D
Djalma Ribeiro
@Djalma Ribeiro
  • How to install and configure OpenVPN?
    D Djalma Ribeiro
    I was able to configure the VPN using this video: https://www.youtube.com/watch?v=IsyNtovozVU
    How do I make the drone auto-initialize the vpn?
    D Djalma Ribeiro
    @tom how do i update openvpn in drone?
    D Djalma Ribeiro
    @tom wifi yes
    D Djalma Ribeiro
    @tom Is there an easier way to connect the QGC to the drone? Even if on each connection I need to manually inform the ips.
    I need to make the drone connect via LTE/5G urgently.
    D Djalma Ribeiro
    @tom
    Well, I managed to update, redid the settings and he is connected to the internet. But I still can't connect the QGC.
    I didn't understand one thing. Why the drone and the pc are online in the "Connectors" of "Networks" but both can't find each other by ping?
    You can only ping if one of them is a Host Connector and the other is a Networks Connector.
    I believe it is not Firewall because I have already disabled it.
    Any idea?
    D Djalma Ribeiro
    @tom you are the best! thanks
    D Djalma Ribeiro
    @tom 😢
    root@qrb5165-rb5:/home/rb5-flight-sdk-1.1.3# ./update-sdk.sh
    bash: ./update-sdk.sh: Permission denied
    D Djalma Ribeiro
    @tom I didn't find the file /etc/modalai/qgc-ip.cfg
    D Djalma Ribeiro
    @tom I managed to make the ping work by putting the drone in host and the pc in network.
    Do I have to use UDP or TCP to connect to the QGC?
    D Djalma Ribeiro
    Now I understand a little more! By the way, thank you very much for your help.
    I have both the pc and the drone online on OpenVPN:
    But neither can find the other by ping.
    Is there anything else I'm forgetting?
    D Djalma Ribeiro
    D Djalma Ribeiro
    D Djalma Ribeiro
    What else do I need to do to complete the OpenVPN setup? Do I need to send any certificate for the drone?
    I also couldn't find how to connect the QGC to the drone using VPN. How to find the address to use etc.
    D Djalma Ribeiro
    @tom
    tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1500
            inet 100.96.1.34  netmask 255.255.255.240  destination 100.96.1.34
            inet6 fd:0:0:8102::2  prefixlen 64  scopeid 0x0<global>
            inet6 fe80::da89:cbe9:b217:1ed7  prefixlen 64  scopeid 0x20<link>
            unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 100  (UNSPEC)
            RX packets 0  bytes 0 (0.0 B)
            TX packets 7  bytes 336 (336.0 B)
    But shouldn't I see the drone in the device list on the OpenVPN website?
    D Djalma Ribeiro
    @tom Hmm!!! Very well observed. I thought that was normal.
    I copied the files to the openvpn folder and ran the command. Result:
    /connector01_sao_paulo.ovpnpn# openvpn --script-security 2 --config /etc/openvpn/
    Wed May  4 19:14:41 2022 OpenVPN 2.4.6 [git:HEAD/b3a7f452206607fb] aarch64-unknown-linux-gnu [SSL (OpenSSL)] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May  3 2022
    Wed May  4 19:14:41 2022 library versions: OpenSSL 1.1.1  11 Sep 2018
    Wed May  4 19:14:41 2022 Outgoing Control Channel Authentication: Using 256 bit message hash 'SHA256' for HMAC authentication
    Wed May  4 19:14:41 2022 Incoming Control Channel Authentication: Using 256 bit message hash 'SHA256' for HMAC authentication
