A
alarm_hq
@alarm_hq
  • Stabilized Flight Mode
    A alarm_hq
    @tom After playing around with CP_DIST, it seems any value > 0 causes position mode to no longer want to allow x/y translation. From what I understand, any value < 0 disables object avoidance. Is this true?
    As far as I'm aware, my settings should be in parity with Modal provided guidance in regards to seeker setup with additional configurations overridden to support voxl-mapper.
    Thanks for the stabilized advice @mohammednaveed, I've gone as far to replace manual mode with this setting.
    A alarm_hq
    How can I enable a stabilized flight mode / configure the RC controller to do so?
    Currently I have manual / position / off-board.
    In positional mode, the drone will stabilize, but only allows changes to the z-position.
    Colloquially speaking, position mode previously allowed for x/y translation, but I don't have any proof of that nor could I explain what would have possibly changed from that point in time.
  • TOF SLAM
    A alarm_hq
    @Matt-Turi thanks so much!
  • TOF SLAM
    A alarm_hq
    Thanks Matt, I think these are all great suggestions and I look forward to trying it out.
    Good luck with the flycontrols or similar change!
  • TOF SLAM
    A alarm_hq
    I have generated a path, though was unable to have the drone take off. Does the drone have to be in a hover state, or can it take off with the plan?
    I don't have a specific preference for the camera control model, other than it's easier to use with a laptop trackpad. If i had to pick one, I'd say flycontrols.
     * This file contains configuration that's specific to voxl-mapper.
    	"robot_radius":	0.2,
    	"point_skip":	7,
    	"voxel_size":	0.20000000298023224,
    	"voxels_per_side":	16,
    	"esdf_save_path":	"/data/voxl_mapper/esdf_map",
    	"tsdf_save_path":	"/data/voxl_mapper/tsdf_map",
    	"mesh_save_path":	"/data/voxl_mapper/mesh.ply",
    	"esdf_max_distance":	4,
    	"esdf_min_distance":	0.20000000298023224,
    	"esdf_default_distance":	2,
    	"esdf_inner_sphere_radius":	0.20000000298023224,
    	"esdf_outer_sphere_radius":	0.600000023841858,
    	"rrt_min_distance":	0.2,
    	"rrt_max_runtime_nanoseconds":	-1,
    	"rrt_use_first_solution":	true,
    	"rrt_treat_unknown_as_occupied":	true,
    	"rrt_send_tree":	false,
    	"loco_num_segments":	12,
    	"loco_derivative_to_optimize":	3,
    	"loco_poly_degree":	12,
    	"loco_smoothness_cost_weight":	0.3,
    	"loco_collision_cost_weight":	12,
    	"loco_waypoint_cost_weight":	0.025,
    	"loco_min_collision_sampling_dist":	0.2,
    	"loco_add_waypoints":	true,
    	"loco_scale_time":	true,
    	"loco_split_at_collisions":	true,
    	"loco_resample_trajectory":	true,
    	"loco_verbose":	false
    /etc/modalai/voxl-mapper.conf
  • TOF SLAM
    A alarm_hq
    I can sometimes get the paths to load in the 3D view. At least, i got working the first time, but was still unable to fly. Does the drone need to be actively flying with off-board (holding position) enabled, or is it sufficient to be powered on with off-board enabled at the controller?
    Subsequent attempts had similar behaviour to what i had before with no indication at the UI/terminal of why the path had not loaded. I need to step away from this for at least the weekend, but I'm definitely stuck.
    To be very verbose, my process is to turn the drone on, wait about a minute, then hand carry the drone around the space (about 30 degrees yawed towards walls) doing two passes, one clockwise, one counter clockwise. Sometimes i'll skip the second pass if the 2d map looks good enough. I'll land back at ~0,0,0 then pick a point in the ui, once satisfied with the choice, press the go! button.
    I'm thinking the issue may be from selecting a new point after the first one was inadequate. This might be anecdotal, but it feels like any point after the first leads to issues.
    Here is my view after a path was not generated after planning to a point (top right). Drone slightly visible in the bottom right.
    Unrelated, and perhaps should be another topic, is there a way to view the 3d/2d maps with a different camera control model? IE not the default trackball?
  • TOF SLAM
    A alarm_hq
    I'm still having issues generating the path, though now voxl-mapper is not giving me the success messages as before.
    Additionally, I've included output from voxl-mapper, voxl-inspect-cpu and voxl-inspect-services.
    As of now, using the seeker, I've configured voxl-vision-px4.conf and voxl-mapper.conf as specified in the voxl-mapper dev branch readme. Using the voxl-portal I was able to generate this map:
    When clicking on 'Plan To a Point', voxl-mapper outputs: Client requested plan to location. I see a green 'Go!' button appear, but no paths. Clicking the button seems to cause the ui to hang briefly, and then return to the original menu items with no effect on the drone.
    voxl-mapper simply states Switching to 3D checks.
