  3. m500 says it is armed but it is not armed
m500
3 Posts 2 Posters 910 Views 2 Watching
  • Daniel RyuD Offline
    Daniel RyuD Offline
    Daniel Ryu
    The m500 I have has been working fairly well, but recently I ran into an issue where the drone is supposedly armed according to QGC and the LED signal on the GPS, but the motors do not move. I checked and made sure the emergency kill switch was not enabled, and the drone was in position mode when I tried to arm it.
    • Jeremy SchmidtJ Offline
      Jeremy Schmidt
      Hi Daniel, Have you tried arming in any other mode? Our recent M500 setup's use Dshot instead of Straight PWM's. We've seen this problem when we set the drone up for dshot, but then it gets switched over to pwm without being calibrated. Are you familiar with Dshot vs PWM for ESC / motor control?
        Jeremy Schmidt
        In the parameters list, check for "dshot_config". Our most recent M500's use dshot 600.
