  3. Error in building voxl-build
5 Posts 3 Posters 1.1k Views 3 Watching
  • Thomas MacNamaraT Offline
    Thomas MacNamara
    Hi, I am trying to build the Docker Image as per the instructions in the gitlab readme
    https://gitlab.com/voxl-public/system-image-build/voxl-build
    On the step
    docker build -t voxl-build -f ubuntu-xenial.Dockerfile .
    I get the following error:
    Collecting pip
      Downloading https://files.pythonhosted.org/packages/f7/ce/e359cf283c0c0f2e0af7df8f16c8d79047aa1887a00a5b39b27d8afc49e2/pip-21.2.1.tar.gz (1.6MB)
        Complete output from command python setup.py egg_info:
          File "<string>", line 1, in <module>
          File "/tmp/pip-build-1qzqBH/pip/setup.py", line 7
            def read(rel_path: str) -> str:
        SyntaxError: invalid syntax
    Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-1qzqBH/pip/
    You are using pip version 8.1.1, however version 21.2.1 is available.
    You should consider upgrading via the 'pip install --upgrade pip' command.
    The command '/bin/sh -c apt-get update    && apt-get -y --quiet --no-install-recommends install       gcc-4.8-multilib       g++-4.8-multilib       gawk       wget       git-core       diffstat       unzip       texinfo       gcc-multilib       build-essential       chrpath       bzip2       zip       cpio       bc       make       autoconf       automake       libtool       wget       curl       sudo       libxml-simple-perl       doxygen       qemu-user-static       android-tools-fsutils       debootstrap       schroot       vim       less       iputils-ping       python       python3.6       python-pip       python-setuptools       python-tk       openssh-server    && apt-get clean autoclean    && pip install --upgrade pip    && curl https://storage.googleapis.com/git-repo-downloads/repo-1 > /usr/bin/repo    && chmod a+x /usr/bin/repo    && echo "dash dash/sh boolean false" | debconf-set-selections    && DEBIAN_FRONTEND=noninteractive dpkg-reconfigure dash' returned a non-zero code: 1
    I have gotten this error in Ubuntu 20 and a clean install of Ubuntu 18
    This is with a fresh pull from the repo
      Hey @Thomas-MacNamara , we're looking into this now.
      -Travis
      • tomT Offline
        @Thomas-MacNamara The issue should be fixed now, go ahead and pull the changes and give it another try.
          Thomas MacNamara
          I can confirm it does work now.
          Also not sure if it helps but after running through this about 10 times I got tired of copy and pasting the steps from the docs and modified the last line of the docker.run
          -w /home/user ${optImg} /bin/bash -c "echo doing the first steps from the docs ; cd $optDir ; sudo -S <<< "user" chown user . ; rm -rfv $optDir ; echo user; source /home/user/build.sh $optDir; $SHELL"
          This just does the rest of the steps at once and starts building
          I am sure most people wouldn't need it but i might be useful for someone
          • tomT Offline
            Great, thank you!
