    1. Home
    2. enrico.bandera 0
    E
    • Profile
    • Following 0
    • Followers 0
    • Topics 4
    • Posts 15
    • Best 0
    • Controversial 0
    • Groups 0
    Posts made by enrico.bandera 0
    • Split code to run on both application processor and Hexagon DSP
      according to this page:
      https://docs.modalai.com/voxl-px4-system-architecture/
      is possible to develope code that runs on both ARM application processor and Hexagon DSP
      How to do that? Where is possible to find Doc and SDK that allow similar architecture support.
      We would like to port/adapt an existing code that runs on an Arduino Nano board to a SMARC RB5 board, in order to control external hardware through its GPIOs and other pins.
      Hope you can share this information
      Thanks in advance
      posted in Software Development
      E
      enrico.bandera 0
    • RE: VOXL2 kernel rebuild: GPIO sysfs does not work
      @modaltb
      no, it behaves the same and returns the identical error message on dmesg.
      E
      enrico.bandera 0
      @modaltb ok, thanks, actually building in perf mode solved the gpio issue.
      We need to detect usb HUB TI TUSB8041.
      This is enabled by GPIO131, and now the kernel enumerates it
      Bus 002 Device 002: ID 0451:8140 Texas Instruments, Inc.
      But no devices were linked to it.
      dmesg output reported following messages:
      [   28.656134] usb 1-1: new low-speed USB device number 2 using xhci-hcd
      [   28.776276] usb 1-1: device descriptor read/64, error -71
      [   29.000256] usb 1-1: device descriptor read/64, error -71
      [   29.224480] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
      [   29.241526] usb 2-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 2.00
      [   29.241541] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [   29.360270] usb 1-1: new low-speed USB device number 3 using xhci-hcd
      [   29.450776] hub 2-1:1.0: USB hub found
      [   29.451044] hub 2-1:1.0: 4 ports detected
      [   29.480718] usb 1-1: device descriptor read/64, error -71
      [   29.704270] usb 1-1: device descriptor read/64, error -71
      [   29.808495] usb usb1-port1: attempt power cycle
      [   30.440376] usb 1-1: new low-speed USB device number 4 using xhci-hcd
      [   30.440852] usb 1-1: Device not responding to setup address.
      [   30.644893] usb 1-1: Device not responding to setup address.
      [   30.848259] usb 1-1: device not accepting address 4, error -71
      [   30.968127] usb 1-1: new low-speed USB device number 5 using xhci-hcd
      [   30.968591] usb 1-1: Device not responding to setup address.
      [   31.172610] usb 1-1: Device not responding to setup address.
      [   31.376137] usb 1-1: device not accepting address 5, error -71
      [   31.376368] usb usb1-port1: unable to enumerate USB device
      [   33.761006] vdd_tof: disabling
      [   33.761012] vdd_hap_boost: disabling
      How can we correctly detect?
      Thanks for your help.
      Enrico
      E
      enrico.bandera 0
      Hi @modaltb ,
      thank for your reply.
      I have installed the latest SDK, 1.1.3 same you mentioned.
      Then rebuild the kernel and flashed.
