Davon PrewittD
Davon Prewitt
@Davon Prewitt
  • New visible cameras not showing up in SW
    Davon PrewittD Davon Prewitt
    @Davon-Prewitt For context, we bought 10 and only 4 seem to work.
    Hello! I have a few IMX678s (M0143) that I bought brand new, but only a few of them seem to work using our working camera configuration using voxl-camera-server. I am on SDK 1.0.0. Could you help diagnose the issue? Is there a good way to determine if the cameras are being seen - perhaps a driver interface besides the camera server? Is this a known hardware issue?
  • IMX678 M0143 Driver not recognized on SDK 1.0.0
    @Moderator Hello again, please advise. I have used voxl-configure-cameras to setup voxl-camera-server to read frames. No luck on my various IMX678 camera modules nor interposers using SDK 1.0.0. The HAL module doesn't seem to recognize the presence of a camera module when calling voxl-camera-server -s. Is there something else i need to do?
    @Moderator Hello. I have flashed the new drivers and voxl-configure-cameras provided me the right drivers and config. No luck getting the camera server to run though. I tried running the configuration on part M0135 interposer.
    Driver info
    system-image: 1.6.2-M0104-14.1a-perf
    kernel: #1 SMP PREEMPT Fri May 19 22:53:15 UTC 2023 4.19.125
    hw version: M0104
    voxl-suite: 1.0.0
    no current network connection
    voxl-camera-server output
    sensor type: imx678
    isEnabled: 1
    camId: 0
    camId2: -1
    fps: 30
    en_preview:          0
    pre_width:           640
    pre_height:          480
    pre_format:          nv21
    en_small_video:      1
    small_video_width:   1024
    small_video_height:  768
    en_large_video:      1
    large_video_width:   2048
    large_video_height:  1536
    en_snapshot:         1
    snap_width:          3840
    snap_height:         2160
    ae_mode:             isp
    standby_enabled:     0
    decimator:           1
    independent_exposure:0
    Starting Camera: hires
    Segmentation fault:
    Fault thread: voxl-camera-ser(tid: 3066)
    Fault address: 0x5658e6a6cc
    Address not mapped.
    Segmentation fault
    I have done some more digging and it would appear that HAL3 does not see my IMX678. After running voxl-camera-server -s snd -l, the LED on the camera is on, but not being recognized.
    I am on the VOXL 2 MINI. I used voxl-configure-cameras 8 to create a config for the IMX678 (M0143) to use voxl-camera-server. I get the following errors.
    Camera Configuration: 8
    [ERROR] Your system image is too old to support the new camera driver structure
    [ERROR] Plese update to a system image newer than May 14 2023
    I am already flashed to the latest SDK (1.0.0). Is there a workaround?