    Wed May  4 19:14:49 2022 TCP/UDP: Preserving recently used remote address: [AF_INET]209.14.3.200:1194
    Wed May  4 19:14:49 2022 Socket Buffers: R=[1048576->1048576] S=[1048576->1048576]
    Wed May  4 19:14:49 2022 NOTE: setsockopt TCP_NODELAY=1 failed
    Wed May  4 19:14:49 2022 UDP link local: (not bound)
    Wed May  4 19:14:49 2022 UDP link remote: [AF_INET]209.14.3.200:1194
    Wed May  4 19:14:49 2022 TLS: Initial packet from [AF_INET]209.14.3.200:1194, sid=02821386 53542aca
    Wed May  4 19:14:50 2022 VERIFY OK: depth=1, CN=CloudVPN Prod CA
    Wed May  4 19:14:50 2022 VERIFY KU OK
    Wed May  4 19:14:50 2022 Validating certificate extended key usage
    Wed May  4 19:14:50 2022 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
    Wed May  4 19:14:50 2022 VERIFY EKU OK
    Wed May  4 19:14:50 2022 VERIFY OK: depth=0, CN=br-gru-dc2-b1.cloud.openvpn.net
    Wed May  4 19:14:50 2022 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, 2048 bit RSA
    Wed May  4 19:14:50 2022 [br-gru-dc2-b1.cloud.openvpn.net] Peer Connection Initiated with [AF_INET]209.14.3.200:1194
    Wed May  4 19:14:51 2022 SENT CONTROL [br-gru-dc2-b1.cloud.openvpn.net]: 'PUSH_REQUEST' (status=1)
    Wed May  4 19:14:51 2022 PUSH: Received control message: 'PUSH_REPLY,route-gateway 100.96.1.33,ifconfig 100.96.1.34 255.255.255.240,ifconfig-ipv6 fd:0:0:8102::2/64 fd:0:0:8102::1,client-ip 200.173.248.124,ping 8,ping-restart 40,reneg-sec 3600,cipher AES-256-GCM,compress stub-v2,peer-id 71,topology subnet,explicit-exit-notify,remote-cache-lifetime 86400,block-outside-dns,route 100.96.0.0 255.224.0.0,route-ipv6 fd:0:0:8000::/49,route 100.80.0.0 255.240.0.0,route-ipv6 fd:0:0:4000::/50,dhcp-option DNS 100.96.1.33,auth-tokenSESS_ID,auth-token-user b25lc29sdmUvY29ubmVjdG9yL2I5YzdiMDVhLTY2ODUtNDNlMS05NTU5LTFkNTdhZWFjYzM4Nl9kY2M3ODY2Ny1hNDFkLTRiNWYtYWE1Ni02MGEwZjE3NzNiYjI='
    Wed May  4 19:14:51 2022 Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:4: client-ip (2.4.6)
    Wed May  4 19:14:51 2022 Options error: option 'reneg-sec' cannot be used in this context ([PUSH-OPTIONS])
    Wed May  4 19:14:51 2022 Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:13: remote-cache-lifetime (2.4.6)
    Wed May  4 19:14:51 2022 Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:14: block-outside-dns (2.4.6)
    Wed May  4 19:14:51 2022 Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:21: auth-token-user (2.4.6)
    Wed May  4 19:14:51 2022 OPTIONS IMPORT: timers and/or timeouts modified
    Wed May  4 19:14:51 2022 OPTIONS IMPORT: explicit notify parm(s) modified
    Wed May  4 19:14:51 2022 OPTIONS IMPORT: compression parms modified
    Wed May  4 19:14:51 2022 OPTIONS IMPORT: --ifconfig/up options modified
    Wed May  4 19:14:51 2022 OPTIONS IMPORT: route options modified
    Wed May  4 19:14:51 2022 OPTIONS IMPORT: route-related options modified
    Wed May  4 19:14:51 2022 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
    Wed May  4 19:14:51 2022 OPTIONS IMPORT: peer-id set
    Wed May  4 19:14:51 2022 OPTIONS IMPORT: adjusting link_mtu to 1624
    Wed May  4 19:14:51 2022 OPTIONS IMPORT: data channel crypto options modified
    Wed May  4 19:14:51 2022 Data Channel: using negotiated cipher 'AES-256-GCM'
    Wed May  4 19:14:51 2022 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
    Wed May  4 19:14:51 2022 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
