김다연김
김다연
@김다연
  • M0187 Lepton Adapter Board – Purchase Inquiry and Delivery to South Korea
    김다연김 김다연
    Hardware: (board / drone / SKU, serial # if you have it): M0187 Lepton Adapter Board
    Software version: (paste the output of voxl-version)
    Configuration / services: (paste the output of voxl-inspect-services)
    What I am trying to do:
    I would like to purchase the M0187 Lepton Adapter Board. The website states that customers should contact the sales team to purchase this board.
    Could you please clarify the following?
    1. How can I contact the sales team and place an order?
    2. What is the maximum quantity I can purchase per order?
    3. What is the estimated lead time from placing an order to delivery in South Korea?
    4. Could you please provide the unit price of the M0187 board and the shipping cost to South Korea?
    If there is any additional information I should be aware of regarding the purchase or use of this board, please let me know.
    What actually happens: (error messages, behavior): This is a purchase inquiry.
    Steps to reproduce:
    Logs / pictures: (attach files; PX4 logs -> https://logs.px4.io)
  • M0022 PWM Breakout Board: 8-Channel Output Pinout
    김다연김 김다연
    Hardware: (board / drone / SKU, serial # if you have it): VOXL 2 IO (M0065) and M0022 PWM Breakout Board (Rev A, as shown in the diagram)
    : I’m reviewing the wiring diagram that shows the M0022 PWM Breakout Board connected to the 10-pin J1 connector on the M0065. The PWM output header on the M0022 appears to have eight columns of three pins each.
    Could you confirm whether each column corresponds to one PWM channel and contains a PWM signal pin, a power pin, and a ground pin? If so, could you confirm the pin order within each column and which column corresponds to each channel (PWM 1–8)?
    Are the power and ground pins shared across all eight columns? Is the power rail supplied through the M0065 J1 connector, or does it require an external supply?
    Steps to reproduce:
  • M0041 Current Sensor and M0173 Connector Pinout Questions
    김다연김 김다연
    Thank you for your quick response. I have one more question about the M0042 board.
    Could you let me know how many shunt resistors are used with the INA232 and what the resistance value of each one is?
    If you’re able to share it, I’d also appreciate seeing the portion of the schematic that shows the INA232 and its shunt resistor connections.
    General Questions m0041 m0173
    김다연김 김다연
    @Vinny said:
    M0041에 대한 자세한 설명(장치 및 I2C 주소 포함)은 다음 링크에서 확인할 수 있습니다:
    We have confirmed that the M0041 uses the INA231. We would like to use the INA260 in place of the INA231.
    Could you please confirm whether the INA260 can be used with the M0041 and the existing VOXL 2 software? If so, what hardware and software changes would be required, including any modifications to the current sensor driver or configuration?
  • VOXL 2 / M0062 Configuration Questions
    김다연김 김다연
    @Vinny said:
    J3는 3번 핀과 5번 핀(GPIO_23 RXD, GPIO_22 TXD)을 통해 UART7만 제공하며, 해당 장치는 /dev/ttyHS1로 열거됩니다. UART13은 J3가 아닌 고속 B2B 포트인 J5에 있습니다. J3 및 J5의 전체 핀 구성은 다음 링크를 참조 하십시오. https://docs.modalai.com/voxl2-connectors/
    We would like to use UART7 on J3 and UART13 on J5 to communicate with an STM32F103. Are these UART interfaces enabled by default, or is any additional hardware or software configuration required?
    VOXL 2 and VOXL 2 Mini voxl2
  • M0155 GPIO 109 Sync Output and IR/EO Camera Synchronization
    김다연김 김다연
    Hardware: (board / drone / SKU, serial # if you have it): voxl2
    1. When the M0155 board is connected to VOXL 2, is GPIO 109 enabled to output a 30 Hz sync signal, as it is with the M0173 board?
    2. If we connect IR and EO cameras to the J6 and J7 connectors on VOXL 2 through the M0155 board, will the cameras be synchronized automatically, or are software configuration changes required?
    Steps to reproduce:
    김다연김 김다연
    Hardware: (board / drone / SKU, serial # if you have it): M0041, M0173
    Software version: (paste the output of voxl-version😞
    What I am trying to do: :
    1. Current Sensor on the M0041 Board
    Could you provide the part number of the current sensor used on the M0041 board? Also, what I2C slave address is configured for this sensor on the board?
    2. Connector Pinout on the M0173 Board
    Could you provide the signal name for each pin of the M0173 board connector highlighted in the image below? We would specifically like to know which pins carry the SPI signals.
    Steps to reproduce:
    김다연김 김다연
    Software version: (paste the output of voxl-version😞 6fc1e777-f5f4-45f8-9d3d-00e25c6d3b7a-image.jpeg
    Configuration / services: (paste the output of voxl-inspect-services)bolded text
    1. IMX412 Camera Frame Rate Configuration
    • list itemCould you confirm whether the IMX412 camera’s frame rate can be set to 8.6 fps to match the operating frequency of our IR camera (Lenton)?
    • list itemIf this requires modifications to the kernel or camera driver, could you provide instructions for building and flashing the modified software?
    • list itemIs it possible to change the frame rate through software configuration after boot without modifying the kernel?
    2. UART Configuration on the J3 Connector
    • list itemCould you explain how to configure and enable the UART7 and UART13 pins on the VOXL 2 J3 connector for communication with an STM32?
    3. Camera FSync Configuration on the J3 Connector
    • list itemCould you confirm the GPIO assignment and control mechanism for outputting an FSync (Frame Sync) signal to a camera through the J3 connector?
    • list itemCould you provide instructions for enabling the FSync signal, configuring its period, and applying the settings?
    4. Clarification Regarding the Boot Mode Switches on the M0062 Board
    Our understanding is as follows:
    • list itemFastboot is a bootloader mode used to install or update system images.
    • list itemEDL is a low-level recovery mode used when a boot failure prevents access to Fastboot.
    The VOXL 2 includes Fastboot and EDL switches. We believe access to these switches may be necessary during development and operation in case recovery is required. Please refer to the image below for the connections between the VOXL 2 and the M0062 board.
    However, based on the M0062 board block diagram, the boot mode switches on the M0062 board appear to be unused. Could you confirm whether these switches are actually used and, if so, under what circumstances?
    Steps to reproduce:
    Logs / pictures: (attach files; PX4 logs -> https://logs.px4.io)bolded text
