  2. FAQs
  3. Errors on build processing for voxl-vision-px4
Scheduled Pinned Locked Moved Unsolved FAQs
10 Posts 2 Posters 2.8k Views 2 Watching
  • S Offline
    S Offline
    shlee853
    I got clone voxl-vision-px4 form git repository and switch to 0.6.8 commit version.
    swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git$ git clone https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-vision-px4.git
    swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git$ cd voxl-vision-px4/
    swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git/voxl-vision-px4$ git submodule update --init --recursive
    swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git/voxl-vision-px4$ git log
    commit eb4f400227a0c1b23e604cf76f4e22714f43f87f (HEAD -> master, origin/master, origin/HEAD)
    Author: Cliff Wong <cliff.wong@modalai.com>
    Date:   Wed May 12 23:53:18 2021 +0000
    Update README.md --ipk command name change
    commit 95234d71677faee8c95242921e285cfe93d9ce7f (tag: v0.8.1)
    Merge: b485c79 216badd
    Author: james <james@modalai.com>
    Date:   Tue Mar 2 13:53:35 2021 -0800
      Merge branch 'dev'
    commit 7b9f76c468045a023b35747deeef52e4f524b7de (tag: v0.6.8)
    Date:   Wed Oct 7 13:00:34 2020 -0700
        detect and warn when PX4 disconnects from uart
    swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git/voxl-vision-px4$ git reset --hard 7b9f76c468045a023b35747deeef52e4f524b7de
    HEAD is now at 7b9f76c detect and warn when PX4 disconnects from uart
    I tried to build source code but, there's some errors without any modification.
    Q1) I gave a command with 'stable' but, installer refered to 'dev'. is this correct?
    Q2) In the process, installation was don even though there're some errors. is it ok?
    swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git/voxl-vision-px4$ voxl-docker -i voxl-emulator
    bash-4.3# ./install_build_deps.sh stable
    using development repository
    Downloading http://voxl-packages.modalai.com/dev/Packages.gz.
    **Updated source 'dev'**.
    No packages removed.
    qemu: Unsupported syscall: 219
    Installing libvoxl_io (0.5.4) on root.
    Downloading http://voxl-packages.modalai.com/dev/libvoxl_io_0.5.4_202105201932.ipk.
    Configuring libvoxl_io.
    Done installing libvoxl_io
    Installing modalai-vl (0.1.4) on root.
    Downloading http://voxl-packages.modalai.com/dev/modalai-vl_0.1.4_8x96.ipk.
    Configuring modalai-vl.
    /usr/lib/rfsa/adsp/port_mapping.xml does not exist, creating symlink
    /usr/lib/rfsa/adsp/eagle.xml does not exist, creating symlink
    /usr/lib/rfsa/adsp/imu_offset.xml does not exist, creating symlink
    /usr/lib/rfsa/adsp/fiducial_markers.xml does not exist, creating symlink
    /bin/chmod: cannot access '/dev/adsprpc-smd': No such file or directory
    Collected errors:
     * pkg_run_script: package "modalai-vl" postinst script returned status 1.
     * opkg_configure: modalai-vl.postinst returned 1.
    Installing imu_app (0.0.6) on root.
    Downloading http://voxl-packages.modalai.com/dev/imu_app_0.0.6.ipk.
    /usr/lib/rfsa/adsp/port_mapping.xml exists but is not a valid symlink, overwriting
    /usr/lib/rfsa/adsp/eagle.xml exists but is not a valid symlink, overwriting
    /usr/lib/rfsa/adsp/imu_offset.xml exists but is not a valid symlink, overwriting
    /usr/lib/rfsa/adsp/fiducial_markers.xml exists and is a valid symlink
    Configuring imu_app.
    Done installing imu_app
    Collected errors:
    the following packages were installed
    libvoxl_io - 0.5.4 - ModalAI library allowing apps processor access to accessory serial ports
    librc_math - 1.1.5 - Math and Linear Algebra Routines for Robotics
    libmodal_pipe - 2.0.6 - Interface for services to communicate over posix named pipes
    modalai-vl - 0.1.4 - ModalAI Vision Library
    imu_app - 0.0.6 - imu server
    Done installing dependencies
    Q3) threre're some errors on build without any modification. Could you please check it?
