  3. M0113 Camera Connection to VOXL2 Mini
image-sensor
4 Posts 2 Posters 886 Views
  • R Offline
    R Offline
    RykerBarthold
    Hi, I am looking to connect a M0113 Camera to a VOXL2 Mini.
    The solution I was able to come to is that I could use the M0008 cable to the camera and the M0076 interposer to connect between the VOXL2 Mini and the cable. Is that correct?
    And are there any more direct options? Like direct cable or interposer between VOXL2 Mini and camera?
    Thank you,
    Ryker
    ModeratorM 1 Reply Last reply
    • R RykerBarthold
      Thank you,
      Ryker
      M0113 -> M0008-> M0076 is correct at this point
      As your production scales, we can help with a custom FPC to fit your platform
      Please see the supported configurations here: https://docs.modalai.com/voxl2-camera-configs/
      R 1 Reply Last reply
      • ModeratorM Moderator
        R Offline
        R Offline
        RykerBarthold
        @Moderator Understood. I saw in another post they mentioned how there may not be firmware support for the OV9782 sensor on the VOXL2 Mini. Is that correct with the above layout?
        Additionally, the other option I saw is M0014 with the OV7251 sensor which should connect directly to the M0076. Again is this correct and is there firmware support for it?
        Thank you
        • R RykerBarthold
          Thank you
          @RykerBarthold OV9782 is definitely supported on VOXL 2
