  3. ADB shell connects to root@m0054:/# instead of voxl2:/$
7 Posts 2 Posters 1.5k Views 1 Watching
  • S Offline
    S Offline
    swickliff
    When I try to ADB shell, it accesses root@m0054:/# instead of voxl2:/$
    This root interface does not have any of the voxl bash commands. For instance I couldn't use voxl-inspect-services.
    I've tried killing and restarting the ADB server, but that did nothing
    lsusb is reading the device as Qualcomm, Inc. KONA-QRD _SN:3C6BFAA2
    A previous forum post had the same issue, they said it was a permissions issue.
    I am not sure what permissions I should try to change. How can I change what ADB shell connects to?
    • S swickliff
      @swickliff It seems as though the voxl-suite hasn't been installed. Can you download and install the latest SDK (1.1.3) from our downloads page? downloads.modalai.com
      S 1 Reply Last reply
        S Offline
        S Offline
        swickliff
        @tom
        The SDK install failed to locate the voxl-suite-offline-packages. I used the 1.1.2 release because that is what we currently have on our other Voxl2 boards at the moment. If you think the 1.1.3 release will produce different results I can try that.
        Here's a screenshot of the errors:
        This board was originally bricked by accident and went through the unbricking guide but had some warnings or errors pop up when the Image was re-flashed. I believe the Image reflash was attempted again but failed.
        • S swickliff
          @tom
          @swickliff What command did you run to generate the above failure? Are you running ./install.sh from the SDK download dir
            S Offline
            S Offline
            swickliff
            @tom yes, I used ./install.sh from the voxl2_SDK_1.1.2 dir
            • S swickliff
              @swickliff Can you try ./install.sh -w ? That will do a full system wipe in case a partition is corrupt
                S Offline
                S Offline
                swickliff
                @tom That worked! thanks for the help
