A
Ariel Saez
@Ariel Saez
  • How to make a clean Docker installation on Voxl?
    A Ariel Saez
    @Eric-Katzfey I try, and show me this error:
  • Qgroundcontrol don't Connect
    A Ariel Saez
    @Eric-Katzfey all the messages I got in QgroundControl are these:
    In the other side, the configuration and, services in the voxl are these:
    Is posible, that the flight core 2 has been damage? or someting, or it's a configuration problem?
    because it's am worried when I try the usb connection with the same problem.
    A Ariel Saez
    @Eric-Katzfey I try the usb cable directly into the flight core v2 and even with usb conection have the same error
    A Ariel Saez
    @Eric-Katzfey Hello, yes I use the voxl-wifi -f comand to configurate the wifi.
    A Ariel Saez
    @Eric-Katzfey I Still can't fix the error, I try installing a older version of sdk, but didn't fix it, also I check the console on the QGroundControl and it shows "Error writing to QHostAddress("192.168.8.1") "14550"
    A Ariel Saez
    @Eric-Katzfey I try the factory_reset and disable config for both mavcam and voxl-streamer and the error is still happening
    A Ariel Saez
    @Eric-Katzfey Hi, the same error...:
    voxl:~$ voxl-docker -i roskinetic-xenial:v1.0
    Error response from daemon: Cannot start container d2a8c94cb91281035cfac16fc5a1df7abf2a031135f3583561197443fed57337: network host not found
    A Ariel Saez
    Hello, I am having several problems with Docker and daemon, I try to use Roskinetic image on the voxl 1 in my Seecker Drone but it gives me many errors and it does not start, when using the voxl-configure-docker-support tool the docker-daemon service start but the docker-autorun servico apears to be enable but not running:
    Scanning services...
    /usr/bin/voxl-inspect-services: line 131: printf: %: invalid number
    docker-autorun | Enabled | Not Running |
    docker-daemon | Enabled | Running | 0.0''
    modallink-relink | Disabled | Not Running |
    voxl-camera-server | Enabled | Running | 1.8%
    voxl-cpu-monitor | Enabled | Running | 0.0%
    voxl-dfs-server | Disabled | Not Running |
    voxl-imu-server | Enabled | Running | 0.0%
    voxl-lepton-server | Disabled | Not Running |
    voxl-mavcam-manager | Disabled | Not Running |
    voxl-mavlink-server | Enabled | Running | 5.5%
    voxl-modem | Disabled | Not Running |
    voxl-portal | Enabled | Running | 0.0%
    voxl-qvio-server | Enabled | Running | 11.1%
    voxl-rangefinder-server | Disabled | Not Running |
    voxl-remote-id | Disabled | Not Running |
    voxl-streamer | Disabled | Not Running |
    voxl-tag-detector | Disabled | Not Running |
    voxl-tflite-server | Disabled | Not Running |
    voxl-time-sync | Disabled | Not Running |
    voxl-uvc-server | Disabled | Not Running |
    voxl-vision-hub | Enabled | Running | 1.8%
    voxl-wait-for-fs | Enabled | Completed |
    I check the docker images and the RosKinetic apears to be uploaded:
    voxl:~$ docker images
    REPOSITORY TAG IMAGE ID CREATED VIRTUAL SIZE
    roskinetic-xenial v1.0 0e12749bdc00 4 years ago 1.633 GB
    hello-image latest efc161607398 7 years ago 2.088 kB
    but when I run docker with the roskinetic image following the How to run Ubuntu on VOXL using Docker, I run the roskinetic image and I get the following error:
    docker run -it --rm --privileged --net=host --name roskinetic -v /home/root:/root/yoctohome/:rw -w /root/ roskinetic-xenial:v1.0 /bin/bash
    Error response from daemon: Cannot start container 1ce02a3225dc996fd565fc50d71da2064552232924e3444c5a81d7b304292626: network host not found
    and trying to run the docker anyway I got the same error. " network host not found",
    Unable to find image 'roskinetic:latest' locally
    Pulling repository docker.io/library/roskinetic
    Error while pulling image: Get https://index.docker.io/v1/repositories/library/roskinetic/images: dial tcp: lookup index.docker.io on 8.8.8.8:53: dial udp 8.8.8.8:53: connect: network is unreachable
    I try to fix the problem but I can find a solution, there's any way to fully uninstall Docker on the voxl and make a clean installation to fix my problem?
    A Ariel Saez
    was configuring the voxl-mavcam-server service when enabling it together with voxl-streamer on my Drone Seeker MRB-D0003-2-V2-C7, Qgroundcontrol stopped working, started connecting and disconnecting where it finally sent the following error message
    "Vehicle 1 did not respond to the parameter request. This will cause QGroundControl to be unable to display its full user interface."
  • How to configure RC control on the voxl?
    A Ariel Saez
    @Ariel-Saez I already fix the problem, my seeker has the wrong sku version, more details with the fix, see my original topic: https://forum.modalai.com/topic/3286/qgroundcontrol-don-t-detect-transmitter
  • QgroundControl don't detect transmitter
    A Ariel Saez
    @Ariel-Saez I already fix the problem, any case someone have the same problem, you need to update the SDK with the proper SKU version, in my case the /data/modalai/sku.txt show me "MRB-D0003-1-V1-C7", and looking my modalai's bill, show I buy the MRB-D0003-2-V2-C7. Next I change my sku.txt with the right code: MRB-D0003-2-V2-C7, then I update my voxl and fix everything.
    update SDK documentation: https://docs.modalai.com/flash-system-image/
    SKU config and documentation: https://docs.modalai.com/voxl-configure-mpa/
    Development Drones seeker
    A Ariel Saez
    I'm having problems with the RC controller on my seeker drone, I got the MRB-D0003-B1-C7-D2-T1-K0 and I buy the Spektrum DXS, the receiver and the transmitter bind no problem, but the flight control seem to not receive the transmitter. Any chance to configure this inside the voxl-vision-hub? or other voxl configuration file?, more detais of my problem it's in this topic
    A Ariel Saez
    Hi, I'm working with the seeker dev Drone and I buy the Spektrum DSX 7-Channels transmiter to fly in manual mode. I follow the instructions to bind the transmitter to the DSMX Remote Receiver. The bind was complete, because I se the receiver turning on with the transmiter power button but When I go to Qgroundcontrol to calibrate the transmiter I keep getting a message to turn on the transmitter while I have the transmitter on.
    Anyone Knows why is this happening?
    The Transmitter: https://www.spektrumrc.com/product/dxs-transmitter-only/SPMR1010.html
    The Receiver: https://www.spektrumrc.com/product/dsmx-remote-receiver/SPM9745.html
    ![alt text](WhatsApp Image 2024-04-03 at 9.20.24 AM(2).jpeg WhatsApp Image 2024-04-03 at 9.20.24 AM(1).jpeg WhatsApp Image 2024-04-03 at 9.20.24 AM.jpeg Screenshot from 2024-04-03 09-17-20.png
  • How to Get the imei code from modem 4g tle
    A Ariel Saez
    Hi, I'm develoving a project with the seeker drone and I'm not from USA, and I need do to homologate the modem 4g lte to fully use it in my country, but for that I need the imei code.
    How can I get that code?
