  2. VOXL Compute & Autopilot
  3. VOXL
  4. pip3 install opencv-contrib-python-headless
Scheduled Pinned Locked Moved VOXL
3 Posts 2 Posters 2.8k Views 2 Watching
  • R Offline
    R Offline
    relevinsky
    I trying to install python opencv package on my voxl board.
    But while downloading and installing the package , I every time run into various problems like the following:
    Python version is 3.0.6
    Please help me to solve the problem like with "numpy" package from
    https://gitlab.com/voxl-public/other/voxl-python-3.6.9
      It is difficult to see exactly what you are trying to do without sharing the commands you are calling.
      If the package is not supported, you should try using Ubuntu in a Docker running on VOXL. See the docs here: https://docs.modalai.com/docker-on-voxl/
      In general, Ubuntu is easier to use if you are not comfortable creating your own packages, and the performance is typically on par or better as it is a pure 64-bit OS
      • R Offline
        R Offline
        relevinsky
        Thank your for your reply.
        The command is pip3 install opencv-contrib-python-headless (=title of the question).
        Ubuntu docker is a good but not enough . I need this (opencv python package) on the target board, again like supported by modalai's python numpy package. Please help me to create/ download/install this python package on a voxl board.
        I need it for later using as ROS node (written in python)
