    Unable to unbrick ModalAI Voxl m500
    • A
      ashwin-umdlife
      Hello there,
      One of our ModalAI drones is bricked and we are unable adb shell into the device. Following the instruction to unbrick given here, I am unable to find device upon sudo fastboot devices.
      Here are the instructions we followed to unbrick the device:
      • Power off the VOXL
      • Detach VOXL USB cable (to ensure USB is not supplying any power VOXL)
      • Attach the USB Expander and Debug Add-On board
      • Ensure the FASTBOOT labeled switch is set to on
      • Ensure the EMERG BOOT labeled switch is set to off
        NOTE: if your board is missing the EMERG BOOT switch, this is OK as its default un-populated state is OFF
      • Power on the VOXL
      • Reattach VOXL USB cable
      • After VOXL boots up (about 5 seconds), set the FASTBOOT back to off
      Here is a video of the attempt https://youtu.be/BDEEefeVZ20
      Please let us know if we have missed any steps. Thank you.
      Ashwin Sushil
      • modaltbM
        modaltb ModalAI Team
        Hi @ashwin-umdlife ,
        Sorry this post is shown as 'deleted' for some reason, testing a response.
        • modaltbM
          I un-deleted this post, I'm not sure if you meant to delete but was asked from our contact email to look at this post.
          OK, I think we have some timing issues possibly happening here.
          Let's work through this and see if we need to update our documentation.... there's a couple scenarios to work through so it's a little tricky.
          The idea here is that we want to mimic "holding down the volume-down key while powering on a phone and letting go right after you power on" and then run the command.
          So, let's try this:
          • have m500 powered off
          • have fastboot switch turned ON
          • have USB cable connected to m500, not the host (because VOXL can get a little power from USB, but not enough to boot)
          • have your terminal open and ready with sudo fastboot devices command waiting
          Now:
          • plug USB power in
          • power on m500
          • turn fastboot switch off and quickly run the command (hit ENTER on the terminal that has the command waiting)
          Repeat this several times if possible. If we ever detect a device in fastboot mode then we can next attempt to update the system image.
          • A
            ashwin-umdlife
            @modaltb I deleted this post because I figure out the usb should be connected to the voxl board and not the expansion board. Thank you making this clear. I see that there is a video made by your team explaining the unbricking procedure. It will be great if you could add it in the office modalai unbricking documentation.
            • Roman RempelR
              Roman Rempel
              @modaltb
              Hey!
              i also try to unbrick my VOXL
              adb - does not work
              but the fastboot sees the device
              Tell me how to properly flash system image using fastboot
              • Chad SweetC
                Chad Sweet ModalAI Team
                Can you please see try this post? https://forum.modalai.com/topic/525/voxl-adb-or-wi-fi-no-longer-communicating
                • A
                  ashwin-umdlife @Chad Sweet
                  @Chad-Sweet I think we are all commenting on the wrong post here. The issue of this post was solved by connecting to the appropriate usb cable.
                  However, @Roman-Rempel I guess you are having similar problem as in this post https://forum.modalai.com/topic/520/voxl-stuck-in-waiting-after-unbricking/3 ?
