Cai BillC
Cai Bill
@Cai Bill
  • VOXL 2 No ESC(s) detected
    Cai BillC Cai Bill
    @Alex-Kushleyev
    Yes it does now, thanks for the help.
    I'm currently trying to get postion fly mode to work, I check all the calibration, they are there, and the VIO output and IMU output looks fine. But when I go to qground control, I can't arm the drone with position mode. It give
    MAV_CMD_COMPONENT_ARM_DISARM command temporarily rejeceted
    ,I test the esc works and I can fly the drone with Manuel mode, but can't switch into position mode and there is no error logged. The drone is on battery and not connect to USB.
    I will put my px4 params here:
    # Onboard parameters for Vehicle 1
    # Stack: PX4 Pro
    # Vehicle: Multi-Rotor
    # Version: 1.14.0 dev
    # Git Revision: 636ffefcb102004d
    # Vehicle-Id Component-Id Name Value Type
    1	1	ASPD_SCALE_1	1.000000000000000000	9
    1	1	BAT1_CAPACITY	4700.000000000000000000	9
    1	1	BAT1_N_CELLS	3	6
    1	1	BAT1_R_INTERNAL	0.003000000026077032	9
    1	1	BAT1_SOURCE	0	6
    1	1	BAT1_V_CHARGED	4.150000095367431641	9
    1	1	BAT1_V_EMPTY	3.500000000000000000	9
    1	1	BAT1_V_LOAD_DROP	0.100000001490116119	9
    1	1	BAT_AVRG_CURRENT	15.000000000000000000	9
    1	1	BAT_CRIT_THR	0.100000001490116119	9
    1	1	BAT_EMERGEN_THR	0.050000000745058060	9
    1	1	BAT_LOW_THR	0.150000005960464478	9
    1	1	BAT_N_CELLS	3	6
    1	1	BAT_V_CHARGED	4.050000190734863281	9
    1	1	BAT_V_EMPTY	3.599999904632568359	9
    1	1	BAT_V_LOAD_DROP	0.300000011920928955	9
    1	1	CAL_ACC0_ID	2490378	6
    1	1	CAL_ACC0_PRIO	50	6
    1	1	CAL_ACC0_ROT	-1	6
    1	1	CAL_ACC0_XOFF	0.013878345489501953	9
    1	1	CAL_ACC0_XSCALE	1.003414273262023926	9
    1	1	CAL_ACC0_YOFF	0.009169578552246094	9
    1	1	CAL_ACC0_YSCALE	1.002086520195007324	9
    1	1	CAL_ACC0_ZOFF	-0.086218357086181641	9
    1	1	CAL_ACC0_ZSCALE	1.002695202827453613	9
    1	1	CAL_ACC1_ID	0	6
    1	1	CAL_ACC2_ID	0	6
    1	1	CAL_ACC3_ID	0	6
    1	1	CAL_AIR_CMODEL	0	6
    1	1	CAL_AIR_TUBED_MM	1.500000000000000000	9
    1	1	CAL_AIR_TUBELEN	0.200000002980232239	9
    1	1	CAL_BARO0_ID	0	6
    1	1	CAL_BARO1_ID	0	6
    1	1	CAL_BARO2_ID	0	6
    1	1	CAL_BARO3_ID	0	6
    1	1	CAL_GYRO0_ID	2490378	6
    1	1	CAL_GYRO0_PRIO	50	6
    1	1	CAL_GYRO0_ROT	-1	6
    1	1	CAL_GYRO0_XOFF	0.017300000414252281	9
    1	1	CAL_GYRO0_YOFF	0.013100000098347664	9
    1	1	CAL_GYRO0_ZOFF	-0.029300000518560410	9
    1	1	CAL_GYRO1_ID	0	6
    1	1	CAL_GYRO2_ID	0	6
    1	1	CAL_GYRO3_ID	0	6
    1	1	CAL_MAG0_ID	396809	6
    1	1	CAL_MAG0_PRIO	75	6
    1	1	CAL_MAG0_ROT	0	6
    1	1	CAL_MAG0_XCOMP	0.000000000000000000	9
    1	1	CAL_MAG0_XODIAG	0.010231973603367805	9
    1	1	CAL_MAG0_XOFF	-0.013507993891835213	9
    1	1	CAL_MAG0_XSCALE	1.011053204536437988	9
    1	1	CAL_MAG0_YCOMP	0.000000000000000000	9
    1	1	CAL_MAG0_YODIAG	-0.043380342423915863	9
    1	1	CAL_MAG0_YOFF	-0.043541945517063141	9
    1	1	CAL_MAG0_YSCALE	1.010007023811340332	9
    1	1	CAL_MAG0_ZCOMP	0.000000000000000000	9
    1	1	CAL_MAG0_ZODIAG	0.123449578881263733	9
    1	1	CAL_MAG0_ZOFF	-0.078322507441043854	9
    1	1	CAL_MAG0_ZSCALE	1.009836196899414063	9
    1	1	CAL_MAG1_ID	0	6
    1	1	CAL_MAG1_ROT	-1	6
    1	1	CAL_MAG2_ID	0	6
    1	1	CAL_MAG2_ROT	-1	6
    1	1	CAL_MAG3_ID	0	6
    1	1	CAL_MAG3_ROT	-1	6
    1	1	CAL_MAG_COMP_TYP	0	6
    1	1	CAL_MAG_SIDES	63	6
    1	1	CA_AIRFRAME	0	6
    1	1	CA_FAILURE_MODE	0	6
    1	1	CA_METHOD	2	6
    1	1	CA_R0_SLEW	0.000000000000000000	9
    1	1	CA_R10_SLEW	0.000000000000000000	9
    1	1	CA_R11_SLEW	0.000000000000000000	9
    1	1	CA_R1_SLEW	0.000000000000000000	9
    1	1	CA_R2_SLEW	0.000000000000000000	9
    1	1	CA_R3_SLEW	0.000000000000000000	9
    1	1	CA_R4_SLEW	0.000000000000000000	9
    1	1	CA_R5_SLEW	0.000000000000000000	9
    1	1	CA_R6_SLEW	0.000000000000000000	9
    1	1	CA_R7_SLEW	0.000000000000000000	9
    1	1	CA_R8_SLEW	0.000000000000000000	9
    1	1	CA_R9_SLEW	0.000000000000000000	9
    1	1	CA_ROTOR0_AX	0.000000000000000000	9
    1	1	CA_ROTOR0_AY	0.000000000000000000	9
    1	1	CA_ROTOR0_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR0_CT	6.500000000000000000	9
    1	1	CA_ROTOR0_KM	0.050000000745058060	9
    1	1	CA_ROTOR0_PX	0.170000001788139343	9
    1	1	CA_ROTOR0_PY	0.170000001788139343	9
    1	1	CA_ROTOR0_PZ	0.000000000000000000	9
    1	1	CA_ROTOR10_AX	0.000000000000000000	9
    1	1	CA_ROTOR10_AY	0.000000000000000000	9
    1	1	CA_ROTOR10_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR10_CT	6.500000000000000000	9
    1	1	CA_ROTOR10_KM	0.050000000745058060	9
    1	1	CA_ROTOR10_PX	0.000000000000000000	9
    1	1	CA_ROTOR10_PY	0.000000000000000000	9
    1	1	CA_ROTOR10_PZ	0.000000000000000000	9
    1	1	CA_ROTOR11_AX	0.000000000000000000	9
    1	1	CA_ROTOR11_AY	0.000000000000000000	9
    1	1	CA_ROTOR11_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR11_CT	6.500000000000000000	9
    1	1	CA_ROTOR11_KM	0.050000000745058060	9
    1	1	CA_ROTOR11_PX	0.000000000000000000	9
    1	1	CA_ROTOR11_PY	0.000000000000000000	9
    1	1	CA_ROTOR11_PZ	0.000000000000000000	9
    1	1	CA_ROTOR1_AX	0.000000000000000000	9
    1	1	CA_ROTOR1_AY	0.000000000000000000	9
    1	1	CA_ROTOR1_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR1_CT	6.500000000000000000	9
    1	1	CA_ROTOR1_KM	0.050000000745058060	9
    1	1	CA_ROTOR1_PX	-0.170000001788139343	9
