  3. VOXL2 OV9782 and other camera supported frame rates. +QVIO
2 Posts 2 Posters 782 Views
  • J Offline
    jameskuesel
    Hi!
    What frame rates does the VOXL2 support with OV9782 cameras? Does it depend on the configuration? Max it seemed I could bump it up to was 30 fps but maybe that was only in my specific configuration (I'll note not one of the officially supported ones!).
    Which frame rates are supported and is there a max frame rate? Is there a list I can view somewhere I could view of sensors and supported frame rates? I didn't see fps on the spec sheets.
    Also, I am assuming this is how this works but does voxl-qvio-server run at the rate the camera it is using is set to? I know in previous posts it has been mentioned that bumping the fps doesn't make a huge impact. That being said, I did run an AR0144 camera at 60 fps and do I think I saw a bit of an improvement compared to 30. However, the results are a little anecdotal. Observed slightly better quality, num features, and less dropouts in difficult enviroments.
    My plan is to run the OV9782 at 60 fps if supported and makes a difference.
    ModeratorM 1 Reply Last reply
    • J jameskuesel
      Hi!
      @jameskuesel 30FPS currently. The AR0144 modules will outperform OV9782 modules as they have a better sensor and better lens
