  3. Can't get QGroundControl to connect
8 Posts 2 Posters 980 Views 1 Watching
  • P Offline
    P Offline
    PatrickC
    I have VOXL with tracking camera only. No flight core, as I'm not developing for a drone application.
    I see in wireshark UDP packets from PC going to VOXL and VOXL is seeing them also.
    / # cat /etc/modalai/voxl-vision-px4.conf
     * VOXL Vision PX4 Configuration File
            "qgc_ip":       "NULL",
            "en_localhost_mavlink_udp":     true,
            "en_secondary_qgc":     false,
            "secondary_qgc_ip":     "192.168.1.214",
            "qgc_udp_port_number":  14550,
            "localhost_udp_port_number":    14551,
            "udp_mtu":      512,
            "en_vio":       true,
            "en_voa":       false,
            "en_send_vio_to_qgc":   false,
            "en_send_voa_to_qgc":   false,
            "en_set_clock_from_gps":        true,
            "en_force_onboard_mav1_mode":   true,
            "en_reset_px4_on_error":        true,
            "qvio_auto_reset_quality":      0.00050000002374872565,
            "en_adsb":      false,
            "adsb_uart_bus":        7,
            "adsb_uart_baudrate":   57600,
            "px4_uart_bus": 5,
            "px4_uart_baudrate":    921600,
            "offboard_mode":        "off",
            "follow_tag_id":        0,
            "en_tag_fixed_frame":   false,
            "fixed_frame_filter_len":       5,
            "en_transform_mavlink_pos_setpoints_from_fixed_frame":  false
    voxl-vision-px4 --debug_udp_recv
    Enabling UDP recv debugging
    loading our own config file
    qgc_ip:                     NULL
    en_localhost_mavlink_udp    1
    en_secondary_qgc:           0
    secondary_qgc_ip:           192.168.1.214
    qgc_udp_port_number:        14550
    localhost_udp_port_number:  14551
    udp_mtu:                    512
    en_vio:                     1
    en_voa:                     0
    en_send_vio_to_qgc:         0
    en_send_voa_to_qgc:         0
    en_set_clock_from_gps:      1
    en_force_onboard_mav1_mode: 1
    en_reset_px4_on_error:      1
    qvio_auto_reset_quality:    0.000500
    en_adsb:                    0
    adsb_uart_bus:              7
    adsb_uart_baudrate:         57600
    px4_uart_bus:               5
    px4_uart_baudrate:          921600
    offboard_mode:              off
    follow_tag_id:              0
    en_tag_fixed_frame:         0
    fixed_frame_filter_len:     5
    loading extrinsics config file
    exising instance of voxl-vision-px4 found, attempting to stop it
    starting geometry module
    starting px4 monitor
    starting uart mavlink
    Successfully opened mavparser
    starting udp mavlink
    Adding manual QGC IP address to udp connection list: NULL
    WARNING: invalid qgc_ip, this is fine if you don't want to use it
    starting px4 shell
    starting fixed pose input
    starting vio manager
    starting tag manager
    UDP recv msg ID:   0 sysid:255 from port: 14550 IP: 192.168.8.112
    Added new UDP connection to 192.168.8.112
    WARNING PX4 DISCONNECTED FROM UART
    So packets are arriving, but nothing is being sent from VOXL?
    My goal is to extract all telemetry thru UART, but want to use QGroundControl to view telemetry.
    • P Offline
      P Offline
      PatrickC
      Also, I'm not getting any readout using voxl-inspect-qvio
      yocto:/etc/modalai$ voxl-inspect-qvio
      waiting for server
        Is QVIO server running? can you paste the output of voxl-inspect-services
        • P Offline
          P Offline
          PatrickC
          Not running, how does it get started?
           Service Name        |  Enabled  |   Running   |  CPU Usage
           docker-autorun      | Disabled  | Not Running | Not Running
           docker-daemon       | Disabled  | Not Running | Not Running
           modallink-relink    | Disabled  | Not Running | Not Running
           voxl-camera-server  |  Enabled  | Not Running | Not Running
           voxl-cpu-monitor    |  Enabled  |   Running   |   0.0%
           voxl-dfs-server     | Disabled  | Not Running | Not Running
           voxl-imu-server     |  Enabled  | Not Running | Not Running
           voxl-modem          | Disabled  | Not Running | Not Running
           voxl-qvio-server    | Disabled  | Not Running | Not Running
           voxl-streamer       | Disabled  | Not Running | Not Running
           voxl-tag-detector   | Disabled  | Not Running | Not Running
           voxl-tflite-server  | Disabled  | Not Running | Not Running
           voxl-time-sync      | Disabled  | Not Running | Not Running
           voxl-vision-px4     |  Enabled  | Not Running | Not Running
          yocto:/etc/modalai$ enable voxl-qvio-server
          -bash: enable: voxl-qvio-server: not a shell builtin
          • P Offline
            P Offline
            PatrickC
            Looks like I need to calibrate the tracking camera. Can I do this without ROS?
