A
arvind_g3aero
@arvind_g3aero
  • voxl-mavcam-manager in differnt versions
    A arvind_g3aero
    Hi Dev Team ,
    Any update regarding snapshots through voxl-mavcam-manager in 1.6.2 SDK on VOXL2 board.
    Please suggest us which SDK to use for snapshot usage on VOXL2 .
    S.Arvind
    A arvind_g3aero
    Hi,Apoorv Thapliyal,
    Thanks for the suggestions made.
    We have tried 1.4.5 SDK on Voxl2 board and we are able to get snapshot in both QGC and also in /data/snapshots folder in the board .If we try to change resolution of snapshot in voxl-camera-server ,it is applied to resolution of snapshot saved in /data/snapshot folder in voxl2 board.
    A arvind_g3aero
    Hi Zach,
    Thanks for your quick reply.
    We are having total 3 cameras,hires imx214,tracking ov7251and usb camera lepton.
    SDK we are using is 1.6.2
    voxl2 (M0054):/$ voxl-camera-server -d 2
    detected system image 1.8.6
    using new imx214 defaults
    configuration for 2 cameras:
    cam #0
    type: ov7251
    bayer_type: 0
    enabled: 1
    camera_id: 0
    camera_id_second: -1
    fps: 30
    en_rotate: 1
    en_rotate2: 0
    en_preview:          1
    en_raw_preview:      1
    preview_width:       640
    preview_height:      480
    en_misp:             0
    misp_width:          -1
    misp_height:         -1
    en_small_video:      0
    small_video_width:   -1
    small_video_height:  -1
    en_large_video:      0
    large_video_width:   -1
    large_video_height:  -1
    en_snapshot:         0
    snap_width:          -1
    snap_height:         -1
    exif_focal_length:   0.000000
    exif_focal_len_35mm_format:0
    exif_fnumber:        0.000000
    ae_mode:             lme_msv
    msv_exposure_min_us: 20
    msv_exposure_max_us: 33000
    gain_min           : 54
    gain_max           : 8000
    standby_enabled:     0
    decimator:           1
    independent_exposure:0
    cam #1
    type: imx214
    bayer_type: 2
    enabled: 1
    camera_id: 1
    fps: 15
    en_rotate: 0
    en_rotate2: 0
    en_preview:          0
    en_raw_preview:      0
    preview_width:       1920
    preview_height:      1080
    en_misp:             0
    misp_width:          -1
    misp_height:         -1
    en_small_video:      1
    small_video_width:   640
    small_video_height:  480
    en_large_video:      0
    large_video_width:   4208
    large_video_height:  3120
    en_snapshot:         1
    snap_width:          4208
    snap_height:         3120
    ae_mode:             isp
    gain_min           : 54
    gain_max           : 8000
    standby_enabled:     0
    decimator:           1
    fsync_en: 0
    fsync_gpio: 109
    connected to mavlink pipe
    Connected to cpu-monitor
    Starting Camera: tracking (id #0)
    setting ov7251 BLC register for cam id 0
    Starting Camera: hires (id #1)
    Estimated imu dt = 0.000976s
    ------ voxl-camera-server: Started 2 of 2 cameras
    Camera: hires taking snapshot (destination: /data/snapshots/hires-2026-08-04_06:55:02.474.jpg)
    ERROR: bufferGetBufferInfo wan't able to successfully find the requested buffer
    Segmentation fault:
    Fault thread: cam1-result(tid: 20257)
    Segmentation fault
    voxl-mavcam-manager
    Parameters as loaded from config file:
    input #0:
    snapshot_pipe_name: hires_snapshot
    video_record_pipe_name: hires_small_encoded
    default_uri: rtsp://192.168.168.156:8900/live
    enable_auto_ip: 1
    mavlink_sys_id: 1
    input #1:
    snapshot_pipe_name: uvc
    video_record_pipe_name: uvc
    default_uri: rtsp://192.168.168.156:8901/live
    enable_auto_ip: 1
    mavlink_sys_id: 1
    existing instance of voxl-mavcam-manager found, attempting to stop it
    COMPID: 100
    Mavlink server Connected
    COMPID: 100
    Error trying to send control command to pipe ch2 /run/mpa/mavlink_to_gcs/, not connected
    auto-detected RTSP URI: rtsp://192.168.168.156:8900/live
    Sending stream info to gcs: rtsp://192.168.168.156:8900/live
    auto-detected RTSP URI: rtsp://192.168.168.156:8901/live
    Sending stream info to gcs: rtsp://192.168.168.156:8901/live
    Unable to find valid pipe that accepts control commands at: uvc
    Successfully sent command to /run/mpa/hires_snapshot/control
    Sending camera_settings with mode VIDEO to gcs
    Sending camera_settings with mode IMAGE to gcs
    root@arvind-Victus-by-HP-Gaming-Laptop-15-fa0xxx:/home/arvind# adb shell
    system-image: 1.8.06-M0054-14.1a-perf
    kernel: #1 SMP PREEMPT Wed Oct 22 03:21:50 UTC 2025 4.19.125
    hw platform: M0054
    mach.var: 1.0.0
    SKU: MCCA-M0054-CC-T0-M0-X0
    voxl-suite: 1.6.2
    current IP: usb0: 192.168.168.156
    voxl2 (M0054):/$
    voxl2 (M0054):/$ cat /home/root/voxl-thermal-streamer_bkp1.sh
    #!/bin/bash
    sleep 3
    echo "uvc camera feed on 192.168.168.156:8901 "
    voxl-streamer --standalone --port 8901 -i uvc -b 200000
    We have 2 camera streams one with voxl-streamer----hires_small_encoded on 8900 port
    other with voxl-streamer standalone with one service ---uvc on 8901 port
    Through mavcam manager (0.6.0) we are able to switch the camera streams in QGC .But while taking snapshot,snapshot is saving in GCS QGC with resolution of GCS Display and snapshot not saving in /data/snapshots folder
    while we are trying with command line also snapshot is not saving meanwhile camera server crashing:
    voxl-send-command hires_snapshot snapshot
    voxl2 (M0054):/data/snapshots$ ls -ltr
    total 0
    voxl-camera-server crashed:
    Camera: hires taking snapshot (destination: /data/snapshots/hires-2026-08-04_07:09:12.701.jpg)
    Segmentation fault:
    Fault thread: cam1-result(tid: 16326)
    Segmentation fault
    voxl2 (M0054):/$
    While we are trying in old sdk 1.3.5 and 1.4.0 snapshot is saving in /data/snapshots folder but 2 cmaera switching is not happening through mavcam manager
    Our requirement is to switch two streams and also screenshot need to be saved in /data/snapshots folder
    Please suggest us which SDK to use for both purpose(camera switching and also snapshot) ,and what is that buffer issue in 1.6.2 SDK
    Thank you
    A arvind_g3aero
    Hi team,
    We are working on voxl2 board.In mavcam manager we have encountered issue .With 1.3.5 and 1.4.0 sdk multiple cameras switching through mavcam manager is not happening,working for one camera and snapshot is saved in GCS QGC and also in /data/snapshots folder.
    With 1.6.2 sdk multiple cameras switching through mavcam manager is happening but while we are trying for snapshot voxl-camera serveris disconnecting and connecting again.We have verified by running voxl-camera-server -d in terminal it is giving no buffer space available .If we disable snapshot in voxl-camera-server then it is not crashing and no buffer space error is also not seen .
    Our requirement is we have two camera switching and snapshot is also required.Please suggest which sdk to use