    1	1	CA_ROTOR1_PY	-0.170000001788139343	9
    1	1	CA_ROTOR1_PZ	0.000000000000000000	9
    1	1	CA_ROTOR2_AX	0.000000000000000000	9
    1	1	CA_ROTOR2_AY	0.000000000000000000	9
    1	1	CA_ROTOR2_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR2_CT	6.500000000000000000	9
    1	1	CA_ROTOR2_KM	-0.050000000745058060	9
    1	1	CA_ROTOR2_PX	0.170000001788139343	9
    1	1	CA_ROTOR2_PY	-0.170000001788139343	9
    1	1	CA_ROTOR2_PZ	0.000000000000000000	9
    1	1	CA_ROTOR3_AX	0.000000000000000000	9
    1	1	CA_ROTOR3_AY	0.000000000000000000	9
    1	1	CA_ROTOR3_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR3_CT	6.500000000000000000	9
    1	1	CA_ROTOR3_KM	-0.050000000745058060	9
    1	1	CA_ROTOR3_PX	-0.170000001788139343	9
    1	1	CA_ROTOR3_PY	0.170000001788139343	9
    1	1	CA_ROTOR3_PZ	0.000000000000000000	9
    1	1	CA_ROTOR4_AX	0.000000000000000000	9
    1	1	CA_ROTOR4_AY	0.000000000000000000	9
    1	1	CA_ROTOR4_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR4_CT	6.500000000000000000	9
    1	1	CA_ROTOR4_KM	0.050000000745058060	9
    1	1	CA_ROTOR4_PX	0.000000000000000000	9
    1	1	CA_ROTOR4_PY	0.000000000000000000	9
    1	1	CA_ROTOR4_PZ	0.000000000000000000	9
    1	1	CA_ROTOR5_AX	0.000000000000000000	9
    1	1	CA_ROTOR5_AY	0.000000000000000000	9
    1	1	CA_ROTOR5_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR5_CT	6.500000000000000000	9
    1	1	CA_ROTOR5_KM	0.050000000745058060	9
    1	1	CA_ROTOR5_PX	0.000000000000000000	9
    1	1	CA_ROTOR5_PY	0.000000000000000000	9
    1	1	CA_ROTOR5_PZ	0.000000000000000000	9
    1	1	CA_ROTOR6_AX	0.000000000000000000	9
    1	1	CA_ROTOR6_AY	0.000000000000000000	9
    1	1	CA_ROTOR6_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR6_CT	6.500000000000000000	9
    1	1	CA_ROTOR6_KM	0.050000000745058060	9
    1	1	CA_ROTOR6_PX	0.000000000000000000	9
    1	1	CA_ROTOR6_PY	0.000000000000000000	9
    1	1	CA_ROTOR6_PZ	0.000000000000000000	9
    1	1	CA_ROTOR7_AX	0.000000000000000000	9
    1	1	CA_ROTOR7_AY	0.000000000000000000	9
    1	1	CA_ROTOR7_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR7_CT	6.500000000000000000	9
    1	1	CA_ROTOR7_KM	0.050000000745058060	9
    1	1	CA_ROTOR7_PX	0.000000000000000000	9
    1	1	CA_ROTOR7_PY	0.000000000000000000	9
    1	1	CA_ROTOR7_PZ	0.000000000000000000	9
    1	1	CA_ROTOR8_AX	0.000000000000000000	9
    1	1	CA_ROTOR8_AY	0.000000000000000000	9
    1	1	CA_ROTOR8_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR8_CT	6.500000000000000000	9
    1	1	CA_ROTOR8_KM	0.050000000745058060	9
    1	1	CA_ROTOR8_PX	0.000000000000000000	9
    1	1	CA_ROTOR8_PY	0.000000000000000000	9
    1	1	CA_ROTOR8_PZ	0.000000000000000000	9
    1	1	CA_ROTOR9_AX	0.000000000000000000	9
    1	1	CA_ROTOR9_AY	0.000000000000000000	9
    1	1	CA_ROTOR9_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR9_CT	6.500000000000000000	9
    1	1	CA_ROTOR9_KM	0.050000000745058060	9
    1	1	CA_ROTOR9_PX	0.000000000000000000	9
    1	1	CA_ROTOR9_PY	0.000000000000000000	9
    1	1	CA_ROTOR9_PZ	0.000000000000000000	9
    1	1	CA_ROTOR_COUNT	4	6
    1	1	CA_R_REV	0	6
    1	1	CA_SV0_SLEW	0.000000000000000000	9
    1	1	CA_SV1_SLEW	0.000000000000000000	9
    1	1	CA_SV2_SLEW	0.000000000000000000	9
    1	1	CA_SV3_SLEW	0.000000000000000000	9
    1	1	CA_SV4_SLEW	0.000000000000000000	9
    1	1	CA_SV5_SLEW	0.000000000000000000	9
    1	1	CA_SV6_SLEW	0.000000000000000000	9
    1	1	CA_SV7_SLEW	0.000000000000000000	9
    1	1	CBRK_AIRSPD_CHK	0	6
    1	1	CBRK_FLIGHTTERM	121212	6
    1	1	CBRK_IO_SAFETY	22027	6
    1	1	CBRK_SUPPLY_CHK	894281	6
    1	1	CBRK_USB_CHK	197848	6
    1	1	CBRK_VTOLARMING	0	6
    1	1	COM_ACT_FAIL_ACT	0	6
    1	1	COM_ARM_ARSP_EN	1	6
    1	1	COM_ARM_AUTH_ID	10	6
    1	1	COM_ARM_AUTH_MET	0	6
    1	1	COM_ARM_AUTH_REQ	0	6
    1	1	COM_ARM_AUTH_TO	1.000000000000000000	9
    1	1	COM_ARM_BAD_INOV	0	6
    1	1	COM_ARM_CHK_ESCS	0	6
    1	1	COM_ARM_EKF_BIAS	3.000000000000000000	9
    1	1	COM_ARM_EKF_HGT	1.000000000000000000	9
    1	1	COM_ARM_EKF_POS	0.500000000000000000	9
    1	1	COM_ARM_EKF_VEL	0.500000000000000000	9
    1	1	COM_ARM_EKF_YAW	0.500000000000000000	9
    1	1	COM_ARM_HFLT_CHK	1	6
    1	1	COM_ARM_IMU_ACC	0.699999988079071045	9
    1	1	COM_ARM_IMU_GYR	0.250000000000000000	9
    1	1	COM_ARM_MAG_ANG	60	6
    1	1	COM_ARM_MAG_STR	2	6
    1	1	COM_ARM_MIS_REQ	0	6
    1	1	COM_ARM_ODID	0	6
    1	1	COM_ARM_SDCARD	0	6
    1	1	COM_ARM_SWISBTN	0	6
    1	1	COM_ARM_WO_GPS	1	6
    1	1	COM_CPU_MAX	-1.000000000000000000	9
    1	1	COM_DISARM_FORCE	0	6
    1	1	COM_DISARM_LAND	0.100000001490116119	9
    1	1	COM_DISARM_PRFLT	20.000000000000000000	9
    1	1	COM_DL_LOSS_T	10	6
    1	1	COM_FAIL_ACT_T	5.000000000000000000	9
    1	1	COM_FLIGHT_UUID	5	6
    1	1	COM_FLTMODE1	7	6
    1	1	COM_FLTMODE2	0	6
    1	1	COM_FLTMODE3	0	6
    1	1	COM_FLTMODE4	2	6
    1	1	COM_FLTMODE5	0	6
    1	1	COM_FLTMODE6	0	6
    1	1	COM_FLT_PROFILE	0	6
    1	1	COM_FLT_TIME_MAX	-1	6
    1	1	COM_FORCE_SAFETY	0	6
    1	1	COM_HLDL_LOSS_T	120	6
    1	1	COM_HLDL_REG_T	0	6
    1	1	COM_HOME_EN	1	6
    1	1	COM_HOME_IN_AIR	0	6
    1	1	COM_IMB_PROP_ACT	0	6
    1	1	COM_KILL_DISARM	0.000000000000000000	9
    1	1	COM_LKDOWN_TKO	3.000000000000000000	9
    1	1	COM_LOW_BAT_ACT	0	6
    1	1	COM_MOT_TEST_EN	1	6
    1	1	COM_OBC_LOSS_T	5.000000000000000000	9
    1	1	COM_OBL_RC_ACT	0	6
    1	1	COM_OBS_AVOID	0	6
