Hi @alex-kushleyev ,
Thank you, the software slave-address change sounds great. If it works, we would prefer that approach, since all five cameras could then be standard M0166 units (easier spares and no warranty issue). A few follow-ups:
- Does the changed address persist across a camera server restart or a sensor reset, or only until reboot? (We noticed the OV7251 runtime address swap skips sensor resets for this reason.)
- Will the kernel change be included in an upcoming SDK / system image release, and does it work together with the fsin (sync) sensormodules?
- We will keep the pre-modified M0166 as a fallback. Please let us know the result of your test.
Regarding AR0144 vs IMX412, the reasons we chose AR0144 for all five visual cameras:
- Same-instant 360° capture: Our goal is to capture like a 360° camera, where every direction is captured at exactly the same moment. Global shutter plus hardware sync on all five cameras is the key requirement. With rolling shutter, each row is exposed at a different time, so motion causes skew and the frames from different cameras would not truly match.
- Stability over resolution: Reliably getting synchronized frames from all directions, quickly and without drops, matters more to us than image resolution. The 162° fisheye also gives five cameras enough overlap to cover 360°.
- Portable device: The system is meant to be portable (handheld), so weight matters, and hand motion makes rolling shutter artifacts more likely.
So our target configuration remains 5x AR0144 for 360° capture plus one thermal camera, as in our test request (Test A: Lepton 3.5, Test B: Boson+ 640). We will choose the thermal camera based on your test results, so it would be great if both variants could be covered in the test.
One more question: we may need color images. Is the color AR0144 variant (M0166-2) available, and would 5x color AR0144 with sync and CPU debayering at 1280x800 @ 30 fps be feasible on VOXL 2?
