    Docker not working correctly on VOXL
    • M
      memeliner787
      I have a VOXL Flight Deck on my hands but am unfortunately not able to get Docker containers running on it.
      First of all, docker-autorun.service does not start:
      # systemctl status docker-autorun.service -l
      ● docker-autorun.service - docker autorun service for VOXL
         Loaded: loaded (/etc/systemd/system/docker-autorun.service; enabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Thu 1970-01-01 00:12:04 UTC; 53 years 11 months ago
        Process: 2168 ExecStartPre=/usr/bin/docker-prepare.sh (code=exited, status=1/FAILURE)
      Jan 01 00:11:42 apq8096 systemd[1]: Starting docker autorun service for VOXL...
      Jan 01 00:11:45 apq8096 docker-prepare.sh[2168]: preparing docker with docker-prepare.sh
      Jan 01 00:11:45 apq8096 docker-prepare.sh[2168]: this may take a few seconds
      Jan 01 00:12:04 apq8096 docker-prepare.sh[2168]: docker-prepare: failed to see cpuset appear after 15 seconds
      Jan 01 00:12:04 apq8096 systemd[1]: docker-autorun.service: Control process exited, code=exited status=1
      Jan 01 00:12:04 apq8096 systemd[1]: Failed to start docker autorun service for VOXL.
      Jan 01 00:12:04 apq8096 systemd[1]: docker-autorun.service: Unit entered failed state.
      Jan 01 00:12:04 apq8096 systemd[1]: docker-autorun.service: Failed with result 'exit-code'.
      Attempting to start it manually doesn't work either:
      / # sudo systemctl start docker-autorun.service
      Job for docker-autorun.service failed because the control process exited with error code. See "systemctl status docker-autorun.service" and "journalctl -xe" for details.
      I can start the docker daemon manually as follows:
      sudo systemctl start docker-daemon
      sudo systemctl status docker-daemon -l
      ● docker-daemon.service - docker service for VOXL
         Loaded: loaded (/usr/bin/docker; enabled; vendor preset: enabled)
         Active: active (start-post) since Sun 2023-12-31 12:46:20 UTC; 12s ago
       Main PID: 4385 (docker);         : 4386 (docker-prepare.)
         CGroup: /system.slice/docker-daemon.service
                 ├─4385 /usr/bin/docker daemon -g /data
                 └─control
                   ├─4386 /bin/bash /usr/bin/docker-prepare.sh
                   └─4456 sleep 1
      but this fails shortly with:
      Dec 31 12:47:03 apq8096 docker-prepare.sh[4386]: docker-prepare: failed to see cpuset appear after 15 seconds
      Dec 31 12:47:03 apq8096 systemd[1]: docker-daemon.service: Control process exited, code=exited status=1
      Dec 31 12:47:03 apq8096 docker[4385]: time="2023-12-31T12:47:03.642284000Z" level=info msg="Processing signal 'terminated'"
      Dec 31 12:47:03 apq8096 systemd[1]: docker-daemon.service: Unit entered failed state.
      Dec 31 12:47:03 apq8096 systemd[1]: docker-daemon.service: Failed with result 'exit-code'.
      I've followed this thread: https://forum.modalai.com/topic/86/docker-daemon-fails-to-start-on-voxl/40 and tried reconfiguring Docker via voxl-configure-docker-support, and also removing /data/network/files. When rerunning voxl-configure-docker-support it always fails when attempting to enable docker-autorun:
      detected hello-world docker image already loaded
      you can test by running:
      voxl-docker -n -i hello-image -e ""
      enabling docker-autorun
      Additionally, when running the voxl-configure-docker-support script I appear to be missing the line detected APQ8096 as shown by the tutorial here: https://docs.modalai.com/docker-on-voxl/
      The output for voxl-version is as follows:
       voxl-version
      system-image: 4.0.0
      kernel:       #1 SMP PREEMPT Thu Oct 13 17:57:05 UTC 2022 3.18.71-perf
      hw version:   VOXL
      voxl-suite:   1.1.0
      Packages:
      Repo: http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64/
      Last Updated: Never
      List:
      	apq8096-dfs-server          0.3.1
      	apq8096-imu-server          1.0.3
      	apq8096-libpng              1.6.38-1
      	apq8096-rangefinder-server  0.1.3
      	apq8096-system-tweaks       0.2.3
      	apq8096-tflite              2.8.3-1
      	libapq8096-io               0.6.0
      	libmodal-cv                 0.4.0
      	libmodal-exposure           0.1.0
      	libmodal-journal            0.2.2
      	libmodal-json               0.4.3
      	libmodal-pipe               2.9.2
      	libvoxl-cci-direct          0.2.1
      	libvoxl-cutils              0.1.1
      	voxl-camera-calibration     0.5.1
      	voxl-camera-server          1.8.7
      	voxl-configurator           0.4.4
      	voxl-cpu-monitor            0.4.7
      	voxl-docker-support         1.3.0
      	voxl-jpeg-turbo             2.1.3-5
      	voxl-lepton-server          1.2.0
      	voxl-logger                 0.3.5
      	voxl-mavcam-manager         0.5.3
      	voxl-mavlink                0.1.1
      	voxl-mavlink-server         1.3.1
      	voxl-modem                  1.0.8
      	voxl-mongoose               7.7.0-1
      	voxl-mpa-to-ros             0.3.7
      	voxl-mpa-tools              1.1.2
      	voxl-opencv                 4.5.5-2
      	voxl-portal                 0.6.2
      	voxl-qvio-server            0.9.4
      	voxl-streamer               0.7.4
      	voxl-suite                  1.1.0
      	voxl-system-image           4.0-r0
      	voxl-tag-detector           0.0.4
      	voxl-tflite-server          0.3.1
      	voxl-utils                  1.3.3
      	voxl-uvc-server             0.1.6
      	voxl-vision-hub             1.7.1
      	voxl-vpn                    0.0.6
      Any further troubleshooting tips will be gladly appreciated, thanks.
      • M
        memeliner787
        Hi, any updates on this? Unfortunately the lack of Docker/ROS functionality blocks the rest of our project unless there's a viable alternative.
        • tomT
          tom admin @memeliner787
          @memeliner787 I was able to get past the issue by modifying /usr/bin/docker-prepare.sh and adding mkdir -p /sys/fs/cgroup/cpuset/system.slice/ before the for loop.
          I also then connected to wifi to get internet access for one boot (unsure if this had an effect or not)
          Next I pushed roskinetic-xenial_v1_0.tgz to target and installed it with docker load -i roskinetic-xenial_v1_0.tgz
          Then I was able to do the following:
          voxl:/$ docker images
          REPOSITORY          TAG                 IMAGE ID            CREATED                  VIRTUAL SIZE
          roskinetic-xenial   v1.0                0e12749bdc00        Less than a second ago   1.633 GB
          hello-image         latest              efc161607398        Less than a second ago   2.088 kB
          voxl:/$ voxl-docker -i roskinetic-xenial:v1.0
          roskinetic:~$ ls
          ros_catkin_ws  yoctohome
          roskinetic:~$
          Unsure exactly what caused this regression but if this fixes your issue then we can mainline the fix
          • M
            memeliner787 @tom
            @tom Thanks - that worked.
            • tomT tom referenced this topic on
