  2. VOXL SDK and Software
  3. Starling 2 / VOXL2 M0129 ESC not detected during voxl-esc scan or firmware upgrade
voxl-sdk
1 Posts 1 Posters 850 Views
  • syamala kotireddyS Offline
    syamala kotireddy
    Hi ModalAI team,
    I am working on a Starling 2 / VOXL2 setup and I am stuck with an ESC communication / firmware issue. I would appreciate your guidance on whether this looks like a software mismatch, a known M0129 compatibility issue, or a hardware-side comms problem.
    Hardware / platform:
    • VOXL2 (M0054)
    • Starling 2 platform
    • ESC board label: M0129
    • SKU shown on device:
      MRB-D0014-4-V1-C27-T9-M22-X0
    Current software versions:
    • system-image: 1.8.06-M0054-14.1a-perf
    • voxl-suite: 1.6.3
    • voxl-esc package manually upgraded from 1.5.7 to 1.6.1
    What I did:
    1. Reflashed the board
    2. Restored / checked calibration as needed
    3. Verified Wi-Fi and internet access
    4. Confirmed newer voxl-esc was available in sdk-1.6 and manually installed:
      dpkg -i /data/voxl-esc_1.6.1_arm64.deb
    5. Checked available firmware files under:
      /usr/share/modalai/voxl-esc-tools/firmware/
    Firmware files present for M0129:
    • modalai_esc_firmware_m0129_3_v39_25_a58f5f6f.bin
    • modalai_esc_firmware_m0129_6_v39_25_a58f5f6f.bin
    Note:
    • My physical ESC only says M0129
    • I do not see a suffix like M0129-3 or M0129-6 printed on the board
    • I also do not see an m0129_1 firmware file in the installed firmware folder
    Main issue:
    • voxl-esc scan does not reliably detect any ESCs
    • voxl-esc upgrade_firmware sometimes previously said “successfully pinged ESCs” but then failed with:
      [ERROR] Unknown board detected:
    • After deeper testing, the underlying Python tools also fail to detect the ESC consistently
    Direct tool results:
    1. voxl-esc-scan.py
    • No ESCs detected at all baud rates
    • Sometimes reports:
      ERROR: voxl_uart_read_bytes: Bus '12' is not initialized
    1. voxl-esc-board-detect.py
    • Ends with:
      ERROR: No ESC(s) detected, exiting.
    1. Debug scan:
      Command used:
      python3 voxl-esc-scan.py --enable-debug True --force-scan-all-baud-rates True
    Observed behavior:
    • UART TX packets are clearly being sent
    • No valid UART RX from ESC
    • In one case RX was all zeros after:
    • Every scan ends with:
      WARNING: No ESC(s) detected
      ERROR: not all ESCs found
    Relevant logs:
    • dmesg shows SLPI restart events after reset commands, for example:
      Fatal error on slpi!
      ... Got kill command from apps processor.
    • /dev shows SLPI subsystem nodes, but the scan path still fails to get a valid ESC reply
    Important observations:
    • The VOXL side appears to be transmitting on the ESC link
    • The ESC side does not appear to respond
    • This now looks more like a low-level comms / wiring / power / bootloader issue than just a wrapper-script issue
    Questions:
    1. Is system-image 1.8.06 with voxl-suite 1.6.3 a supported combination for Starling 2 + M0129 ESC?
    2. For an ESC labeled only “M0129”, which firmware should be used:
      • m0129_3
      • m0129_6
      • or is there another variant / package expected?
    3. Is the missing response from the ESC more indicative of:
      • incorrect harness / connector / pinout
      • ESC not powered correctly
      • damaged ESC MCU
      • wrong firmware / bootloader state
    4. Is there a recommended low-level recovery path for M0129 when voxl-esc-scan.py cannot detect any ESCs?
    5. Are there any additional commands you want me to run to verify the ESC UART / SLPI bridge path on this platform?
    Example command outputs:
    system image / suite:
    • voxl-suite: 1.6.3
    voxl-esc version after manual install:
    • 1.6.1
    Direct scan result:
    • WARNING: No ESC(s) detected
    • ERROR: not all ESCs found
    Direct board detect result:
    • ERROR: No ESC(s) detected, exiting.
    Any help would be greatly appreciated. I can also provide full logs or photos of the ESC board/harness if needed.
    Thank you.