    1	1	COM_OF_LOSS_T	3.000000000000000000	9
    1	1	COM_PARACHUTE	0	6
    1	1	COM_POSCTL_NAVL	0	6
    1	1	COM_POS_FS_DELAY	1	6
    1	1	COM_POS_FS_EPH	5.000000000000000000	9
    1	1	COM_POS_LOW_EPH	-1.000000000000000000	9
    1	1	COM_POWER_COUNT	1	6
    1	1	COM_PREARM_MODE	0	6
    1	1	COM_QC_ACT	0	6
    1	1	COM_RCL_EXCEPT	0	6
    1	1	COM_RC_ARM_HYST	1000	6
    1	1	COM_RC_IN_MODE	3	6
    1	1	COM_RC_LOSS_T	0.500000000000000000	9
    1	1	COM_RC_OVERRIDE	1	6
    1	1	COM_RC_STICK_OV	30.000000000000000000	9
    1	1	COM_SPOOLUP_TIME	2.000000000000000000	9
    1	1	COM_TAKEOFF_ACT	0	6
    1	1	COM_VEL_FS_EVH	1.000000000000000000	9
    1	1	COM_WIND_MAX	-1.000000000000000000	9
    1	1	COM_WIND_WARN	-1.000000000000000000	9
    1	1	CP_DELAY	0.400000005960464478	9
    1	1	CP_DIST	-1.000000000000000000	9
    1	1	CP_GO_NO_DATA	0	6
    1	1	CP_GUIDE_ANG	30.000000000000000000	9
    1	1	EKF2_ABIAS_INIT	0.200000002980232239	9
    1	1	EKF2_ABL_ACCLIM	25.000000000000000000	9
    1	1	EKF2_ABL_GYRLIM	3.000000000000000000	9
    1	1	EKF2_ABL_LIM	0.400000005960464478	9
    1	1	EKF2_ABL_TAU	0.500000000000000000	9
    1	1	EKF2_ACC_B_NOISE	0.003000000026077032	9
    1	1	EKF2_ACC_NOISE	0.349999994039535522	9
    1	1	EKF2_AID_MASK	0	6
    1	1	EKF2_ANGERR_INIT	0.100000001490116119	9
    1	1	EKF2_ARSP_THR	0.000000000000000000	9
    1	1	EKF2_ASPD_MAX	20.000000000000000000	9
    1	1	EKF2_ASP_DELAY	100.000000000000000000	9
    1	1	EKF2_AVEL_DELAY	5.000000000000000000	9
    1	1	EKF2_BARO_CTRL	1	6
    1	1	EKF2_BARO_DELAY	0.000000000000000000	9
    1	1	EKF2_BARO_GATE	5.000000000000000000	9
    1	1	EKF2_BARO_NOISE	3.500000000000000000	9
    1	1	EKF2_BCOEF_X	100.000000000000000000	9
    1	1	EKF2_BCOEF_Y	100.000000000000000000	9
    1	1	EKF2_BETA_GATE	5.000000000000000000	9
    1	1	EKF2_BETA_NOISE	0.300000011920928955	9
    1	1	EKF2_DECL_TYPE	7	6
    1	1	EKF2_DRAG_CTRL	0	6
    1	1	EKF2_DRAG_NOISE	2.500000000000000000	9
    1	1	EKF2_EAS_NOISE	1.399999976158142090	9
    1	1	EKF2_EVA_NOISE	0.100000001490116119	9
    1	1	EKF2_EVP_GATE	5.000000000000000000	9
    1	1	EKF2_EVP_NOISE	0.100000001490116119	9
    1	1	EKF2_EVV_GATE	3.000000000000000000	9
    1	1	EKF2_EVV_NOISE	0.100000001490116119	9
    1	1	EKF2_EV_CTRL	0	6
    1	1	EKF2_EV_DELAY	0.000000000000000000	9
    1	1	EKF2_EV_HGT_TO	5000	6
    1	1	EKF2_EV_NOISE_MD	0	6
    1	1	EKF2_EV_POS_TO	1000	6
    1	1	EKF2_EV_POS_X	0.000000000000000000	9
    1	1	EKF2_EV_POS_Y	0.000000000000000000	9
    1	1	EKF2_EV_POS_Z	0.000000000000000000	9
    1	1	EKF2_EV_QMIN	0	6
    1	1	EKF2_FUSE_BETA	0	6
    1	1	EKF2_GBIAS_INIT	0.100000001490116119	9
    1	1	EKF2_GND_EFF_DZ	4.000000000000000000	9
    1	1	EKF2_GND_MAX_HGT	0.500000000000000000	9
    1	1	EKF2_GPS_CHECK	245	6
    1	1	EKF2_GPS_CTRL	7	6
    1	1	EKF2_GPS_DELAY	110.000000000000000000	9
    1	1	EKF2_GPS_POS_X	0.000000000000000000	9
    1	1	EKF2_GPS_POS_Y	0.000000000000000000	9
    1	1	EKF2_GPS_POS_Z	0.000000000000000000	9
    1	1	EKF2_GPS_P_GATE	5.000000000000000000	9
    1	1	EKF2_GPS_P_NOISE	0.500000000000000000	9
    1	1	EKF2_GPS_V_GATE	5.000000000000000000	9
    1	1	EKF2_GPS_V_NOISE	0.300000011920928955	9
    1	1	EKF2_GRAV_NOISE	1.000000000000000000	9
    1	1	EKF2_GSF_TAS	15.000000000000000000	9
    1	1	EKF2_GYR_B_LIM	0.150000005960464478	9
    1	1	EKF2_GYR_B_NOISE	0.001000000047497451	9
    1	1	EKF2_GYR_NOISE	0.014999999664723873	9
    1	1	EKF2_HDG_GATE	2.599999904632568359	9
    1	1	EKF2_HEAD_NOISE	0.300000011920928955	9
    1	1	EKF2_HGT_REF	0	6
    1	1	EKF2_IMU_CTRL	3	6
    1	1	EKF2_IMU_POS_X	0.032999999821186066	9
    1	1	EKF2_IMU_POS_Y	0.008000000379979610	9
    1	1	EKF2_IMU_POS_Z	-0.035999998450279236	9
    1	1	EKF2_MAG_ACCLIM	0.500000000000000000	9
    1	1	EKF2_MAG_B_NOISE	0.000099999997473788	9
    1	1	EKF2_MAG_CHECK	1	6
    1	1	EKF2_MAG_DECL	0.000000000000000000	9
    1	1	EKF2_MAG_DELAY	0.000000000000000000	9
    1	1	EKF2_MAG_E_NOISE	0.001000000047497451	9
    1	1	EKF2_MAG_GATE	3.000000000000000000	9
    1	1	EKF2_MAG_NOISE	0.050000000745058060	9
    1	1	EKF2_MAG_TYPE	0	6
    1	1	EKF2_MAG_YAWLIM	0.200000002980232239	9
    1	1	EKF2_MCOEF	0.150000005960464478	9
    1	1	EKF2_MIN_RNG	0.100000001490116119	9
    1	1	EKF2_NOAID_NOISE	10.000000000000000000	9
    1	1	EKF2_NOAID_TOUT	5000000	6
    1	1	EKF2_OF_CTRL	0	6
    1	1	EKF2_OF_DELAY	20.000000000000000000	9
    1	1	EKF2_OF_GATE	3.000000000000000000	9
    1	1	EKF2_OF_N_MAX	0.500000000000000000	9
    1	1	EKF2_OF_N_MIN	0.150000005960464478	9
    1	1	EKF2_OF_POS_X	0.000000000000000000	9
    1	1	EKF2_OF_POS_Y	0.000000000000000000	9
    1	1	EKF2_OF_POS_Z	0.000000000000000000	9
    1	1	EKF2_OF_QMIN	1	6
    1	1	EKF2_PCOEF_XN	0.000000000000000000	9
    1	1	EKF2_PCOEF_XP	0.000000000000000000	9
    1	1	EKF2_PCOEF_YN	0.000000000000000000	9
    1	1	EKF2_PCOEF_YP	0.000000000000000000	9
    1	1	EKF2_PCOEF_Z	0.000000000000000000	9
    1	1	EKF2_PREDICT_US	10000	6
    1	1	EKF2_REQ_EPH	3.000000000000000000	9
    1	1	EKF2_REQ_EPV	5.000000000000000000	9
    1	1	EKF2_REQ_GPS_H	5.000000000000000000	9
    1	1	EKF2_REQ_HDRIFT	0.100000001490116119	9
    1	1	EKF2_REQ_NSATS	6	6
    1	1	EKF2_REQ_PDOP	2.500000000000000000	9
    1	1	EKF2_REQ_SACC	1.500000000000000000	9
    1	1	EKF2_REQ_VDRIFT	0.200000002980232239	9
    1	1	EKF2_RNG_A_HMAX	5.000000000000000000	9
    1	1	EKF2_RNG_A_IGATE	1.000000000000000000	9
