    How to save images into the SD card using gphoto2.
    Software Development
    2507
    • A
      Alex123
      I'm using gphoto library to save the camera images into the voxl core-board by following https://docs.modalai.com/voxl-libgphoto2/
      I am looking for a way to save the images into the SD card instead of saving them into the internal memory of the voxl core-board.
      As well as I am looking for a way to have filenames numbered as they're saved instead of asking to overwrite the previous photos (like capt001.arw, capt002.arw, and so on).
      Command: gphoto2 --capture-image-and-download
      Thank you.
      • modaltbM
        modaltb ModalAI Team
        Hi @Alex123 ,
        Have you tried using the --filename FILENAME option?
        http://www.gphoto.org/doc/manual/ref-gphoto2-cli.html
        A 2 Replies Last reply Reply Quote 0
        • A
          Alex123 @modaltb
          @modaltb
          No.
          I'll try this and let you know.
          And how can I save the images on SD card?
          • tomT
            tom admin @Alex123
            @Alex123 If you save a file to the /sdcard/ directory it will be saved onto the SD card.
            • A
              Alex123 @modaltb
              Hi @modaltb
              I've tried it using --filename FILENAME option, but it's saving images only in a specified pattern. It's not ignoring the overwrite option.
              The image name should be different from the previous images in my case.
              • A
                Alex123
                Hi @tom
                Using voxl core-board, when we run "docker run -i -t --rm -v /dev/bus/usb/:/dev/bus/usb --net=host --privileged libgphoto2" command, we get
                root@apq8096:/#
                In this, we are unable to get an SD card.
                root@apq8096:/# ls
                FFmpeg etc media root sys voxl-libgphoto2
                bin gphoto2-updater.sh mnt run tmp voxl-libgphoto2.py
                boot home opt sbin usr
                dev lib proc srv var
                root@apq8096:/# cd mnt/
                root@apq8096:/mnt# ls
                root@apq8096:/mnt#
                In adb shell,
                / # ls
                WEBSERVER data flight_controller lost+found proc srv usr
                bin dev home media run sys var
                boot dsp lib mnt sbin system vendor
                build.prop etc lib64 opt sdcard target
                cache firmware linuxrc persist share tmp
                we can get an SD card in the /mnt directory.
                / # cd mnt/
                /mnt # ls
                sdcard
                So if we are in "root@apq8096:/#" then how to access the /sdcard/ directory?
                And how to write an image into sdcard?
                I've tried like this,
                gphoto2 --capture-image-and-download --folder=/mnt/sdcard/
                It's not saving the images into an SD card.
                • tomT
                  tom admin
                  Hi @Alex123
                  It looks like in order to access the sdcard directory in Docker you will have to mount it similar to how the /dev/bus/usb directory is mounted.
                  You can do this by adding another mounting path to the Docker run command, similar to:
                  docker run -i -t --rm -v /dev/bus/usb/:/dev/bus/usb -v /sdcard:/sdcard --net=host --privileged libgphoto2
                  You should now be able to access the /sdcard directory in Docker.
                  As for the naming issues, I'm not positive on the correct answer however gphoto2 has fairly good documentation on their different command line options here: http://www.gphoto.org/doc/manual/ref-gphoto2-cli.html#cli-examples
                  • A
                    Alex123 @tom
                    @tom
                    Yes, it's working.
                    • tomT
                      tom admin @Alex123
                      @Alex123 Glad I could help!
