  3. OpenVpn don't launch on boot
5 Posts 2 Posters 934 Views 2 Watching
  • Sébastien de Pret Roose de CalesbergS Offline
    I have OpenVpn that work when I launch the command:
    openvpn --daemon --script-security 2 --config /etc/openvpn/modal-connector_amsterdam.ovpn
    But when I try to have it launch on boot I have the service that launch but I don't have the tun0 showing in ifconfig.Screenshot from 2021-11-19 14-51-17.png
    And i did
    systemctl enable vpn-start.service
    Any idea where the problem could be? Thanks.
    (And I ask on the side but is it possible to install zerotier?)
    • tomT Online
      tomT Online
      I see that the VPN service is starting so that is a positive. It relies on the voxl-time-sync service to confirm that the date / time is correct before proceeding. One thing to try is to add a sudo to the front of your openvpn call in the service file. Root access may be required depending on your VPN configuration.
      I am not familiar with zerotier so can't give you an answer on that one.
        It gives me 2021 when I launch the time-sync command, so it should be ok.
        Going to try the sudo command.
        sudo /usr/sbin/openvpn --daemon --script-security 2 --config /etc/openvpn/modal-connector_amsterdam.ovpn
        So something like that in the vpn-start file, right?
        • tomT Online
          tomT Online
          @Sébastien-de-Pret-Roose-de-Calesberg Yes, exactly. You may have to specify the whole path of sudo i.e. /usr/bin/sudo
          • tomT Online
            tomT Online
            Also, ensure you aren't connecting to your VPN with the same key on a different machine.
