Arjun JainA
Arjun Jain
@Arjun Jain
  • The drone xyz axis visualization goes away
    Arjun JainA Arjun Jain
    The drone visualized by the 3-axis in the 3D map view goes away intermittently. However the dot in 2D can be still clearly seen and moving. If I restart voxl-portal, I can again see the drone in 3D. Any idea how to fix it?
    On the related note, where are the html files of the portal located in the docker/voxl board? Suppose I want to change the color etc., which html/css files should I change?
    Many thanks. Warm regards,
    Arjun
  • Uable to start camera server on voxl 2
    @Alex-Gardner hi alex! How to go back to the default configuration? We didn’t change actually, not sure why the configuration is looking for different cameras. Many thanks!
  • voxl-mapper: error while loading shared libraries
    @Anubhav smells like a version mismatch problem. Can you also run Voxl-mapper with -d for more info?
  • voxl2 unbrick
    @Nishkala please write a more meaningful question so that people on this forum can help you. What are the symptoms? Why do you think it is bricked? What all did you try?
  • Exporting map from voxl-mapper
    @darwin-keem you can save the map from the web portal. It gets saved on the board at a specific location. You can then copy it and render it in your software.
  • Issue running tmux or tmux scripts on VOXL2
    @Jeff-Delaune try screen
  • VIO uses only tracking camera and no ToF data on voxlcam?
    @Matthew-Booker thank you! 🙏
    @Alex-Gardner anyone? Thanks in advance for your answer.
    Hi all! I wanted to confirm if the following was true:
    1. The ToF data is used for collision avoidance feature
    2. The downward facing cameras a used for apriltag localization and for tracking features on the ground for VIO.
    If true, why are we not using also the ToF for the localization and VIO? Another related question is can we have vertical apriltags (like on walls) and also re-localize based on them?
    Many thanks in advance.
  • Cannot run voxl-mapper: ERROR fetching tf from tf ringbuffer there wasn't sufficient data in the buffer
    Hi @ahmed-mustahid : I am no expert, but I too get that warning sometimes but the voxl-mapper still works and generates a valid scene. I thought it is just when the camera is blocked or it doesn't have enough features or something like that it displays that warning. I am also curious to learn from the voxl team what this warning means.
  • modifying voxl-mapper
    @Matthew-Booker However, when I try to save the mesh from the portal, in my compiled version, I get this symbol not found error. Any ideas why it can not find this function and how to fix it? Many thanks in advance.
    skipped 2 point clouds
    WARNING bytes left in tof point cloud pipe
    skipped 3 point clouds
    skipped 1 point clouds
    voxl-mapper: symbol lookup error: voxl-mapper: undefined symbol: _ZNK7voxblox5LayerINS_9TsdfVoxelEE10saveToFileESsb
    Fault address: 0x7f60053888
    Access to this address is not allowed.
    Segmentation fault
    @Matthew-Booker Thanks a lot!
    What works for me is:
    voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./install_build_deps.sh apq8096 sdk-0.8
    voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./build.sh apq8096
    voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./make_package.sh ipk
    scp voxl-mapper_0.0.7.ipk root@10.0.1.10:
    On voxl 1 board, I added arm64 7 to /etc/opkg/arch.conf
    voxl:~$ voxl-configure-opkg dev
    opkg install --force-reinstall --force-downgrade --force-depends --force-overwrite voxl-mapper_0.0.7.ipk
    Then everything seems to work so far!
