  3. Hi-Res camera disconnect
6 Posts 3 Posters 787 Views 2 Watching
  • wilkinsafW Offline
    wilkinsafW Offline
    wilkinsaf
    We are experiencing interruptions with our cameras. We are actively seeing it in voxl-streamer, but believe it might be having an effect on flight stability as well (we are using VIO)
    When using voxl-streamer we are able to see the video feed for a few minutes, and then it cuts out.
    The main error we see is this
    ERROR: Got 0 bytes. Expecting 40
    closing FDs for client channel 0
    here it is in context
    ---------- hi-res camera -----------------
    yocto:~# voxl-streamer
    Using configuration file /etc/modalai/voxl-streamer.conf
    requesting name voxl-streamer0
    with complete path /run/mpa/hires_preview/voxl-streamer0
    connected after 1 attempt(s)
    Stream available at rtsp://127.0.0.1:8900/live
    A new client has connected to the RTSP server
    An existing client has disconnected from the RTSP server
    WARNING: Got 59392 bytes. Expecting 460800. skipping frame.
    WARNING: Got 59432 bytes. Expecting 460800. skipping frame.
    WARNING: Got 61400 bytes. Expecting 460800. skipping frame.
    Trying to stop loop
    voxl-streamer ending
    yocto:~#
    We also see this with the tracking camera
    ----------- tracking --------------
    yocto:~# voxl-streamer -c tracking-mpa
    Using configuration tracking-mpa
    with complete path /run/mpa/tracking/voxl-streamer0
    connected after 2 attempt(s)
    WARNING: Got 212992 bytes. Expecting 307200. skipping frame.
    WARNING: Got 208896 bytes. Expecting 307200. skipping frame.
    Trying to stop loop
    yocto:~#
    I wanted to include some information from the camera server as well.
    ------------- voxl-camera-server ---------------------
    Jan 01 00:08:59 apq8096 bash[2367]: voxl-camera-server ERROR: Framenumber: 15506 ErrorCode: 4
    Jan 01 00:08:59 apq8096 bash[2367]: voxl-camera-server ERROR: Framenumber: 15507 ErrorCode: 4
    Jan 01 00:08:59 apq8096 bash[2367]: voxl-camera-server ERROR: Framenumber: 15508 ErrorCode: 4
    Jan 01 00:08:59 apq8096 bash[2367]: voxl-camera-server ERROR: Framenumber: 15513 ErrorCode: 4
    Jan 01 00:08:59 apq8096 bash[2367]: voxl-camera-server ERROR: Framenumber: 15514 ErrorCode: 4
    Jan 01 00:08:59 apq8096 bash[2367]: voxl-camera-server ERROR: Framenumber: 15516 ErrorCode: 4
    Jan 01 00:09:00 apq8096 bash[2367]: ERROR in pipe_server_send_to_client, tried to write 460800 bytes but write returned 59392
    Jan 01 00:09:00 apq8096 bash[2367]: ERROR in pipe_server_send_to_client, tried to write 460800 bytes but write returned 61440
    Jan 01 00:09:01 apq8096 bash[2367]: voxl-camera-server ERROR: Framenumber: 15551 ErrorCode: 4
    Jan 01 00:09:01 apq8096 bash[2367]: voxl-camera-server ERROR: Framenumber: 15552 ErrorCode: 4
    and QVIO, but there does not appear to be a lot here
    Jan 01 00:00:08 apq8096 voxl-qvio-server[2072]: loading /data/modalai/opencv_tracking_intrinsics.yml
    Jan 01 00:00:08 apq8096 voxl-qvio-server[2072]: WARNING: disconnected from camera server, resetting VIO
    Jan 01 00:09:21 apq8096 voxl-qvio-server[2072]: WARNING: output data thread fell behind
    Jan 01 00:09:25 apq8096 voxl-qvio-server[2072]: WARNING: output data thread fell behind
    Jan 01 00:09:32 apq8096 voxl-qvio-server[2072]: WARNING: output data thread fell behind
    Jan 01 00:09:34 apq8096 voxl-qvio-server[2072]: WARNING: output data thread fell behind
    Jan 01 00:09:35 apq8096 voxl-qvio-server[2072]: WARNING: output data thread fell behind
    Jan 01 00:09:38 apq8096 voxl-qvio-server[2072]: WARNING: output data thread fell behind
    Jan 01 00:09:42 apq8096 voxl-qvio-server[2072]: WARNING: output data thread fell behind
    Jan 01 00:09:46 apq8096 voxl-qvio-server[2072]: WARNING: output data thread fell behind
    Jan 01 00:10:18 apq8096 voxl-qvio-server[2072]: WARNING: output data thread fell behind
    Questions we asked ourselves
    Q: Could it be hardware setup? Loose cable?
    A: I tried this on 2 different setups and had the same issue
    Q: Have you changed any default camera settings?
    A: No
    Q: What is your camera settings setup
    A: Hi-res + tracking (we have stereo too, but I can not seem to get any stream from them. tried voxl-inspect-cam but still not nothing)
    Q: What cameras are you using?
