  2. Software Development
  3. Modal Ai Voxl2 Mini HITL Request for Support
2 Posts 2 Posters 1.7k Views 1 Watching
  • EyucelE Offline
    EyucelE Offline
    Eyucel
    Hello everyone. I hope you are well and everything is fine.
    I am a voxl2 mini user. I bought this electronic card and I am using it according to the documentation. However, I encountered a problem somewhere. I want to simulate my Voxl2 mini card with HITL and I have set up the necessary setup. When I run it, I get the error I have posted. There is no information flow from the UART port, nor can I connect via docker. When I plug in the FTDI cable, the computer does not see it at all. However, when I plug in the UART converter, the computer sees it, but as I said, there is no information flow this time.
    If I need to give more information;
    Here I tried connecting RX and TX in reverse and forward.
    Here I also tried connecting rx and tx straight and reverse
    I would be very grateful if you could help me on this issue. Thank you very much for your help in advance, I wish you good work.
    d.png g)
    • EyucelE Eyucel
      d.png g)
      @Eyucel To use PX4 HITL on VOXL 2 mini you need to connect to a DSP UART, not an applications processor UART. So, instead of using J10, you need to use a UART on J19 (Like the ESC UART pins 7 and 8).
