  2. VOXL SDK and Software
  3. Flash-system-image waiting for fastboot...
3 Posts 2 Posters 952 Views 1 Watching
  • G Offline
    G Offline
    Gaurav Borade
    I want to flash the system image & I am following the steps from https://docs.modalai.com/flash-system-image/
    I have successfully done uptill the step 2
    But at step 3 I am getting the following error
    It keep waiting for fastboot, I have also checked that the android-tools-adb , android-tools-fastboot are installed
    I tried several times but bot able to resolve it, please help me to resolve it
    • PawelJP Offline
      PawelJP Offline
      PawelJ
      wrote on last edited by PawelJ
      I ran into the same problem recently. Are you sure you're running the install as sudo sudo ./install.sh? Also, make sure your voxl is in station mode, not softap, as it needs access to the internet. You can switch it with adb shell voxl-wifi station <SSID> <PWD>. More details here https://docs.modalai.com/wifi-setup/.
      Cheers
      G 1 Reply Last reply
      • PawelJP PawelJ
        Cheers
        G Offline
        G Offline
        Gaurav Borade
        @PawelJ Thank you for the suggestion.
        Actually, I am facing another issue with my board, i.e. my board is going offline (https://forum.modalai.com/topic/289/adb-device-offline?_=1625029971070) and hence I am not able to communicate with it.
        Once I am able to communicate it I will check this.