    1	1	EKF2_RNG_A_VMAX	1.000000000000000000	9
    1	1	EKF2_RNG_CTRL	0	6
    1	1	EKF2_RNG_DELAY	5.000000000000000000	9
    1	1	EKF2_RNG_GATE	5.000000000000000000	9
    1	1	EKF2_RNG_K_GATE	1.000000000000000000	9
    1	1	EKF2_RNG_NOISE	0.100000001490116119	9
    1	1	EKF2_RNG_PITCH	0.000000000000000000	9
    1	1	EKF2_RNG_POS_X	0.000000000000000000	9
    1	1	EKF2_RNG_POS_Y	0.000000000000000000	9
    1	1	EKF2_RNG_POS_Z	0.000000000000000000	9
    1	1	EKF2_RNG_QLTY_T	1.000000000000000000	9
    1	1	EKF2_RNG_SFE	0.050000000745058060	9
    1	1	EKF2_SYNT_MAG_Z	0	6
    1	1	EKF2_TAS_GATE	3.000000000000000000	9
    1	1	EKF2_TAU_POS	0.250000000000000000	9
    1	1	EKF2_TAU_VEL	0.250000000000000000	9
    1	1	EKF2_TERR_GRAD	0.500000000000000000	9
    1	1	EKF2_TERR_MASK	3	6
    1	1	EKF2_TERR_NOISE	5.000000000000000000	9
    1	1	EKF2_WIND_NSD	0.009999999776482582	9
    1	1	FD_ACT_EN	1	6
    1	1	FD_ACT_MOT_C2T	2.000000000000000000	9
    1	1	FD_ACT_MOT_THR	0.200000002980232239	9
    1	1	FD_ACT_MOT_TOUT	100	6
    1	1	FD_ESCS_EN	1	6
    1	1	FD_EXT_ATS_EN	0	6
    1	1	FD_EXT_ATS_TRIG	1900	6
    1	1	FD_FAIL_P	60	6
    1	1	FD_FAIL_P_TTRI	0.300000011920928955	9
    1	1	FD_FAIL_R	60	6
    1	1	FD_FAIL_R_TTRI	0.300000011920928955	9
    1	1	FD_IMB_PROP_THR	30	6
    1	1	FLW_TGT_ALT_M	0	6
    1	1	FLW_TGT_DST	8.000000000000000000	9
    1	1	FLW_TGT_FA	180.000000000000000000	9
    1	1	FLW_TGT_HT	8.000000000000000000	9
    1	1	FLW_TGT_MAX_VEL	5.000000000000000000	9
    1	1	FLW_TGT_RS	0.100000001490116119	9
    1	1	FW_AIRSPD_MAX	20.000000000000000000	9
    1	1	FW_AIRSPD_TRIM	15.000000000000000000	9
    1	1	FW_ARSP_MODE	0	6
    1	1	FW_PSP_OFF	0.000000000000000000	9
    1	1	FW_T_CLMB_R_SP	3.000000000000000000	9
    1	1	FW_T_SINK_R_SP	2.000000000000000000	9
    1	1	GF_ACTION	2	6
    1	1	GF_ALTMODE	0	6
    1	1	GF_COUNT	-1	6
    1	1	GF_MAX_HOR_DIST	0.000000000000000000	9
    1	1	GF_MAX_VER_DIST	0.000000000000000000	9
    1	1	GF_PREDICT	0	6
    1	1	GF_SOURCE	0	6
    1	1	GND_SPEED_THR_SC	1.000000000000000000	9
    1	1	GPS_1_GNSS	0	6
    1	1	GPS_1_PROTOCOL	1	6
    1	1	GPS_DUMP_COMM	0	6
    1	1	GPS_PITCH_OFFSET	0.000000000000000000	9
    1	1	GPS_SAT_INFO	0	6
    1	1	GPS_UBX_BAUD2	230400	6
    1	1	GPS_UBX_CFG_INTF	0	6
    1	1	GPS_UBX_DYNMODEL	6	6
    1	1	GPS_UBX_MODE	0	6
    1	1	GPS_YAW_OFFSET	0.000000000000000000	9
    1	1	HTE_ACC_GATE	3.000000000000000000	9
    1	1	HTE_HT_ERR_INIT	0.100000001490116119	9
    1	1	HTE_HT_NOISE	0.003599999938160181	9
    1	1	HTE_THR_RANGE	0.200000002980232239	9
    1	1	HTE_VXY_THR	10.000000000000000000	9
    1	1	HTE_VZ_THR	2.000000000000000000	9
    1	1	IMU_ACCEL_CUTOFF	40.000000000000000000	9
    1	1	IMU_DGYRO_CUTOFF	40.000000000000000000	9
    1	1	IMU_GYRO_CUTOFF	40.000000000000000000	9
    1	1	IMU_GYRO_DNF_BW	15.000000000000000000	9
    1	1	IMU_GYRO_DNF_EN	1	6
    1	1	IMU_GYRO_DNF_HMC	3	6
    1	1	IMU_GYRO_DNF_MIN	25.000000000000000000	9
    1	1	IMU_GYRO_NF0_BW	20.000000000000000000	9
    1	1	IMU_GYRO_NF0_FRQ	0.000000000000000000	9
    1	1	IMU_GYRO_NF1_BW	20.000000000000000000	9
    1	1	IMU_GYRO_NF1_FRQ	0.000000000000000000	9
    1	1	IMU_GYRO_RATEMAX	800	6
    1	1	IMU_INTEG_RATE	200	6
    1	1	LNDMC_ALT_GND	2.000000000000000000	9
    1	1	LNDMC_ALT_MAX	-1.000000000000000000	9
    1	1	LNDMC_ROT_MAX	30.000000000000000000	9
    1	1	LNDMC_TRIG_TIME	0.500000000000000000	9
    1	1	LNDMC_XY_VEL_MAX	1.500000000000000000	9
    1	1	LNDMC_Z_VEL_MAX	0.250000000000000000	9
    1	1	LND_FLIGHT_T_HI	0	6
    1	1	LND_FLIGHT_T_LO	3380614	6
    1	1	MAN_ARM_GESTURE	0	6
    1	1	MAV_COMP_ID	1	6
    1	1	MAV_FWDEXTSP	1	6
    1	1	MAV_HASH_CHK_EN	1	6
    1	1	MAV_HB_FORW_EN	1	6
    1	1	MAV_PROTO_VER	0	6
    1	1	MAV_RADIO_TOUT	5	6
    1	1	MAV_SIK_RADIO_ID	0	6
    1	1	MAV_SYS_ID	1	6
    1	1	MAV_TYPE	2	6
    1	1	MAV_USEHILGPS	0	6
    1	1	MC_ACRO_EXPO	0.689999997615814209	9
    1	1	MC_ACRO_EXPO_Y	0.689999997615814209	9
    1	1	MC_ACRO_P_MAX	720.000000000000000000	9
    1	1	MC_ACRO_R_MAX	720.000000000000000000	9
    1	1	MC_ACRO_SUPEXPO	0.699999988079071045	9
    1	1	MC_ACRO_SUPEXPOY	0.699999988079071045	9
    1	1	MC_ACRO_Y_MAX	540.000000000000000000	9
    1	1	MC_AIRMODE	0	6
    1	1	MC_AT_APPLY	1	6
    1	1	MC_AT_AXES	3	6
    1	1	MC_AT_RISE_TIME	0.140000000596046448	9
    1	1	MC_AT_START	0	6
    1	1	MC_AT_SYSID_AMP	0.699999988079071045	9
    1	1	MC_BAT_SCALE_EN	0	6
    1	1	MC_INJECT_AMP	0.050000000745058060	9
    1	1	MC_INJECT_CNT	12	6
    1	1	MC_INJECT_EN	0	6
    1	1	MC_INJECT_INC	1.000000000000000000	9
    1	1	MC_INJECT_REST_T	1.000000000000000000	9
    1	1	MC_INJECT_RPY	2	6
    1	1	MC_INJECT_SINE_T	5.000000000000000000	9
    1	1	MC_INJECT_START	3.000000000000000000	9
    1	1	MC_MAN_TILT_TAU	0.000000000000000000	9
    1	1	MC_ORBIT_RAD_MAX	1000.000000000000000000	9
    1	1	MC_PITCHRATE_D	0.000000000000000000	9
    1	1	MC_PITCHRATE_FF	0.000000000000000000	9
    1	1	MC_PITCHRATE_I	0.400000005960464478	9
    1	1	MC_PITCHRATE_K	1.000000000000000000	9
    1	1	MC_PITCHRATE_MAX	150.000000000000000000	9
    1	1	MC_PITCHRATE_P	0.079999998211860657	9
    1	1	MC_PITCH_CUTOFF	0.000000000000000000	9
    1	1	MC_PITCH_P	5.500000000000000000	9
    1	1	MC_PR_INT_LIM	0.300000011920928955	9
    1	1	MC_ROLLRATE_D	0.000000000000000000	9
    1	1	MC_ROLLRATE_FF	0.000000000000000000	9
    1	1	MC_ROLLRATE_I	0.400000005960464478	9
    1	1	MC_ROLLRATE_K	1.000000000000000000	9
