  3. libvoxl-cutils camera_image_metadata.h
2 Posts 2 Posters 526 Views 1 Watching
  • K Offline
    K Offline
    KnightHawk
    I'm looking for a specific header so that I can access the camera data in my custom driver but I do not see it in https://gitlab.com/voxl-public/voxl-sdk/core-libs/libvoxl-cutils. Where can I find camera_image_metadata.h? Thanks.
    // ---------------- Save Camera Feed (if enabled) -----------------
    if (camera_pipe_fd != -1 && FD_ISSET(camera_pipe_fd, &rfds)) {
        camera_image_metadata_t meta;
        ssize_t ret = read(camera_pipe_fd, &meta, sizeof(meta));
        if (ret == sizeof(meta)) {
            if (img_buffer.size() < meta.size) {
                img_buffer.resize(meta.size);
            ret = read(camera_pipe_fd, img_buffer.data(), meta.size);
            if (ret == (ssize_t)meta.size) {
                cv::Mat image(meta.height * 3 / 2, meta.width, CV_8UC1, img_buffer.data());
                char filename[128];
                snprintf(filename, sizeof(filename), "/data/img_%s_%lld.jpg", TARGET_CAMERA_NAME.c_str(), (long long)meta.timestamp_ns);
                cv::imwrite(filename, image);
    • K KnightHawk
                  char filename[128];
      @KnightHawk , the definition is in libmodal-pipe library.
      Link Preview Image
      library/include/modal_pipe_interfaces.h · master · voxl / VOXL SDK / Core Libs / libmodal-pipe · GitLab
      This is a library to support named-pipe communication between a local server and multiple local clients. This is used for the voxl-imu-server.
      favicon
      GitLab (gitlab.com)
