D
Daniel Lin
@Daniel Lin
  • Running customized software in emulators
    D Daniel Lin
    I know that customized software can be compiled in voxl-emulator or voxl-cross dockers. After compilation, it seems that the compiled code can only run on VOXL. I have tried to installed the compiled voxl-imu-server.ipk file in voxl-emulator docker. After that, executing the installed software generates errors like:
    Failed to get D-Bus connection: Operation not permitted
    However, there are other normal outputs. Therefore, my inferences are that voxl-emulator is able to execute the code but does not have the emulated hardware.
    My ultimate goal is to run customized software on emulated environment, instead of on physical VOXL m500 drones, so as to protect the physical drones from damages caused by our buggy codes.
    To sum up, my question is: is there an emulated VOXL m500 environment that I can test our planners?