    1	1	MC_ROLLRATE_MAX	150.000000000000000000	9
    1	1	MC_ROLLRATE_P	0.079999998211860657	9
    1	1	MC_ROLL_CUTOFF	0.000000000000000000	9
    1	1	MC_ROLL_P	5.500000000000000000	9
    1	1	MC_RR_INT_LIM	0.300000011920928955	9
    1	1	MC_THR_CURVE_ACR	0	6
    1	1	MC_YAWRATE_D	0.000000000000000000	9
    1	1	MC_YAWRATE_FF	0.000000000000000000	9
    1	1	MC_YAWRATE_I	0.300000011920928955	9
    1	1	MC_YAWRATE_K	1.000000000000000000	9
    1	1	MC_YAWRATE_MAX	150.000000000000000000	9
    1	1	MC_YAWRATE_P	0.129999995231628418	9
    1	1	MC_YAW_CUTOFF	0.000000000000000000	9
    1	1	MC_YAW_P	2.000000000000000000	9
    1	1	MC_YAW_WEIGHT	0.400000005960464478	9
    1	1	MC_YR_INT_LIM	0.300000011920928955	9
    1	1	MIS_DIST_1WP	900.000000000000000000	9
    1	1	MIS_LND_ABRT_ALT	30	6
    1	1	MIS_MNT_YAW_CTL	0	6
    1	1	MIS_PD_TO	5.000000000000000000	9
    1	1	MIS_TAKEOFF_ALT	2.500000000000000000	9
    1	1	MIS_TKO_LAND_REQ	0	6
    1	1	MIS_YAW_ERR	12.000000000000000000	9
    1	1	MIS_YAW_TMT	-1.000000000000000000	9
    1	1	MODALAI_CONFIG	0	6
    1	1	MOT_SLEW_MAX	0.000000000000000000	9
    1	1	MPC_ACC_DOWN_MAX	3.000000000000000000	9
    1	1	MPC_ACC_HOR	3.000000000000000000	9
    1	1	MPC_ACC_HOR_MAX	6.000000000000000000	9
    1	1	MPC_ACC_UP_MAX	3.000000000000000000	9
    1	1	MPC_ALT_MODE	0	6
    1	1	MPC_HOLD_DZ	0.100000001490116119	9
    1	1	MPC_HOLD_MAX_XY	0.000000000000000000	9
    1	1	MPC_HOLD_MAX_Z	0.000000000000000000	9
    1	1	MPC_JERK_AUTO	4.000000000000000000	9
    1	1	MPC_JERK_MAX	40.000000000000000000	9
    1	1	MPC_LAND_ALT1	10.000000000000000000	9
    1	1	MPC_LAND_ALT2	5.000000000000000000	9
    1	1	MPC_LAND_ALT3	1.000000000000000000	9
    1	1	MPC_LAND_CRWL	0.300000011920928955	9
    1	1	MPC_LAND_RADIUS	1000.000000000000000000	9
    1	1	MPC_LAND_RC_HELP	0	6
    1	1	MPC_LAND_SPEED	1.000000000000000000	9
    1	1	MPC_MANTHR_MIN	0.119999997317790985	9
    1	1	MPC_MAN_TILT_MAX	35.000000000000000000	9
    1	1	MPC_MAN_Y_MAX	150.000000000000000000	9
    1	1	MPC_MAN_Y_TAU	0.079999998211860657	9
    1	1	MPC_POS_MODE	4	6
    1	1	MPC_THR_CURVE	0	6
    1	1	MPC_THR_HOVER	0.389999985694885254	9
    1	1	MPC_THR_MAX	0.750000000000000000	9
    1	1	MPC_THR_MIN	0.119999997317790985	9
    1	1	MPC_THR_XY_MARG	0.300000011920928955	9
    1	1	MPC_TILTMAX_AIR	30.000000000000000000	9
    1	1	MPC_TILTMAX_LND	12.000000000000000000	9
    1	1	MPC_TKO_RAMP_T	1.000000000000000000	9
    1	1	MPC_TKO_SPEED	1.500000000000000000	9
    1	1	MPC_USE_HTE	1	6
    1	1	MPC_VELD_LP	5.000000000000000000	9
    1	1	MPC_VEL_MANUAL	5.000000000000000000	9
    1	1	MPC_VEL_MAN_BACK	-1.000000000000000000	9
    1	1	MPC_VEL_MAN_SIDE	-1.000000000000000000	9
    1	1	MPC_XY_CRUISE	5.000000000000000000	9
    1	1	MPC_XY_ERR_MAX	2.000000000000000000	9
    1	1	MPC_XY_MAN_EXPO	0.449999988079071045	9
    1	1	MPC_XY_P	0.949999988079071045	9
    1	1	MPC_XY_TRAJ_P	0.500000000000000000	9
    1	1	MPC_XY_VEL_ALL	-10.000000000000000000	9
    1	1	MPC_XY_VEL_D_ACC	0.000000000000000000	9
    1	1	MPC_XY_VEL_I_ACC	0.100000001490116119	9
    1	1	MPC_XY_VEL_MAX	5.000000000000000000	9
    1	1	MPC_XY_VEL_P_ACC	3.000000000000000000	9
    1	1	MPC_YAWRAUTO_MAX	45.000000000000000000	9
    1	1	MPC_YAW_EXPO	0.300000011920928955	9
    1	1	MPC_YAW_MODE	0	6
    1	1	MPC_Z_MAN_EXPO	0.100000001490116119	9
    1	1	MPC_Z_P	1.000000000000000000	9
    1	1	MPC_Z_VEL_ALL	-3.000000000000000000	9
    1	1	MPC_Z_VEL_D_ACC	0.000000000000000000	9
    1	1	MPC_Z_VEL_I_ACC	2.000000000000000000	9
    1	1	MPC_Z_VEL_MAX_DN	1.500000000000000000	9
    1	1	MPC_Z_VEL_MAX_UP	4.000000000000000000	9
    1	1	MPC_Z_VEL_P_ACC	8.000000000000000000	9
    1	1	MPC_Z_V_AUTO_DN	1.500000000000000000	9
    1	1	MPC_Z_V_AUTO_UP	3.000000000000000000	9
    1	1	NAV_ACC_RAD	2.000000000000000000	9
    1	1	NAV_DLL_ACT	0	6
    1	1	NAV_FORCE_VT	1	6
    1	1	NAV_FW_ALTL_RAD	5.000000000000000000	9
    1	1	NAV_FW_ALT_RAD	10.000000000000000000	9
    1	1	NAV_LOITER_RAD	80.000000000000000000	9
    1	1	NAV_MC_ALT_RAD	0.800000011920928955	9
    1	1	NAV_MIN_LTR_ALT	-1.000000000000000000	9
    1	1	NAV_RCL_ACT	2	6
    1	1	NAV_TRAFF_AVOID	1	6
    1	1	NAV_TRAFF_A_HOR	500.000000000000000000	9
    1	1	NAV_TRAFF_A_VER	500.000000000000000000	9
    1	1	NAV_TRAFF_COLL_T	60	6
    1	1	PLD_BTOUT	5.000000000000000000	9
    1	1	PLD_FAPPR_ALT	0.100000001490116119	9
    1	1	PLD_HACC_RAD	0.200000002980232239	9
    1	1	PLD_MAX_SRCH	3	6
    1	1	PLD_SRCH_ALT	10.000000000000000000	9
    1	1	PLD_SRCH_TOUT	10.000000000000000000	9
    1	1	RC10_DZ	0.000000000000000000	9
    1	1	RC10_MAX	2000.000000000000000000	9
    1	1	RC10_MIN	1000.000000000000000000	9
    1	1	RC10_REV	1.000000000000000000	9
    1	1	RC10_TRIM	1500.000000000000000000	9
    1	1	RC11_DZ	0.000000000000000000	9
    1	1	RC11_MAX	2000.000000000000000000	9
    1	1	RC11_MIN	1000.000000000000000000	9
    1	1	RC11_REV	1.000000000000000000	9
    1	1	RC11_TRIM	1500.000000000000000000	9
    1	1	RC12_DZ	0.000000000000000000	9
    1	1	RC12_MAX	2000.000000000000000000	9
    1	1	RC12_MIN	1000.000000000000000000	9
    1	1	RC12_REV	1.000000000000000000	9
    1	1	RC12_TRIM	1500.000000000000000000	9
    1	1	RC13_DZ	0.000000000000000000	9
    1	1	RC13_MAX	2000.000000000000000000	9
    1	1	RC13_MIN	1000.000000000000000000	9
    1	1	RC13_REV	1.000000000000000000	9
    1	1	RC13_TRIM	1500.000000000000000000	9
