Ariel PomerA
Ariel Pomer
@Ariel Pomer
  • TOF camera params
    Ariel PomerA Ariel Pomer
    @Ariel-Pomer
    i forgot to mention i am using voxl-camera-server sdk-0.9
  • TOF camera params
    hey 🙂
    regarding hal3_camera_mgr.cpp
    i see that in QRB5165 version, you initialize a TOFInterface object that can extract LensParameters by using royaleCamera->getLensParameters inside the TOFBridge::setup() function.
    how can we do the same with the APQ8096 version?
    i tried looking for the same function at the TOFCreateInterface() function which creates the interface but i could not find the file that defines TOFCreateInterface.
    extra : maybe you could tell me that lens params of the tof camera sold by you? (VOXL Time of Flight (TOF) Depth Sensor)
    thanks 🙂
  • voxl tof frame rate
    hey,
    i am trying to change to tof camera framte rate by modifying the "frame_rate" field in the "voxl-camera-server.conf" file.
    5 and 15 fps works, but when trying 15 or 30 for example, the camera server won't start.
    i saw this forum thread https://forum.modalai.com/topic/137/cannot-change-tof-framerate/2
    but the repository mentioned there seems outdated.
    any advise how to change the frame-rate?
    thanks
  • qvio-server :
    hey,
    i tried using qvio-server on a HIRES camera by changing qvio and camera config files.
    this is the image i get when pointing for a random place
    (i cut out the image itself which i think is not so important).
    XYZ coordinates do not change when moving the platform and points on the image keep resetting
    terminal shows next error when starting voxl-qvio-server :
    what could be the problem?
    thanks 🙂
    ariel
