  3. Unable to retrieve full set of parameters Voxl2 -> QgroundControl
3 Posts 2 Posters 899 Views 1 Watching
  • J Offline
    jocacace13
    Hello guys,
    I just reinstalled from scratch the SDK and the operating system of my voxl2 (from flashing the firmware to SDK 1.2). I can access the voxl2 portal, seeing cameras and similar. However, when I try to configure my UAV using QGroundControl, it is very slow to download the parameter list (20% of package loss rate). However, when it finished I had the error: Unable to retrieve the full set of parameters.
    Sadly, in this state, I cannot access the configuration options of Qground (ie. RC configuration, flight mode and similar).
    Where I am wrong? Before reinstalling everything, Qground was working!
    • J jocacace13
      Hello guys,
      @jocacace13 It sounds like you have a weak network connection between voxl2 and your host machine.
      J 1 Reply Last reply
        jocacace13
        @tom Thanks for the reply. I thought the same at the start. I also tried connecting with the ethernet cable, and the results were the same. Do you mind if any other issues can cause the same behaviour?