    1	1	RC14_DZ	0.000000000000000000	9
    1	1	RC14_MAX	2000.000000000000000000	9
    1	1	RC14_MIN	1000.000000000000000000	9
    1	1	RC14_REV	1.000000000000000000	9
    1	1	RC14_TRIM	1500.000000000000000000	9
    1	1	RC15_DZ	0.000000000000000000	9
    1	1	RC15_MAX	2000.000000000000000000	9
    1	1	RC15_MIN	1000.000000000000000000	9
    1	1	RC15_REV	1.000000000000000000	9
    1	1	RC15_TRIM	1500.000000000000000000	9
    1	1	RC16_DZ	0.000000000000000000	9
    1	1	RC16_MAX	2000.000000000000000000	9
    1	1	RC16_MIN	1000.000000000000000000	9
    1	1	RC16_REV	1.000000000000000000	9
    1	1	RC16_TRIM	1500.000000000000000000	9
    1	1	RC17_DZ	0.000000000000000000	9
    1	1	RC17_MAX	2000.000000000000000000	9
    1	1	RC17_MIN	1000.000000000000000000	9
    1	1	RC17_REV	1.000000000000000000	9
    1	1	RC17_TRIM	1500.000000000000000000	9
    1	1	RC18_DZ	0.000000000000000000	9
    1	1	RC18_MAX	2000.000000000000000000	9
    1	1	RC18_MIN	1000.000000000000000000	9
    1	1	RC18_REV	1.000000000000000000	9
    1	1	RC18_TRIM	1500.000000000000000000	9
    1	1	RC1_DZ	10.000000000000000000	9
    1	1	RC1_MAX	1897.000000000000000000	9
    1	1	RC1_MIN	1103.000000000000000000	9
    1	1	RC1_REV	-1.000000000000000000	9
    1	1	RC1_TRIM	1498.000000000000000000	9
    1	1	RC2_DZ	10.000000000000000000	9
    1	1	RC2_MAX	1897.000000000000000000	9
    1	1	RC2_MIN	1103.000000000000000000	9
    1	1	RC2_REV	1.000000000000000000	9
    1	1	RC2_TRIM	1502.000000000000000000	9
    1	1	RC3_DZ	10.000000000000000000	9
    1	1	RC3_MAX	1898.000000000000000000	9
    1	1	RC3_MIN	1102.000000000000000000	9
    1	1	RC3_REV	1.000000000000000000	9
    1	1	RC3_TRIM	1102.000000000000000000	9
    1	1	RC4_DZ	10.000000000000000000	9
    1	1	RC4_MAX	1897.000000000000000000	9
    1	1	RC4_MIN	1103.000000000000000000	9
    1	1	RC4_REV	-1.000000000000000000	9
    1	1	RC4_TRIM	1500.000000000000000000	9
    1	1	RC5_DZ	10.000000000000000000	9
    1	1	RC5_MAX	1898.000000000000000000	9
    1	1	RC5_MIN	1102.000000000000000000	9
    1	1	RC5_REV	1.000000000000000000	9
    1	1	RC5_TRIM	1500.000000000000000000	9
    1	1	RC6_DZ	10.000000000000000000	9
    1	1	RC6_MAX	1898.000000000000000000	9
    1	1	RC6_MIN	1102.000000000000000000	9
    1	1	RC6_REV	1.000000000000000000	9
    1	1	RC6_TRIM	1500.000000000000000000	9
    1	1	RC7_DZ	10.000000000000000000	9
    1	1	RC7_MAX	2000.000000000000000000	9
    1	1	RC7_MIN	1000.000000000000000000	9
    1	1	RC7_REV	1.000000000000000000	9
    1	1	RC7_TRIM	1500.000000000000000000	9
    1	1	RC8_DZ	10.000000000000000000	9
    1	1	RC8_MAX	2000.000000000000000000	9
    1	1	RC8_MIN	1000.000000000000000000	9
    1	1	RC8_REV	1.000000000000000000	9
    1	1	RC8_TRIM	1500.000000000000000000	9
    1	1	RC9_DZ	0.000000000000000000	9
    1	1	RC9_MAX	2000.000000000000000000	9
    1	1	RC9_MIN	1000.000000000000000000	9
    1	1	RC9_REV	1.000000000000000000	9
    1	1	RC9_TRIM	1500.000000000000000000	9
    1	1	RC_ARMSWITCH_TH	0.750000000000000000	9
    1	1	RC_CHAN_CNT	7	6
    1	1	RC_ENG_MOT_TH	0.750000000000000000	9
    1	1	RC_FAILS_THR	0	6
    1	1	RC_GEAR_TH	0.750000000000000000	9
    1	1	RC_KILLSWITCH_TH	0.750000000000000000	9
    1	1	RC_LOITER_TH	0.750000000000000000	9
    1	1	RC_MAP_ACRO_SW	0	6
    1	1	RC_MAP_ARM_SW	0	6
    1	1	RC_MAP_AUX1	0	6
    1	1	RC_MAP_AUX2	0	6
    1	1	RC_MAP_AUX3	0	6
    1	1	RC_MAP_AUX4	0	6
    1	1	RC_MAP_AUX5	0	6
    1	1	RC_MAP_AUX6	0	6
    1	1	RC_MAP_ENG_MOT	0	6
    1	1	RC_MAP_FAILSAFE	0	6
    1	1	RC_MAP_FLAPS	0	6
    1	1	RC_MAP_FLTMODE	6	6
    1	1	RC_MAP_FLTM_BTN	0	6
    1	1	RC_MAP_GEAR_SW	0	6
    1	1	RC_MAP_KILL_SW	5	6
    1	1	RC_MAP_LOITER_SW	0	6
    1	1	RC_MAP_MAN_SW	0	6
    1	1	RC_MAP_MODE_SW	5	6
    1	1	RC_MAP_OFFB_SW	0	6
    1	1	RC_MAP_PARAM1	0	6
    1	1	RC_MAP_PARAM2	0	6
    1	1	RC_MAP_PARAM3	0	6
    1	1	RC_MAP_PITCH	2	6
    1	1	RC_MAP_POSCTL_SW	0	6
    1	1	RC_MAP_RATT_SW	0	6
    1	1	RC_MAP_RETURN_SW	0	6
    1	1	RC_MAP_ROLL	1	6
    1	1	RC_MAP_STAB_SW	0	6
    1	1	RC_MAP_THROTTLE	3	6
    1	1	RC_MAP_TRANS_SW	0	6
    1	1	RC_MAP_YAW	4	6
    1	1	RC_OFFB_TH	0.750000000000000000	9
    1	1	RC_RETURN_TH	0.750000000000000000	9
    1	1	RC_TRANS_TH	0.750000000000000000	9
    1	1	RTL_CONE_ANG	45	6
    1	1	RTL_DESCEND_ALT	10.000000000000000000	9
    1	1	RTL_HDG_MD	0	6
    1	1	RTL_LAND_DELAY	0.000000000000000000	9
    1	1	RTL_LOITER_RAD	80.000000000000000000	9
    1	1	RTL_MIN_DIST	10.000000000000000000	9
    1	1	RTL_PLD_MD	0	6
    1	1	RTL_RETURN_ALT	30.000000000000000000	9
    1	1	RTL_TIME_FACTOR	1.100000023841857910	9
    1	1	RTL_TIME_MARGIN	100	6
    1	1	RTL_TYPE	0	6
    1	1	SDLOG_BOOT_BAT	0	6
    1	1	SDLOG_DIRS_MAX	0	6
    1	1	SDLOG_MISSION	0	6
    1	1	SDLOG_MODE	0	6
    1	1	SDLOG_PROFILE	129	6
    1	1	SDLOG_UTC_OFFSET	0	6
    1	1	SDLOG_UUID	1	6
    1	1	SENS_BARO_QNH	1013.250000000000000000	9
    1	1	SENS_BARO_RATE	20.000000000000000000	9
    1	1	SENS_BOARD_ROT	0	6
    1	1	SENS_BOARD_X_OFF	0.041955806314945221	9
    1	1	SENS_BOARD_Y_OFF	-1.713702201843261719	9
    1	1	SENS_BOARD_Z_OFF	0.000000000000000000	9
    1	1	SENS_DPRES_OFF	0.000000000000000000	9
    1	1	SENS_GPS_MASK	7	6
    1	1	SENS_GPS_PRIME	0	6
    1	1	SENS_GPS_TAU	10.000000000000000000	9
    1	1	SENS_IMU_AUTOCAL	0	6
    1	1	SENS_IMU_MODE	1	6
    1	1	SENS_MAG_AUTOCAL	0	6
    1	1	SENS_MAG_AUTOROT	0	6
    1	1	SENS_MAG_MODE	1	6
    1	1	SENS_MAG_RATE	15.000000000000000000	9
