Dean HartD
Dean Hart
@Dean Hart
  • Resetting ssh password
    Dean HartD Dean Hart
    Seems to be an issue with QGC itself. The latest v4.2.3 I’m running is where it’s failing. If I revert back to the latest 4.1.* (4.1.7) it works.
    Development Drones m500
    @James-Strawson Yes wifi (softAP mode).
    @James-Strawson Just restarted QGC to test. Correct. Green line stops just over 1/3 of the way and error Vehicle 1 did not respond to request for parameters. This will cause QGroundControl to be unable to display its full user interface is displayed.
    Thanks @Alex-Gardner . I reflashed the board. Went through all the setup instructions but I'm stuck at https://docs.modalai.com/voxl-m500-user-guide-px4/#connect-m500-to-qgroundcontrol.
    QGC can see the drone, I can see telemetry streaming, but when trying to access vehicle settings I encounter the message Vehicle settings and info will display after connecting your vehicle.
    When attempting to arm I encounter the error Vehicle did not respond to command: MAV_CMD_COMPONENT_ARM_DISARM.
    This is what's running on the drone:
    root@apq8096:~# voxl-inspect-services  --version
     Service Name         |  Version  |  Enabled  |   Running   |  CPU Usage
     docker-autorun       |    1.2.4  | Disabled  | Not Running |
     docker-daemon        |    1.2.4  | Disabled  | Not Running |
     modallink-relink     |   0.15.1  | Disabled  | Not Running |
     voxl-camera-server   |    0.9.1  |  Enabled  |   Running   |     2.0
     voxl-cpu-monitor     |    0.2.5  |  Enabled  |   Running   |     0.0
     voxl-dfs-server      |    0.2.6  | Disabled  | Not Running |
     voxl-imu-server      |    1.0.1  |  Enabled  |   Running   |     0.0
     voxl-mavlink-server  |    0.1.1  |  Enabled  |   Running   |     0.0
     voxl-modem           |   0.15.1  | Disabled  | Not Running |
     voxl-portal          |    0.2.6  |  Enabled  |   Running   |     0.0
     voxl-qvio-server     |    0.4.6  |  Enabled  |   Running   |    10.1
     voxl-streamer        |    0.3.1  | Disabled  | Not Running |
     voxl-tag-detector    |    0.0.4  | Disabled  | Not Running |
     voxl-tflite-server   |    0.2.3  | Disabled  | Not Running |
     voxl-time-sync       |    1.1.1  | Disabled  | Not Running |
     voxl-vision-px4      |    1.0.5  |  Enabled  |   Running   |     0.0
     voxl-wait-for-fs     |    1.1.1  |  Enabled  |  Completed  |
    Any ideas?
    I purchased the VOXL M500 over a year ago. I set it up initially but due to other projects I’m just getting back to it. Unable to ssh in using root/oelinux123 so worried I may have changed the password. How do I go about resetting it?