    A: Both tracking and hi-res from modalai
    Any insight would be much appreciated. Thank you for your time
      these issues don't seem to be common.
      Which version of software are you using?
      What else is running? Those data fell behind errors indicate that too much is running on the cpu. Can you test while also running voxl-inspect-cpu?
        wilkinsafW Offline
        wilkinsaf
        Thank you for the quick reply @Chad-Sweet
        Here is the version information
        yocto:~# voxl-version
        cat: /etc/modalai/voxl-software-bundle-version.txt: No such file or directory
        system-image:    ModalAI 3.2.0 BUILDER: ekatzfey BUILD_TIME: 2021-02-05_19:54
        kernel:          #1 SMP PREEMPT Fri Feb 5 20:03:22 UTC 2021 3.18.71-perf
        architecture:    aarch64
        processor:       apq8096
        os:              GNU/Linux
        voxl-suite:
        Package: voxl-suite
        Version: 0.3.4
        Depends: voxl-utils (>= 0.6.0), libmodal_json (>= 0.3.4), libmodal_pipe (>= 1.7.8), librc_math (>= 1.1.4), libvoxl_io (>= 0.5.4), mavlink-camera-manager (>= 0.0.1), opencv (>= 4.5.1), openmp (>= 10.0.1), voxl-camera-server (>= 0.5.6), voxl-dfs-server (>= 0.0.7), voxl-docker-support (>= 1.1.1), voxl-gphoto2 (>= 0.0.5), voxl-hal3-tof-cam-ros (>= 0.0.5), voxl-imu-server (>= 0.7.8), voxl-modem (>= 0.11.0), voxl-mpa-tflite-server (>= 0.0.2), voxl-mpa-tools (>= 0.1.6), voxl-nodes (>= 0.1.3), voxl-qvio-server (>= 0.2.1), voxl-rtsp (>= 1.0.3), voxl-streamer (>= 0.2.1), voxl-vision-px4 (>= 0.8.1), voxl-vpn (>= 0.0.3)
        Section: base
        Architecture: all
        Maintainer: james@modalai.com
        MD5Sum: e1e5bf1a125affe5036099f6ce895bed
        Filename: voxl-suite_0.3.4.ipk
        Description: meta-package for voxl-suite stable release
        Installed-Time: 333
        Package: voxl-suite
        Version: 0.2.0
        Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
        Status: unknown ok not-installed
        Section: base
        Architecture: armv7a
        MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
        Filename: voxl-suite_0.2.0.ipk
        Description: meta-package to install all of the voxl-suite
        I will run voxl-inspect-cpu now
          wilkinsafW Offline
          wilkinsaf
          wrote on last edited by wilkinsaf
          It appears I do not have voxl-inspect-cpu
          yocto:~# ls /usr/bin/ | grep voxl
          voxl-backup
          voxl-calibrate-imu
          voxl-camera-server
          voxl-configure-camera-server
          voxl-configure-cameras
          voxl-configure-dfs
          voxl-configure-docker-support.sh
          voxl-configure-extrinsics
          voxl-configure-modem
          voxl-configure-mpa
          voxl-configure-qvio
          voxl-configure-vision-px4
          voxl-dfs-server
          voxl-docker
          voxl-env
          voxl-fan
          voxl-gphoto2
          voxl-gpio
          voxl-gpio-loopback
          voxl-hwscan
          voxl-i2c
          voxl-imu-server
          voxl-inspect-apriltag-config
          voxl-inspect-cam
          voxl-inspect-extrinsics
          voxl-inspect-imu
          voxl-inspect-points
          voxl-inspect-pose
          voxl-inspect-qvio
          voxl-inspect-services
          voxl-inspect-vibration
          voxl-kill-pipe
          voxl-logger
          voxl-modem
          voxl-modem-start.sh
          voxl-perfmon
          voxl-px4-shell
          voxl-qvio-server
          voxl-replay
          voxl-reset-qvio
          voxl-rtsp
          voxl-spi
          voxl-streamer
          voxl-test-mavparser
          voxl-test-time
          voxl-time-sync
          voxl-uart-loopback
          voxl-version
          voxl-vision-px4
          voxl-vpn-init
          voxl-wifi
          Looking into how to download this tool now
            It looks like you are using an older version of our software bundle (0.3.2 sys image + 0.3.4 sdk). Our current (0.3.3. sys image + 0.4.6 sdk) platform release can be found on our downloads page. That release contains significant stability improvements to camera server as well as a number of other tools and will make it much easier to debug the problem if it persists.
              wilkinsafW Offline
              wilkinsaf
              That is great to hear. Thanks @Alex-Gardner!
              I will update.
              I assumed I was on the latest as I had seen I was on factory bundle 1.0.1 and saw on this page: https://docs.modalai.com/downloads/
              That the latest factory bundle was 1.0.1.
              Should I be paying attention to the
              When checking whether the system needs an update?
