  2. VOXL SDK and Software
  3. Getting mavsdk server running on voxl2
voxl-sdk
7 Posts 3 Posters 1.6k Views
  • B Offline
    B Offline
    binu.abraham
    I have a voxl2 drone, I can ssh to it, but can't adb in right now.
    I am trying to follow the instructions on https://docs.modalai.com/mavsdk/ But cannot find the voxl-mavsdk.tar file that is referenced in the video in the download.
    So I have tried to build it using the docker https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-mavsdk. But the build.sh assumes the device is connected via adb .
    I tried running those commands from the ssh shell , but I couldn't find voxl-configure-docker-support.sh.
    Is there a different set of instructions for voxl2 ?
    B 1 Reply Last reply
    • B binu.abraham
      B Offline
      B Offline
      binu.abraham
      @binu-abraham I found the voxl-configure-docker-support script, trying to run it now
      • B binu.abraham
        B Offline
        B Offline
        binu.abraham
        @binu-abraham Is there a pre-built docker image for mavsdk server on voxl2 ?
        B B 2 Replies Last reply
        • B binu.abraham
          B Offline
          B Offline
          binu.abraham
          @binu-abraham
          Wanted to post about how I got this working finally
          I was having issues with docker build ( would segfault on ubuntu) and building the mavsdk from source ( while running the binary on voxl2, it complained that glibc was missing ) , so I finally downloaded the mavsdk_server_linux-arm64-musl from https://github.com/mavlink/MAVSDK/releases
          Followed the instructions to set the vision hub prameters from https://docs.modalai.com/mavsdk/
          Started the mavsdk-server
          ./mavsdk_server_linux-arm64-musl -p 50051 udpin://0.0.0.0:14550
          From the android app
          drone = System(
          <drone IP address>,
          50051 // -p parameter for mavsdk-server
          Don't call mavsdkServer.run as mavsdkserver is already running in voxl2
          • B binu.abraham
            @binu-abraham
            drone = System(
            <drone IP address>,
            B Offline
            B Offline
            brahim
            @binu-abraham you can do an scp of the get_docker.sh script here on to the voxl2 and then run it.
            Most of the voxl suite packages assume you have an adb connection.
            As for building the docker image over ssh, I would just clone down voxl-docker-mavsdk on to the voxl2 itself, change directory to voxl-docker-mavsdk, and then just run the following command:
            docker build . -t mavsdk --network=host
            This should build an ubuntu focal image with mavsdk + all dependencies as well as the takeoff and land example
            L 1 Reply Last reply
            • B binu.abraham
              B Offline
              B Offline
              brahim
              @binu-abraham I do not believe modalai has images on docker hub or any other docker repo. The gitlab repo has all of the Dockerfiles though.
              • B brahim
                L Offline
                L Offline
                luisdelavega
                @brahim Thanks for this advice!
                I'm working on Windows with WSL and it is impossible for me to build the docker image by following the instructions on the voxl-docker-mavsdk README.
                I'm still unsure why the image build on the VOXL and not on my WSL Ubuntu, but at least I got it to work.