    Wed May  4 19:14:51 2022 ROUTE_GATEWAY 10.46.46.117/255.255.255.248 IFACE=wwan0 HWADDR=00:00:00:00:00:00
    Wed May  4 19:14:51 2022 GDG6: remote_host_ipv6=n/a
    Wed May  4 19:14:51 2022 ROUTE6_GATEWAY fe80::6802:b8ff:fede:bb0a IFACE=wlan0
    Wed May  4 19:14:51 2022 TUN/TAP device tun0 opened
    Wed May  4 19:14:51 2022 TUN/TAP TX queue length set to 100
    Wed May  4 19:14:51 2022 do_ifconfig, tt->did_ifconfig_ipv6_setup=1
    Wed May  4 19:14:51 2022 /sbin/ifconfig tun0 100.96.1.34 netmask 255.255.255.240 mtu 1500 broadcast 100.96.1.47
    Wed May  4 19:14:51 2022 /sbin/ifconfig tun0 add fd:0:0:8102::2/64
    Wed May  4 19:14:51 2022 /sbin/route add -net 100.96.0.0 netmask 255.224.0.0 gw 100.96.1.33
    Wed May  4 19:14:51 2022 /sbin/route add -net 100.80.0.0 netmask 255.240.0.0 gw 100.96.1.33
    Wed May  4 19:14:51 2022 add_route_ipv6(fd:0:0:8000::/49 -> fd:0:0:8102::1 metric -1) dev tun0
    Wed May  4 19:14:51 2022 /sbin/route -A inet6 add fd:0:0:8000::/49 dev tun0
    Wed May  4 19:14:51 2022 add_route_ipv6(fd:0:0:4000::/50 -> fd:0:0:8102::1 metric -1) dev tun0
    Wed May  4 19:14:51 2022 /sbin/route -A inet6 add fd:0:0:4000::/50 dev tun0
    Wed May  4 19:14:51 2022 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
    Wed May  4 19:14:51 2022 Initialization Sequence Completed
    D Djalma Ribeiro
    @tom
    Options error: In [CMD-LINE]:1: Error opening configuration file: /etc/openvpn/connector01_sao_paulo.ovpn
    D Djalma Ribeiro
    @tom
    sh-4.4# ping google.com
    PING google.com (142.250.79.238): 56 data bytes
    64 bytes from 142.250.79.238: icmp_seq=0 ttl=114 time=63.395 ms
    64 bytes from 142.250.79.238: icmp_seq=1 ttl=114 time=63.037 ms
    64 bytes from 142.250.79.238: icmp_seq=2 ttl=114 time=62.547 ms
    64 bytes from 142.250.79.238: icmp_seq=3 ttl=114 time=66.664 ms
    64 bytes from 142.250.79.238: icmp_seq=4 ttl=114 time=63.391 ms
    64 bytes from 142.250.79.238: icmp_seq=5 ttl=114 time=64.499 ms
    64 bytes from 142.250.79.238: icmp_seq=6 ttl=114 time=68.028 ms
    64 bytes from 142.250.79.238: icmp_seq=7 ttl=114 time=75.665 ms
    ^C--- google.com ping statistics ---
    8 packets transmitted, 8 packets received, 0% packet loss
    round-trip min/avg/max/stddev = 62.547/65.903/75.665/4.099 ms
    D Djalma Ribeiro
    Command "systemctl enable rb5-flight-modem"
    Result: Failed to enable unit: Unit file rb5-flight-modem.service does not exist.
    D Djalma Ribeiro
    I'm using this one: https://docs.modalai.com/Qualcomm-Flight-RB5-user-guide-connect-network/#connecting-to-5g-network
    I'm using an LTE chip. I already configured it using the rb5-modem-configure command.
    The systemctl status -l rb5-modem command gives the following output:
    ifconfig:
    D Djalma Ribeiro
    How to install and configure OpenVPN on Qualcomm Flight RB5?
    I'm following the documentation but I'm having a lot of trouble.
    I have the etc/openvpn folder and I have already copied the ovpn file into it.
    When I run the command "openvpn --script-security 2 --config myfile.ovpn" nothing happens.
    When I run "systemctl enable vpn-start.service" I see the message: Failed to enable unit: Unit file vpn-start.service does not exist. Because there is no vpn-start file in the /etc/systemd/system folder
    Does anyone know what I should do?
