  3. VOXL2 TOF Camera not working
2 Posts 2 Posters 458 Views
  • Thomas MüllerT Offline
    Thomas Müller
    Hi everyone,
    we are trying to set up the VOXL2 for DAA currently using 3 tracking cameras, 1 high res and 1 TOF camera. We encountered the issue that we cannot receive any data from the TOF camera:
    For: "voxl-inspect-cam -a" we get:
    | Pipe Name | bytes | wide | hgt |exp(ms)| gain | frame id |latency(ms)| fps | mbps | format
    | hires_large_color |18495360 | 4056 | 3040 | 8.33 | 173 | 41737 | 67.0 | 30.0 | 4441.6 | NV12
    | hires_large_encoded | 663 | 4056 | 3040 | 8.33 | 173 | 41737 | 81.2 | 30.0 | 0.3 | H265 (P)
    | hires_large_grey |12330240 | 4056 | 3040 | 8.33 | 173 | 41738 | 58.9 | 30.0 | 2961.0 | RAW8
    | hires_small_color | 1179648 | 1024 | 768 | 8.33 | 173 | 41739 | 42.4 | 30.0 | 283.3 | NV12
    | hires_small_encoded | 138 | 1024 | 768 | 8.33 | 173 | 41739 | 47.9 | 30.0 | 0.5 | H265 (P)
    | hires_small_grey | 786432 | 1024 | 768 | 8.33 | 173 | 41739 | 41.7 | 30.0 | 188.9 | RAW8
    | hires_snapshot |
    | qvio_overlay | 1146880 | 1280 | 896 | 3.38 | 56 | 41718 | 30.9 | 30.0 | 275.3 | RAW8
    | tracking_down | 1024000 | 1280 | 800 | 5.13 | 157 | 152 | 18.5 | 30.0 | 245.8 | RAW8
    | tracking_front | 1024000 | 1280 | 800 | 3.38 | 56 | 41718 | 19.2 | 30.0 | 245.8 | RAW8
    | tracking_rear | 1024000 | 1280 | 800 | 5.00 | 91 | 151 | 18.6 | 30.0 | 245.8 | RAW8
    -> No tof_depth measures.
    For "journalctl -u voxl-camera-server" we get the following output:
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: name: tof
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: sensor type: pmd-tof-liow2
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: isEnabled: 1
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: camId: 3
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: camId2: -1
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: fps: 10
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: en_rotate: 1
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: en_rotate2: 0
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: en_preview: 1
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: pre_width: 240
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: pre_height: 1629
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: en_raw_preview: 1
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: en_small_video: 0
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: small_video_width: -1
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: Connected to cpu-monitor
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: gbm_create_device(156): Info: backend name is: msm_drm
    Jul 21 12:43:52 m0054 voxl-camera-server[1391]: Starting Camera: hires (id #1)
    Jul 21 12:43:53 m0054 voxl-camera-server[1391]: Starting Camera: tracking_rear (id #2)
    Jul 21 12:43:53 m0054 voxl-camera-server[1391]: Starting Camera: tof (id #3)
    Jul 21 12:43:53 m0054 voxl-camera-server[1391]: ERROR: Camera 3 failed to find supported preview config: 240x1629
    Jul 21 12:43:53 m0054 voxl-camera-server[1391]: WARNING: Failed to start cam tof due to invalid resolution
    Jul 21 12:43:53 m0054 voxl-camera-server[1391]: WARNING: assuming cam is missing and trying to compensate
    Jul 21 12:43:53 m0054 voxl-camera-server[1391]: Starting Camera: tracking_down (originally id #4) with id offset: 1
    Jul 21 12:43:53 m0054 voxl-camera-server[1391]: ------ voxl-camera-server: Started 4 of 5 cameras
    Jul 21 12:43:53 m0054 voxl-camera-server[1391]: ------ voxl-camera-server: Camera server is now running
    Jul 21 12:43:54 m0054 voxl-camera-server[1391]: connected to mavlink pip
    Also when checking the config-file we saw no parameter for changing the resolution of the TOF Camera:
    "type": "pmd-tof-liow2",
    "name": "tof",
    "enabled": true,
    "camera_id": 3,
    "fps": 10,
    "en_rotate": true,
    "ae_mode": "off",
    "exposure_max_us": 6000,
    "standby_enabled": false,
    "decimator": 5
    Question: Is the resolution really the issue and if so where can we change it?
    Thanks in advance!
    Best regards,
    Thomas
    Viktor GalV 1 Reply Last reply
    • Thomas MüllerT Thomas Müller
      Hi everyone,
      | hires_snapshot |
      "name": "tof",
      "enabled": true,
      "camera_id": 3,
      "fps": 10,
      "en_rotate": true,
      "ae_mode": "off",
      "decimator": 5
      Thanks in advance!
      Best regards,
      Thomas
      Viktor GalV Offline
      Viktor GalV Offline
      Viktor Gal
      @Thomas-Müller interesting. i'm just experience the very same thing. have you by chance figured out what was the issue?