    1	1	SENS_MAG_SIDES	63	6
    1	1	SYS_AUTOCONFIG	0	6
    1	1	SYS_AUTOSTART	4001	6
    1	1	SYS_CAL_TDEL	24	6
    1	1	SYS_CAL_TMAX	10	6
    1	1	SYS_CAL_TMIN	5	6
    1	1	SYS_FAC_CAL_MODE	0	6
    1	1	SYS_FAILURE_EN	0	6
    1	1	SYS_HAS_BARO	1	6
    1	1	SYS_HAS_GPS	1	6
    1	1	SYS_HAS_MAG	1	6
    1	1	SYS_HAS_NUM_DIST	0	6
    1	1	SYS_HITL	0	6
    1	1	SYS_MC_EST_GROUP	2	6
    1	1	SYS_RGB_MAXBRT	1.000000000000000000	9
    1	1	SYS_STCK_EN	1	6
    1	1	SYS_VEHICLE_RESP	-0.400000005960464478	9
    1	1	THR_MDL_FAC	0.800000011920928955	9
    1	1	TRIG_MODE	0	6
    1	1	UAVCAN_ENABLE	0	6
    1	1	VOXLPM_SHUNT_BAT	0.000630000024102628	9
    1	1	VOXL_ESC_BAUD	2000000	6
    1	1	VOXL_ESC_CONFIG	1	6
    1	1	VOXL_ESC_FUNC1	103	6
    1	1	VOXL_ESC_FUNC2	102	6
    1	1	VOXL_ESC_FUNC3	104	6
    1	1	VOXL_ESC_FUNC4	101	6
    1	1	VOXL_ESC_MODE	0	6
    1	1	VOXL_ESC_PUB_BST	1	6
    1	1	VOXL_ESC_REV	0	6
    1	1	VOXL_ESC_RPM_MAX	7000	6
    1	1	VOXL_ESC_RPM_MIN	1000	6
    1	1	VOXL_ESC_SDIR1	0	6
    1	1	VOXL_ESC_SDIR2	0	6
    1	1	VOXL_ESC_SDIR3	0	6
    1	1	VOXL_ESC_SDIR4	0	6
    1	1	VOXL_ESC_T_COSP	0.990000009536743164	9
    1	1	VOXL_ESC_T_DEAD	20	6
    1	1	VOXL_ESC_T_EXPO	35	6
    1	1	VOXL_ESC_T_MINF	0.150000005960464478	9
    1	1	VOXL_ESC_T_OVER	0	6
    1	1	VOXL_ESC_T_PERC	90	6
    1	1	VOXL_ESC_T_WARN	0	6
    1	1	VOXL_ESC_VLOG	1	6
    1	1	VTO_LOITER_ALT	80.000000000000000000	9
    1	1	VT_B_DEC_MSS	2.000000000000000000	9
    1	1	WV_EN	0	6
    1	1	WV_GAIN	1.000000000000000000	9
    1	1	WV_ROLL_MIN	1.000000000000000000	9
    1	1	WV_YRATE_MAX	90.000000000000000000	9
    1	1	XRCE_DDS_DOM_ID	0	6
    1	1	XRCE_DDS_KEY	1	6
    Cai BillC Cai Bill
    @tom I used ./install.sh
    Cai BillC Cai Bill
    After a third Reboot and and run the tool again I have the esc working:
    voxl-esc setup_sentinel_v1
    enabling bridge
    bridge enabled
    [INFO] Setting CPU to performance mode
    [INFO] Scanning for ESC...
    [INFO] M0117-1 detected
    [INFO] has for most recent firmware: eb6fb500
    [INFO] Expected ESC firmware info:
    	Firmware: modalai_esc_firmware_m0117_1_v0_39_RC10_eb6fb500.bin
    	Firmware hash: eb6fb500
    [INFO] Number of ESCs with correct FW: 0
    [INFO] 0 of the ESCs do not have the current firmware
    [INFO] Uploading current ESC firmware...
    [GCC 8.4.0]
    Found voxl-esc tools bin version: 1.6
    INFO: Firmware file name : firmware/modalai_esc_firmware_m0117_1_v0_39_RC10_eb6fb500.bin
    INFO: Firmware file size : 23088 bytes
    VOXL Platform: M0054
    INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000
    INFO: ESC(s) detected: [0, 1, 2, 3]
    INFO: Sending reset command to ESC ID 0
    Updated baud rate to 230400
    INFO: Installing firmware to ESC ID 0 : firmware/modalai_esc_firmware_m0117_1_v0_39_RC10_eb6fb500.bin
    	Progress: 100% [##################################################]
    INFO: Firmware successfully updated for ESC id 0
    [GCC 8.4.0]
    INFO: ESC(s) detected: [1, 2, 3]
    INFO: Sending reset command to ESC ID 1
    INFO: Installing firmware to ESC ID 1 : firmware/modalai_esc_firmware_m0117_1_v0_39_RC10_eb6fb500.bin
    INFO: Firmware successfully updated for ESC id 1
    [GCC 8.4.0]
    INFO: ESC(s) detected: [0, 2, 3]
    INFO: Sending reset command to ESC ID 2
    INFO: Installing firmware to ESC ID 2 : firmware/modalai_esc_firmware_m0117_1_v0_39_RC10_eb6fb500.bin
    INFO: Firmware successfully updated for ESC id 2
    [GCC 8.4.0]
    INFO: ESC(s) detected: [0, 1, 3]
    INFO: Sending reset command to ESC ID 3
    INFO: Installing firmware to ESC ID 3 : firmware/modalai_esc_firmware_m0117_1_v0_39_RC10_eb6fb500.bin
    INFO: Firmware successfully updated for ESC id 3
    [INFO] Verifying firmware upload was succecssful...
    successfully flashed firmware to all 4 escs
    uploading params file ../voxl-esc-params/Sentinel_V1/Sentinel_V1.xml
    [GCC 8.4.0]
    INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000, protocol: firmware
    INFO: ESC Information:
    INFO: ---------------------
    	Board      : version 34: ModalAi 4-in-1 ESC (M0117-1)
    	UID        : 0x203034305743570C00290031
    	Firmware   : version   39, hash eb6fb500
    	Bootloader : version  183, hash 25317f42
    	UID        : 0x203034305743570C00290041
    	UID        : 0x203034305743570C0029003E
    	UID        : 0x203034305743570C0029002E
    successfully pinged ESCs
    [GCC 8.4.0]
    INFO: Params file name : ../voxl-esc-params/Sentinel_V1/Sentinel_V1.xml
    INFO: Params file size : 7561 bytes
    INFO: ESCs detected:
    ID: 0, SW: 39, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
    ID: 1, SW: 39, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
    ID: 2, SW: 39, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
    ID: 3, SW: 39, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
    INFO: Loading XML config file...
    INFO: Uploading params for ESC ID 255...
    -- board config
    -- id config
    -- uart config
    -- tune config
        DONE
    INFO: Resetting ESCs...
        DONE
    WARNING: Received 12 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
    disabling bridge
    bridge disabled
    Still have no idea why the first two time failed, I did apt update and upgrade between every reboot and I also give chmod 755 to /data/, maybe that helped?
