
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting mavlink IO
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Waiting to connect to voxl-mavlink-server
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting fixed pose input
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting vio manager
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting tag manager
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting voa manager
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting horizon cal module
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: starting offboard figure eight
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Init complete
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Connected to VIO pipe: qvio
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Geometry module updating to use imu: imu0 for VIO
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: new T imu wrt body:
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: 0.0200   0.0140  -0.0080
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: new R imu to body:
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: 1.0000  -0.0000   0.0000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: 0.0000   1.0000  -0.0000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: 0.0000   0.0000   1.0000
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: done updating transforms to use imu: imu0
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Connected to voxl-mavlink-server
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Detected Autopilot Mavlink SYSID 1
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: requesting autopilot_version
    Jan 01 00:00:11 apq8096 voxl-vision-hub[2366]: Detected autopilot version: 1.14.0
    Mar 21 14:18:09 apq8096 voxl-vision-hub[2366]: WARNING: Autopilot Mavlink Disconnected
    Mar 21 14:18:11 apq8096 voxl-vision-hub[2366]: WARNING: Autopilot Mavlink Disconnected
    Mar 21 14:19:08 apq8096 voxl-vision-hub[2366]: WARNING: Autopilot Mavlink Disconnected
    Thanks so much for any help.
    Evan DE Evan D
    @Moderator Thanks for your reply. I'm very new to this so I appreciate your patience.
    The log file just shows that no RC messages are getting through, even though I have binded the transmitter to the receiver and am moving the joysticks. But I haven't calibrated the controller so this may be expected.
    Here's the log file from simply turning on the drone and controller and moving the joysticks: https://logs.px4.io/plot_app?log=8cc328d8-5b81-426e-b04c-72698a4ed8f4
    What else can I try to troubleshoot? Is there anything in the log files that stands out?
    Evan DE Evan D
    Just wanted to follow up because I still cannot get the controller to work.
    In QGroundControl I selected "Reset all to firmwares defaults", uploaded the M500_FCV1.params, and re-calibrated the sensors. Should the drone be ready to fly at this point or do I need to upload some of the helper parameters?
    Evan DE Evan D
    I'm having trouble getting my Spektrum DX6e controller connected to QGroundControl. I have connected it and calibrated it before, but now when I try to do this i get the message "Radio Not Ready Please turn on the transmitter." The Spektrum Bind button works and the radio is on and connected when I get this message. I have made sure to reboot the drone after binding the controller.
    Not sure if this is the problem, but I was messing around with the px4 parameters and ended up resetting them, then uploading them from here: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/tree/master/params/v1.14/platforms
    I tried to use both the M500_FCV1.params and the M500_FCV2.params, but neither of these fixed my controller problem. Which of these is correct?
    I'm working with a brand new M500, so everything should be up to date.
    Thanks in advance for your help!
  • Data Collection from Ground Sensors
    Evan DE Evan D
    Apologies if this is a trivial question, but I'm doing a research project that requires a testbed for a drone to visit a series of ground sensors, wirelessly collect and store their data, and return to the base station for this data to be offloaded. The ground sensors will use either Wi-Fi or Bluetooth to transmit their data to the drone. Is implementing this on the VOXL m500 possible?
