  3. "Failed - Network error" when downloading VOXL Emulator 1.7.tgz
10 Posts 4 Posters 1.5k Views 2 Watching
  • svenzymeS Offline
    svenzymeS Offline
    svenzyme
    When we download the emulator from the developer resources, we receive the error in the title after it pulls down the 1.1 GB. The page source indicates that maybe it's Stripe authentication? Happens the same from linux, mac and windows from diverse location. Is there a source besides browser perhaps to acquire the package? Thanks!
    The link we use is https://developer.modalai.com/asset/eula-download/75
      Hi @svenzyme , the Stripe javascript is part of a Sails.js template that's used but sitting idle for now. I also got a failed download, going to dig in and see what's causing it.
      Will give you an update once it's working!
        @svenzyme , I rebooted the container running that web server and then the download worked on my end.
        Can you give another try please?
        I didn't see anything special in the logs but will keep an eye out. Thanks for the info.
        • svenzymeS Offline
          svenzymeS Offline
          svenzyme
          Thanks for the quick response!
          Three more attempts with the same failed completions. Very odd. Is an alternative download possible via slack or ftp? I understand that EULA might prevent that type of file transfer. I really appreciate the eagerness to work on this.
            Very odd! Let me get an email to you.
            Travis
            • Akshay WalvekarA Offline
              Akshay Walvekar
              Any update on this? I also faced the same issue.
                Hi @Akshay-Walvekar ,
                Dang I thought it was working, let me look again, not sure why this is failing…. Will update once I resolve.
                  I'm not positive what is causing this, I'm not seeing it on my end, so it could be timing/bandwidth related. I saw something in the nginx logs that lead to to trying to set proxy_max_temp_file_size to 0 and I just rebuilt that container.
                  @Akshay-Walvekar can you give a shot when you have a chance to download again?
                    Akshay Walvekar
                    Thanks for the support.
                    Today, I was able to download VOXL Emulator 1.7.tgz successfully
                    • H Offline
                      H Offline
                      howard
                      I am also facing same issue, tried multiple times yet unable to download, please help