            yocto:/etc/modalai$ voxl-qvio-server
            loading qvio config file
            Creating new config file: /etc/modalai/voxl-qvio-server.conf
            imu_name:                         imu1
            cam_name:                         tracking
            odr_hz:                           30.000
            use_camera_height_bootstrap:      1
            camera_height_off_ground_m:        0.100
            enable_init_while_moving:         1
            cam_imu_timeshift_s:               0.002
            cam_imu_timeshift_s_uncertainty:   0.001
            T_cam_wrt_imu_uncertainty:         0.005  0.005  0.005
            R_cam_to_imu_uncertainty:          0.040  0.040  0.040
            accl_fsr_ms2:                     156.000
            gyro_fsr_rad:                     34.000
            accl_noise_std_dev:                0.316
            gyro_noise_std_dev:                0.010
            cam_noise_std_dev:                100.000
            min_std_pixel_noise:               0.500
            fail_high_pixel_noise_points:      1.665
            limited_imu_bw_trigger:           35.000
            gps_imu_time_alignment_s:          0.000
            T_gps_wrt_imu:                    -0.115  0.450  0.100
            enable_mapping:                   1
            enable_gps_vel:                   0
            setting scheduler
            WARNING Failed to set priority, errno = 1
            This seems to be a problem with ADB, the scheduler
            should work properly when this is a background process
            ERROR failed to set scheduler
            #0:
                parent:                imu1
                child:                 tracking
                T_child_wrt_parent:    0.017   0.015   0.013
                RPY_parent_to_child:   0.0    45.0    90.0
                R_child_to_parent:     0.000  -0.707   0.707
                                       1.000   0.000  -0.000
                                      -0.000   0.707   0.707
            tbc:   0.017  0.015  0.013
            ombc:  0.614  0.614  1.482 (axis angle)
            ombc:  0.000 45.000 90.000 (RPY deg)
            WARNING: Failed to open tracking camera intrinsic file:
            /data/modalai/opencv_tracking_intrinsics.yml
            using default tracking camera intrinsics for now
            follow instructions here to calibrate the tracking cam:
            https://docs.modalai.com/calibrate-cameras/
            using camera intrinsics:
            focal lengths: 275.078000 274.931000
            principle points: 319.625000 243.144000
            distortion: 0.003908 -0.009574 0.010173 -0.003329
            MachineVision is licensed as community user
            LNX_8074 supported? 1
            LNX_8096 supported? 1
            LNX_IA64 supported? 1
            WINDOWS supported? 0
            AR ERROR: arFileOpen(): Failed to open file: /etc/modalai/vislam/Configuration.SF.xml
            FASTCV: fcvAvailableHardware Linux
            mempool cur block size 307200, new block size 307200
            Please ignore the error about Configuration.SF.xml above. ^^^
            It's an optional file, and should be a warning not an error
            waiting for imu
            waiting for cam
            • P Offline
              P Offline
              PatrickC
              @Alex-Gardner I turned on some of the services
               voxl-camera-server  |  Enabled  |   Running   |   4.1%
               voxl-qvio-server    |  Enabled  |   Running   |  10.6%
               voxl-vision-px4     |  Enabled  |   Running   |   1.8%
              getting vio data, but lots of BAD_CAM_CAL
              yocto:~$ voxl-inspect-qvio
              waiting for server
                  T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)| state| error_code
               -377.23 1276.78  231.84|  20.6   47.4  -97.2| OKAY | BAD_CAM_CAL
               -379.63 1270.80  230.19|  28.4   40.2  -73.3| OKAY | BAD_CAM_CAL
               -380.97 1266.02  229.11|  31.1   33.5  -57.5| OKAY | BAD_CAM_CAL
               -346.15 1295.79  243.18|  22.2    6.9    1.4| OKAY |
               -346.10 1295.99  243.34|  21.1    5.9    4.5| OKAY |
               -346.02 1296.26  243.58|  19.5    4.8    8.5| OKAY | BAD_CAM_CAL
               -345.99 1296.50  243.75|  18.2    3.9   11.6| OKAY |
               -345.98 1296.77  243.93|  16.9    3.1   14.7| OKAY | BAD_CAM_CAL
               -346.00 1297.45  244.38|  13.7    1.6   22.2| OKAY |
               -346.03 1297.77  244.58|  12.3    1.1   25.4| OKAY | BAD_CAM_CAL
                Calibrating the cameras currently requires ROS (though we're making progress on an on-board embedded tool that should be here in a few weeks).
                P 1 Reply Last reply
                • ? A Former User
                  P Offline
                  P Offline
                  PatrickC
                  @Alex-Gardner thank you. I'll head down that path with ROS.
                  Any readmes/docs/guidance on how I can extract the telemetry/pose data via UART(J10)? I have the hardware connected, but a bit lost on where to start. Would it be easier if I added the Flight Core to the VOXL to get the telemetry ports J4/J5?
                  Is Flight Core required to allow qGroundControl to connect to VOXL?
                  Thanks.
