  3. voxl-docker-mavsdk-python build issues
voxl
48 Posts 6 Posters 30.8k Views 4 Watching
    @Alexander-Saunders I'm only suggesting that there is a permissions problem of some sort. I don't see that on my machine so just trying to figure out what is different in your environment.
    Alexander SaundersA Offline
    Alexander Saunders
    @Eric-Katzfey Is it possible to see a picture of your terminal of the commands you sent?
      Alexander Saunders
      • Alexander SaundersA Alexander Saunders
        @Alexander-Saunders iris_hitl.sdf is part of the docker image so it will be the same.
          @Alexander-Saunders
          modalai@modalai-XPS-15-9570:~$ docker run --rm -it --net=host --privileged -v /dev/input:/dev/input:rw voxl-gazebo-docker
          root@modalai-XPS-15-9570:/usr/workspace/voxl2_hitl_gazebo# ls
          CMakeLists.txt           build-gazebo.bash    include       package.xml            scripts
          Dockerfile               build-mavlink.bash   mavlink       resources              src
          README.md                cmake                mavlink-libs  run-docker-image.bash  unit_tests
          build                    docker-commands.txt  models        run_gazebo.bash        worlds
          build-docker-image.bash  external             msgs          run_headless.bash
          root@modalai-XPS-15-9570:/usr/workspace/voxl2_hitl_gazebo# ls /dev/ttyUSB0
          /dev/ttyUSB0
          root@modalai-XPS-15-9570:/usr/workspace/voxl2_hitl_gazebo# ls -l /dev/ttyUSB0
          crw-rw---- 1 root dialout 188, 0 Jun  3 16:02 /dev/ttyUSB0
          root@modalai-XPS-15-9570:/usr/workspace/voxl2_hitl_gazebo# ./run_headless.bash
          GAZEBO_PLUGIN_PATH :/usr/workspace/voxl2_hitl_gazebo
          GAZEBO_MODEL_PATH :/usr/workspace/voxl2_hitl_gazebo/models
          LD_LIBRARY_PATH :/usr/workspace/voxl2_hitl_gazebo/build
          Warning [parser.cc:833] XML Attribute[version] in element[sdf] not defined in SDF, ignoring.
          Opened serial device /dev/ttyUSB0
            @Alexander-Saunders
            modalai@modalai-XPS-15-9570:~$ docker images | grep gazebo
            voxl-gazebo-docker            latest       1c8ce4f31e4f   3 months ago    3.73GB
            voxl-gazebo-docker            v1.2         1c8ce4f31e4f   3 months ago    3.73GB
              @Alexander-Saunders We have quite a few customers using HITL successfully and they are using the instructions in the document so I'm thinking there is something in your environment that is causing the issue. Do you have access to a different Linux machine that you can use?
              Alexander SaundersA 1 Reply Last reply
                Alexander Saunders
                @Eric-Katzfey Update:
                We switched some of the wires for the FTDI cable and now receiving data. We went back to following the HITL docs along with https://forum.modalai.com/topic/3511/serial-port-closed-and-other-hitl-errors/9 . We have the drone running in HITL via QGC and running the voxl-px4-hitl command. Despite this, gazebo is still not showing the drone or connecting. Could the issue possibly be with the Dockerfile that reflects bionic instead of focal since that had to be changed for the image to be pulled? We also tried running ./run-docker.sh within the directory and received docker run --help.
                  @Alexander-Saunders Looks better now. What does the dsp_hitl start command look like now? Seems like it is setup for VIO only.