      The output of dmesg |grep voxl is following:
      [   24.177791] voxl_fsync_mod: disagrees about version of symbol module_layout
      [   24.185953] voxl_gpio_mod: disagrees about version of symbol module_layout
      [   24.194024] voxl_platform_mod: disagrees about version of symbol module_layout
      [   32.003105] voxl_gpio_mod: disagrees about version of symbol module_layout
      [   32.004019] voxl_fsync_mod: disagrees about version of symbol module_layout
      [   32.016895] voxl_platform_mod: disagrees about version of symbol module_layout
      Original kernel replies with following output:
      [    2.383515] voxl_fsync_mod_init
      [    2.383703] voxl_fsync_probe
      [    2.383801] voxl_fsync_probe : OK
      [    2.384617] voxl-gpio init
      [    2.385049] voxl_gpio_probe
      [    2.385143] voxl-gpio: gpio0 - output, high
      [    2.385163] voxl-gpio: gpio1 - output, high
      [    2.385187] voxl-gpio: gpio53 - output, high
      [    2.385209] voxl-gpio: gpio56 - output, high
      [    2.385231] voxl-gpio: gpio57 - output, high
      [    2.385251] voxl-gpio: gpio85 - output, high
      [    2.385269] voxl-gpio: gpio86 - output, high
      [    2.385291] voxl-gpio: gpio87 - output, high
      [    2.385309] voxl-gpio: gpio88 - output, high
      [    2.385327] voxl-gpio: gpio89 - output, high
      [    2.385345] voxl-gpio: gpio124 - output, high
      [    2.385364] voxl-gpio: gpio152 - output, high
      [    2.385382] voxl-gpio: gpio157 - output, high
      [    2.385403] voxl-gpio: gpio159 - output, high
      [    2.385423] voxl-gpio: gpio36 - output, low
      [    2.385442] voxl-gpio: gpio37 - output, low
      [    2.385463] voxl-gpio: gpio46 - output, low
      [    2.385483] voxl-gpio: gpio54 - output, low
      [    2.385503] voxl-gpio: gpio55 - output, low
      [    2.385522] voxl-gpio: gpio67 - output, low
      [    2.385549] voxl-gpio: gpio82 - output, low
      [    2.385564] voxl-gpio: gpio83 - output, low
      [    2.385581] voxl-gpio: gpio84 - output, low
      [    2.385603] voxl-gpio: gpio131 - output, low
      [    2.385623] voxl-gpio: gpio153 - output, low
      [    2.385643] voxl-gpio: gpio154 - output, low
      [    2.385663] voxl-gpio: gpio155 - output, low
      [    2.385686] voxl-gpio: gpio48 - input
      [    2.385705] voxl-gpio: gpio49 - input
      [    2.385728] voxl-gpio: gpio50 - input
      [    2.385744] voxl-gpio: gpio51 - input
      [    2.385763] voxl-gpio: gpio52 - input
      [    2.385765] voxl-gpio probe complete
      [    2.386275] voxl-platform init
      [    2.386369] voxl_platform_probe
      [    2.386416] voxl-platform: Machine: - ID - 1
      [    2.386418] voxl-platform: Variant: - ID - 0
      [    2.386419] voxl-platform probe complete
      E
      enrico.bandera 0
    • VOXL2 kernel rebuild: GPIO sysfs does not work
      Hi, I need to add a new USB device to usb core driver: hub.c
      I can modify it and rebuild a new kernel successfully, but after flashing it I cannot use gpio sysfs anymore.
      The interface is present, but when attempting to write on /sys/class/gpio/export file it returns me with this error:
      voxl2:/$ echo 131 > /sys/class/gpio/export
      bash: echo: write error: Invalid argument
      Kernel version is:
      voxl2:/$ uname -a
      Linux m0054 4.19.125 #1 SMP PREEMPT Fri Apr 12 14:07:33 UTC 2024 aarch64 aarch64 aarch64 GNU/Linux
      I am building from kernel GIT repo on branch qrb5165-ubun1.0-14.1a
      Also command voxl-gpio read/write returns error
      voxl2:/$ voxl-gpio read 131
      ERROR:   Invalid GPIO direction for pin 131: got 0
      ERROR:   Failed to open path /sys/class/gpio/gpio1231/value
      ERROR reading from pin number : 131 (got -1, expected 0 or 1
      According to documentation it should work
      https://docs.modalai.com/voxl-gpio-io/#manipulating-gpio-using-linux-commands
      Thanks in advance
      Enrico
      E
      enrico.bandera 0
    • RE: Failure on build customized px4 firmware repo
      @Alex-Kushleyev I could fix it!
      The problem was in the git submodule configuration: the px4-autopilot repo, was not correctly configured and command git submodule update --init --recursive was incomplete.
      Now I can correctly build our px4-autopilot inside docker container. And deploy to target, install and run it!