    Any guidance would be greatly appreciated.
  • TOF SLAM
    A alarm_hq
    I was using a plot branch of voxl-portal and what I believe to be the dev of mapper.
    However, I'll just recompile and reinstall both.
  • TOF SLAM
    A alarm_hq
     Service Name        |  Enabled  |   Running   |  CPU Usage
     docker-autorun      | Disabled  | Not Running | Not Running
     docker-daemon       | Disabled  | Not Running | Not Running
     modallink-relink    | Disabled  | Not Running | Not Running
     voxl-camera-server  |  Enabled  |   Running   |     6.1
     voxl-cpu-monitor    |  Enabled  |   Running   |     0.0
     voxl-dfs-server     | Disabled  | Not Running | Not Running
     voxl-imu-server     |  Enabled  |   Running   |     0.0
     voxl-modem          | Disabled  | Not Running | Not Running
     voxl-portal         |  Enabled  |   Running   |     0.0
     voxl-qvio-server    |  Enabled  |   Running   |    11.9
     voxl-streamer       | Disabled  | Not Running | Not Running
     voxl-tag-detector   | Disabled  | Not Running | Not Running
     voxl-tflite-server  | Disabled  | Not Running | Not Running
     voxl-time-sync      | Disabled  | Not Running | Not Running
     voxl-vision-px4     |  Enabled  |   Running   |     4.0
     voxl-wait-for-fs    |  Enabled  |  Completed  |  Completed
    Current voxl-vision-px4.conf:
            "qgc_ip":       "192.168.8.84",
            "en_localhost_mavlink_udp":     true,
            "en_secondary_qgc":     false,
            "secondary_qgc_ip":     "192.168.1.29",
            "qgc_udp_port_number":  14550,
            "localhost_udp_port_number":    14551,
            "udp_mtu":      512,
            "en_vio":       true,
            "en_voa":       true,
            "en_send_vio_to_qgc":   true,
            "en_send_voa_to_qgc":   true,
            "en_set_clock_from_gps":        true,
            "en_force_onboard_mav1_mode":   true,
            "en_reset_px4_on_error":        true,
            "qvio_auto_reset_quality":      0.00050000002374872565,
            "horizon_cal_tolerance":        0.300000011920929,
            "voa_upper_bound_m":    1.25,
            "voa_lower_bound_m":    1.25,
            "en_adsb":      false,
            "adsb_uart_bus":        7,
            "adsb_uart_baudrate":   57600,
            "px4_uart_bus": 5,
            "px4_uart_baudrate":    921600,
            "offboard_mode":        "trajectory",
            "follow_tag_id":        0,
            "en_tag_fixed_frame":   false,
            "fixed_frame_filter_len":       5,
            "en_transform_mavlink_pos_setpoints_from_fixed_frame":  false
    Running on seeker drone
  • TOF SLAM
    A alarm_hq
    @Matt-Turi I've been beta-testing the mapper project this week and seem to be 95% of the way there.
    Mapping appears to go well, walls are reliably detected and the mesh looks good for flight. However, within the mapper I cannot seem to get a path to load.
    From the mesh view, I'm clicking plan to point, and selecting an arbitrary point within the map and press 'go'. From terminal (voxl-mapper -d), I see that it solves for the path (fairly quickly), attempts to do some smoothing and ultimately reports a Success message.
    However, I don't see the path load in the mapper, nor do I see any indication to proceed with a flight.
  • Invalid local position
    A alarm_hq
    I found the QGC
    EKF2_AID_MASK parameter settings above (configuring to 280: Vision position fusion, vision yaw fusion, vision velocity fusion) to allow the seeker to enter position and off-board modes.
    Prior to configuring, QGC was receiving VIO but was still unable to enter position mode as referenced here
    To make the forum search engine happy: seeker position mode rejected
  • Voxl-mapper instructions
    A alarm_hq
    I was able to compile, deploy and run the voxl-mapper tool.
    I've generated some 0-byte ply and related files /etc/voxl_mapper, and noticed that when viewing live in rviz seems to result in triggering timestamp too new.
    What would be an ideal mapping process? How should the drone be handled in order to keep the service alive?
  • Seeker replacement props
    A alarm_hq
    What model props came with the seeker kit?
    I made the mistake of throwing out the packaging they came in prior to purchasing back up props.
  • How to: Seeker ESC calibration
    A alarm_hq
    Awesome, that was the driver I had used. Thanks for clarifying!
    A alarm_hq
    And if I've already made the "mistake" of reflashing px4 firmware, is the closed loop RPM control affected?
    A alarm_hq
    I'm unsure how to calibrate the ESCs on the seeker.
    I can't use qgroundcontrol as the seeker doesn't have 5v input, non battery power input as documented here
    However, using the px4-esc-tool to calibrate the seeker's ESC, the prompts request your to remove J1007 from the VOXL Flight. This connector is not populated from the factory.
    Any advice? Should I just ignore it and move to the next step?