    Cai BillC Cai Bill
    After reboot
    I got the following error:
    Received standard error event SNS_STD_ERROR_NOT_SUPPORTED
    Connection error: connection reset
    Couldn't configure flight_controller sensor
    ERROR:   fc_sensor_initialize failed
    ERROR:   Failed to initialize slpi
    ERROR:   Encountered error while initializing bus 12
    ERROR:   voxl_uart_flush: Bus '12' is not initialized
    ERROR:   voxl_uart_write: Bus '12' is not initialized
    ERROR:   voxl_uart_read_bytes: Bus '12' is not initialized
    ERROR:   voxl_uart_close: Bus '12' is not initialized
    Cai BillC Cai Bill
    @Alex-Kushleyev
    I have upgrade the SDK1.3 and got the following error for esc:
    voxl2:/$ voxl-esc setup_sentinel_v1
    enabling bridge
    bridge enabled
    terminate called after throwing an instance of 'qmi_error'
      what():  qmi_client_send_msg_sync() failed, (client_id=)0, result=0: qmi service error (-2)
    [ERROR] Unknown board detected:
    disabling bridge
    bridge disabled
    EXITING VOXL-ESC WITH ERROR
    Any clue on what may be the case?
    Cai BillC Cai Bill
    @Alex-Kushleyev
    I have the same issue, should I order a new esc? When I run the voxl-esc scan on the voxl2, it is trying to find esc under /dev/slpi-uart-2, which I went and checked under /dev/, and there is such port shown up.
    The ESC does boot up with the sound, but I think the serial port maybe damaged.
    Scan Report:
    voxl-esc
    Starting Wizard
    What do you want to do?
    1) scan              3) spin              5) upload_params
    2) detect            4) upgrade_firmware
    #? 1
    enabling bridge
    bridge enabled
    [GCC 8.4.0]
    Found voxl-esc tools bin version: 1.2
    Detected VOXL2 M0054 or M0104!
    Found previous connection information in .voxl_esc_cache ..
    Prioritizing /dev/slpi-uart-2 @ 57600
    INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 57600
    Sending library name request: libslpi_uart_bridge_slpi.so
    Received standard error event 2
    Error calling voxl_uart_init
    INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 250000
    INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 921600
    INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 230400
    INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 115200
    INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 38400
    Updated baud rate to 38400
    /usr/bin/voxl-esc: line 131:  8107 Segmentation fault      python3 voxl-esc-scan.py
    FAILED to ping ESCs
    disabling bridge
    bridge disabled
    DONE
    ls /dev/slpi-uart-*
    ls: cannot access '/dev/slpi-uart-*': No such file or directory
  • voxl-configure-mpa failled on voxl-esc step
    Cai BillC Cai Bill
    @tom Hi Tom,
    I'm still unable to figure out what happen to the ESC, I can only suspected the firmware or the wiring. Do you guys offer mailed in repair?
    Cai BillC Cai Bill
    voxl2:~$ px4-qshell modalai_esc
    INFO  [qshell] Send cmd: 'modalai_esc'
    ERROR [uORB] Error Sending [qshell_req] topic data over comm_channel
    ERROR [qshell] command timed out
    ERROR [qshell] Command failed
    voxl2:~$ px4-listener esc_status
    never published
    I also tried px4-qshell modalai_esc and px4-listener esc_status, Both of them failed
    Cai BillC Cai Bill
    @tom
    When I power on the drone, the ESC does light up blue and flash for a bit, then it turned off. The drone makes boot on noise. I check the wiring, all joint are connected to the broad.
    Cai BillC Cai Bill
    @tom Yes, It still fail:
    Here is the log:
    $voxl-esc setup_sentinel_v1
    enabling bridge
    detected voxl-px4 is enabled
    detected voxl-px4 is running, stopping it now
    bridge enabled
    disabling bridge
    re-enabling voxl-px4
    Created symlink /etc/systemd/system/multi-user.target.wants/voxl-px4.service → /etc/systemd/system/voxl-px4.service.
    restarting voxl-px4
    bridge disabled
    Cai BillC Cai Bill
    I was trying to get the drone flying again, so I tried the voxl-configure-mpa to reset all service. But It failed on voxl-esc setup_sentinel_v. Should I be worried? How should I fix this problem.
    Log shown bellow:
    executing: voxl-esc setup_sentinel_v1
    enabling bridge
    bridge enabled
    disabling bridge
    restarting voxl-px4
    bridge disabled
    FAILED TO EXECUTE: voxl-esc setup_sentinel_v1
    executing: voxl-configure-px4 sentinel_v1
    wiping old config file
    enabling  voxl-px4 systemd service
    Done configuring voxl-px4
    Success!
    executing: voxl-configure-px4-params -np MRB-D0006
    [INFO] Voxl-px4 service found and active.
    [INFO] Loading the following param files: platforms/Sentinel_V1.params, EKF2_helpers/outdoor_gps_baro.params.
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/platforms/Sentinel_V1.params
    [INFO] Scanning currently loaded parameters...
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/EKF2_helpers/outdoor_gps_baro.params
    [INFO] Loading file: /data/px4/param/parameters_gyro.cal
    [INFO] Trimming duplicate parameters...
    [INFO] Loading file: /data/px4/param/parameters_acc.cal
    [INFO] Loading file: /data/px4/param/parameters_level.cal
    [INFO] Loading file: /data/px4/param/parameters_rc.cal
    [INFO] Done configuring for platform MRB-D0006
    Success!
    checking /data/modalai/voxl-imu-server.cal
    checking /data/px4/param/parameters_mag.cal
             FAILED TO EXECUTE the following steps:
          Encountered Problems Configuring MPA Services :-/
            Some Services may not start up on next reboot
    Calibration File Status:
    Missing /data/modalai/voxl-imu-server.cal
    Present /data/modalai/opencv_tracking_intrinsics.yml
    Present /data/modalai/opencv_stereo_front_intrinsics.yml
    Present /data/modalai/opencv_stereo_front_extrinsics.yml
    Present /data/modalai/opencv_stereo_rear_intrinsics.yml
    Present /data/modalai/opencv_stereo_rear_extrinsics.yml
    Present /data/px4/param/parameters_gyro.cal
    Present /data/px4/param/parameters_acc.cal
    Missing /data/px4/param/parameters_mag.cal
    Present /data/px4/param/parameters_level.cal
    Detected Missing Calibration Files
    please run the required cals
    https://docs.modalai.com/calibration/
                    PLEASE POWER CYCLE YOUR VOXL
  • Voxl2 Mavros install problem:
    Cai BillC Cai Bill
    Hi I want to use mavros on the sentinel drone, but when I follow this documentand tried:
    apt install -f ros-melodic-mavros ros-melodic-mavros-extras ros-melodic-control-toolbox
    I got this error:
    Reading package lists... Done
    Building dependency tree
    Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    The following information may help to resolve the situation:
    The following packages have unmet dependencies:
     ros-melodic-mavros : Depends: libeigen3-dev but it is not going to be installed
                          Depends: ros-melodic-eigen-conversions but it is not going to be installed
                          Depends: ros-melodic-tf2-eigen but it is not going to be installed
     ros-melodic-mavros-extras : Depends: ros-melodic-tf2-eigen but it is not going to be installed
    E: Unable to correct problems, you have held broken packages.
    I did got ros melodic running on the drone and I checked the voxl-configure-pkg-manage, and update afterward. But I'm still not able to get mavros installed.
    voxl-configure-pkg-manager
    Which repository do you want to use?
    stable  - recommended for most users
    staging - packages under testing for next sdk release
    sdk-X.Y - Specific SDK release
    dev     - recommended for ModalAI development team only
    1) dev	    3) sdk-0.7	5) sdk-0.9  7) staging
    2) sdk-0.6  4) sdk-0.8	6) sdk-1.0
    #? 6
    Using repo: sdk-1.0
    Any recommendation?
  • Camera Calibration Needed
    Cai BillC Cai Bill
    @tom Thank you I have the 120 second limits on reply XD, sorry for the delay
    Development Drones rb5
    Cai BillC Cai Bill
    @tom also Missing /data/modalai/voxl-imu-server.cal
    Cai BillC Cai Bill
    @tom Hi tom
    Thank you, I got those files, Do you happen to have /data/px4/param/parameters_mag.cal too? I'm still missing this one.
    Cai BillC Cai Bill
    Re: Camera Calibration
    @modaltb
    We also lost all of our calibration, could you send over the backup?
    SN:
    M2100000J5W
    Thank you so much.