      Kind Regards
      posted in PX4 Autonomy Developer Kit
      E
      enrico.bandera 0
      @Alex-Kushleyev yes, I did it exactly how described in https://gitlab.com/voxl-public/voxl-sdk/services/voxl-px4
      The problem occurs when I try to replace the submodule px4-firmware with another (in this case it is named px4-autopilot) using git submodule add <path_to_repo>
      Then I modified the build.sh clean.sh and make-package.sh in order to use the new repo/submodule instead the original one.
      All this is done inside the rb5-flight-px4-build-docker.
      The error is:
      /usr/local/workspace/px4-autopilot/boards/modalai/voxl2-slpi/src/drivers/dsp_hitl/dsp_hitl.cpp:49:10: fatal error: 'mavlink.h' file not found
      #include <mavlink.h>
      1 error generated.
      ninja: build stopped: subcommand failed.
      make: *** [Makefile:232: modalai_voxl2-slpi] Error 1
      cat: build/modalai_voxl2-slpi_default/src/lib/version/build_git_version.h: No such file or directory
      *** End of qurt slpi build ***
      User ID is 1000
      Group ID is 1000
      *** End of build ***
      E
      enrico.bandera 0
    • Failure on build customized px4 firmware repo
      Hi I am trying to build a customized px4 for voxl2
      So I added our repo as submodule but the build fails with following error message:
      I have previously succesfully built with native px4-firmware repo, and also deployed on target.
      I did not overwrite original px4-firmware, but I added a new px4-autopilot folder that has the same structure, hence I expect it build in same way.
      Obviously I modified the existing scripts to use px4-autopilot folder instead of px4-firmware
      May be this is not sufficient?
      Thanks in Advance
      Enrico
      E
      enrico.bandera 0
    • RE: HexagonSDK4.1.0.4 installation fails due to erro on license verification
      @Eric-Katzfey thanks, I completed all steps successfully and also built the px4 image for voxl2
      Thanks a lot for your help
      Enrico
      E
      enrico.bandera 0
      @Eric-Katzfey the directory is shown in the shell prompt: it is /local/mnt/workspace/Qualcomm/Hexagon_SDK/4.1.0.4/
      I assume this is the default installation path for Hexagon_SDK v 4.1.0.4 sinc I have not customized the installation path.
      Kind Regards
      E
      enrico.bandera 0
      @Eric-Katzfey thanks for your help. Anyway I guess thet even the tar archive is already unpacked since I can see this folder content:
      But if I try to follow next steps:
      Download and load the base Docker image from ModalAI
      Use setup.sh to retrieve and load the base Docker image
      Build the Docker image
      Make sure the Hexagon SDK archive is in the project directory
      Run build.sh
      I obtain further errors since both setup.sh and build.sh are missing
      I've already done the steps in this link:
      But obviously the run_docker fails, since docker image above mentioned is missing.
      So I guess (and hope) just last fix is missing.
      Thanks in advance.
      E
      enrico.bandera 0
      @Eric-Katzfey I've opened a Case on Qualcom site. They answered it was a backend problem they also detected and fixed. So I've tried again and actually it activates a license. But now the installation breaks up after a while, reporting a post install error. See attached screenshot
      So I've tried launching installation with CLI tool. It produces the same error, but it addictionally ask me to install another component: Compute.Core.1.x
      Shoul I also install it? Which version (it offers me 12 diferent chiches), also the option to skip (as I did)
      Please let me know if this component is requested.
      Here screenshot of qpm-cli output:
      E
      enrico.bandera 0
      @Eric-Katzfey Yes, I've an active account and first of all the Qualcom Package Manager request to login with it. I did log in without any error (access was successful).
      Anyway it was not possible to obtain any license.
      E
      enrico.bandera 0
    • HexagonSDK4.1.0.4 installation fails due to erro on license verification
      Hi all,
      I am trying to install Qualcom HexagonSDK4.1.0.4 on a Linux system. I followed the instructions reported at following link:
      https://gitlab.com/voxl-public/rb5-flight/rb5-flight-px4-build-docker
      Unfortunately it failf with following error message, after I press the INSTALL button.
      "License verification failed for Hexagon SDK 4.x" (see attached screenshot)
      Any idea how to specify correct license?
      Thanks
      Enrico
      E
      enrico.bandera 0
