Dean FortierD
Dean Fortier
@Dean Fortier
  • UVC Camera interfacing in version 3.2.0
    Dean FortierD Dean Fortier
    Thank you both
    Hi Modalai Team,
    I am using a UVC camera and following the UVC streaming guide with VOXL version 3.2.0 and do not have ffmpeg installed by default and the link to download the ffmpeg ipk is broken. What is the recommended path forward for using a UVC camera? Should I use voxl-docker-ffmpeg, build voxl-ffmpeg, or something else?
    Thanks
    Also here is my current voxl-version:
    system-image:    ModalAI 3.2.0 BUILDER: ekatzfey BUILD_TIME: 2021-02-05_19:54
    kernel:          #1 SMP PREEMPT Fri Feb 5 20:03:22 UTC 2021 3.18.71-perf
    factory-bundle:  1.0.1 (Yocto installation)
    architecture:    aarch64
    processor:       apq8096
    os:              GNU/Linux
    voxl-suite:
    Package: voxl-suite
    Version: 0.3.4
    Depends: voxl-utils (>= 0.6.0), libmodal_json (>= 0.3.4), libmodal_pipe (>= 1.7.8), librc_math (>= 1.1.4), libvoxl_io (>= 0.5.4), mavlink-camera-manager (>= 0.0.1), opencv (>= 4.5.1), openmp (>= 10.0.1), voxl-camera-server (>= 0.5.6), voxl-dfs-server (>= 0.0.7), voxl-docker-support (>= 1.1.1), voxl-gphoto2 (>= 0.0.5), voxl-hal3-tof-cam-ros (>= 0.0.5), voxl-imu-server (>= 0.7.8), voxl-modem (>= 0.11.0), voxl-mpa-tflite-server (>= 0.0.2), voxl-mpa-tools (>= 0.1.6), voxl-nodes (>= 0.1.3), voxl-qvio-server (>= 0.2.1), voxl-rtsp (>= 1.0.3), voxl-streamer (>= 0.2.1), voxl-vision-px4 (>= 0.8.1), voxl-vpn (>= 0.0.3)
    Status: install user installed
    Section: base
    Architecture: all
    Maintainer: james@modalai.com
    MD5Sum: e1e5bf1a125affe5036099f6ce895bed
    Filename: voxl-suite_0.3.4.ipk
    Description: meta-package for voxl-suite stable release
    Installed-Time: 13238
    Package: voxl-suite
    Version: 0.2.0
    Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
    Status: unknown ok not-installed
    Section: base
    Architecture: armv7a
    MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
    Filename: voxl-suite_0.2.0.ipk
    Description: meta-package to install all of the voxl-suite
  • Bad Image Output using voxl_cam_ros
    Hi @James-Strawson,
    Thanks for the tip I will try it out!
  • Getting voxl-streamer running
    @Eric-Katzfey Thanks for the explanation, I was not starting the voxl-camera-server before.
    When I started the voxl-camera-server, I had my camera configuration include the tracking camera which stopped the voxl-camera-server from starting correctly.
    Once I changed my camera configuration with voxl-configure-cameras to "hires only" I was able to start the camera server and then start the voxl-streamer as well.
    Hi @Eric-Katzfey,
    Thanks for the tip, I installed the 3.2.0-0.3.4-b release and still have the same issue. Also I am not sure what to modify in the voxl-streamer.conf file. I modified line 6 from:
    "mpa-camera": "hires_preview" },
    to:
    "mpa-camera": "hires/preview" },
    but I think I am missing something as I am getting the same error message.
    Thanks,
    Dean
    Hey Modalai Team,
    I'm trying to use voxl_cam_ros with an M0025 (IMX214) and am not getting good image quality out. Here is an example:
    I am able to use voxl-rtsp with a decent output:
    I am not getting any terrible errors when launching the ROS node except for
    ERROR: The requested frame_id(0) does not exist in the queue.
    [ERROR] [20204.856915384]: GetImageData() Unable to get Frame data for id: 0 rc: -2
    which is harmless according to this post.
    my voxl-version is as follows:
    yocto:/# voxl-version
    cat: /etc/modalai/voxl-software-bundle-version.txt: No such file or directory
    processor:       apq8096
    os:              GNU/Linux
    voxl-suite:
    Package: voxl-suite
    Version: 0.3.4
    Section: base
    Architecture: all
    Package: voxl-suite
    Version: 0.2.0
    Section: base
    Any tips would be greatly appreciated.
    Thanks,
    Dean
    Hi @Lynn-Koudsi and @Eric-Katzfey,
    I am having the same issue as you Lynn where I am getting the error:
    yocto:/# voxl-streamer
    Using configuration file /etc/modalai/voxl-streamer.conf
    closing FDs for client channel 0
    ERROR: Couldn't open MPA pipe /run/mpa/hires/preview/
    Where is the script where you changed /run/mpa/hires_preview?
    Thanks,
    Dean
