  2. Software Development
  3. ROS
  4. /tof_depth image conversion problem
4 Posts 2 Posters 2.7k Views 1 Watching
  • J Offline
    Judoor 0
    I would like to convert the depth image from mono8 to UC16 while maintaining accurate depth references.
    Currently, I am doing this, but I am ending up with a flat image.
    void depthCallback(const sensor_msgs::ImageConstPtr &msg)
             try
                 // Convert the input ROS image to an OpenCV image
                 cv_bridge::CvImagePtr cv_ptr = cv_bridge::toCvCopy(msg, sensor_msgs::image_encodings::MONO8);
                 // Create a new image in CV_16UC1 format
                 cv::Mat converted_image;
                 cv_ptr->image.convertTo(converted_image, CV_16UC1, 256.0); // Scale mono8 values to 16-bit
                 // Publish the converted image
                 cv_bridge::CvImage out_msg;
                 out_msg.header = msg->header; // Keep the same header
                 out_msg.encoding = sensor_msgs::image_encodings::TYPE_16UC1;
                 out_msg.image = converted_image;
                 depth_pub_.publish(out_msg.toImageMsg());
                 // depth_pub_.publish(depth_msg);
             catch (cv_bridge::Exception &e)
                 ROS_ERROR("CvBridge Error in depthCallback: %s", e.what());
    Also, I want to mix it with an RGB image to get an RGBD image, I'm using the rgbdsync nodelet from rtabmap_ros. But I'm unable to make it work. Does someone already did that ?
    Julien
    J 1 Reply Last reply
    • J Judoor 0
               try
      Julien
      Judoor 0
      Can you help me with the depth image conversion ?
      • J Judoor 0
        @Judoor-0 , can you please clarify what you mean a "flat image" ?
        Also, it seems you can convert the type to MONO16 right in toCvCopy call. Take a look at the implementation, which will automatically re-scale the data (from MONO8 to MONO16), so you will not lose any information (because in this case you will be upscaling, that is going from 8 bit to 16 bit): https://github.com/strawlab/vision_opencv/blob/master/cv_bridge/src/cv_bridge.cpp#L174
        So you can probably just have:
        cv_bridge::CvImagePtr cv_ptr = cv_bridge::toCvCopy(msg, sensor_msgs::image_encodings::MONO16);
        out_msg.image = cv_ptr->image;
        or i think you can just do the following because toCvCopy will automatically copy the header and update the encoding for you:
        depth_pub_.publish(cv_ptr->toImageMsg());
        I have not tried running it, but hopefully should point you in the right direction!
          Judoor 0
          @Alex-Kushleyev thank you alex i'll try that