    bash-4.3# ./build.sh
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/root/build
    [  9%] Built target voxl-px4-shell
    [ 14%] Building C object src/CMakeFiles/voxl-vision-px4.dir/px4_monitor.c.o
    [ 19%] Building C object src/CMakeFiles/voxl-vision-px4.dir/px4_shell.c.o
    [ 23%] Building C object src/CMakeFiles/voxl-vision-px4.dir/fixed_frame_pipe.c.o
    [ 28%] Building C object src/CMakeFiles/voxl-vision-px4.dir/offboard_follow_tag.c.o
    In file included from /home/root/src/fixed_frame_pipe.c:35:0:
    /home/root/src/../include/voxl_vision_px4.h:62:16: error: redefinition of 'struct pose_4dof_t'
     typedef struct pose_4dof_t{
    In file included from /usr/include/modal_pipe_deprecated.h:42:0,
                     from /usr/include/modal_pipe_sink.h:42,
                     from /home/root/src/fixed_frame_pipe.c:34:
    /usr/include/modal_pipe_interfaces.h:523:16: note: originally defined here
    /home/root/src/../include/voxl_vision_px4.h:66:3: error: conflicting types for 'pose_4dof_t'
     } pose_4dof_t;
    /usr/include/modal_pipe_interfaces.h:528:27: note: previous declaration of 'pose_4dof_t' was here
     } __attribute__((packed)) pose_4dof_t;
    In file included from /home/root/src/px4_shell.c:36:0:
                     from /home/root/src/px4_shell.c:35:
     } pose_4dof_t;
    /home/root/src/fixed_frame_pipe.c: In function 'fixed_frame_pipe_init':
    /home/root/src/fixed_frame_pipe.c:63:2: warning: 'pipe_sink_init_channel' is deprecated (declared at /usr/include    /modal_pipe_deprecated.h:735):
    Please use pipe_sink_create() instead [-Wdeprecated-declarations]
      if(pipe_sink_init_channel(FIXED_FRAME_SINK_CH, FIXED_FRAME_PIPE_PATH, 1, READ_BUF_SIZE)){
    /home/root/src/fixed_frame_pipe.c:66:2: warning: implicit declaration of function 'pipe_sink_set_data_cb' [-Wimplicit-function-declaration]
      pipe_sink_set_data_cb(FIXED_FRAME_SINK_CH, data_cb);
    /home/root/src/fixed_frame_pipe.c: In function 'fixed_frame_pipe_stop':
    /home/root/src/fixed_frame_pipe.c:72:2: warning: 'pipe_sink_close_channel' is deprecated (declared at /usr/include    /modal_pipe_deprecated.h:749):
    Please use pipe_sink_close() instead [-Wdeprecated-declarations]
      pipe_sink_close_channel(FIXED_FRAME_SINK_CH);
    src/CMakeFiles/voxl-vision-px4.dir/build.make:182: recipe for target 'src/CMakeFiles/voxl-vision-px4.dir/fixed_frame_pipe.c.o' failed
    make[2]: *** [src/CMakeFiles/voxl-vision-px4.dir/fixed_frame_pipe.c.o] Error 1
    make[2]: *** Waiting for unfinished jobs....
    /home/root/src/px4_shell.c: In function 'px4_shell_init':
    /home/root/src/px4_shell.c:89:2: warning: 'pipe_sink_init_channel' is deprecated (declared at /usr/include    /modal_pipe_deprecated.h:735):
      if(pipe_sink_init_channel(TO_PX4_SHELL_CH, TO_PX4_SHELL_PATH, 1, READ_BUF_SIZE)){
    /home/root/src/px4_shell.c:92:2: warning: implicit declaration of function 'pipe_sink_set_data_cb' [-Wimplicit-function-declaration]
      pipe_sink_set_data_cb(TO_PX4_SHELL_CH, data_cb);
    /home/root/src/px4_shell.c:94:2: warning: 'pipe_sink_init_channel' is deprecated (declared at /usr/include    /modal_pipe_deprecated.h:735):
      if(pipe_sink_init_channel(FROM_PX4_SHELL_CH, FROM_PX4_SHELL_PATH, 0, 0)){
    /home/root/src/px4_shell.c: In function 'px4_shell_stop':
    /home/root/src/px4_shell.c:106:2: warning: 'pipe_sink_close_channel' is deprecated (declared at /usr/include    /modal_pipe_deprecated.h:749):
      pipe_sink_close_channel(TO_PX4_SHELL_CH);
    /home/root/src/px4_shell.c:107:2: warning: 'pipe_sink_close_channel' is deprecated (declared at /usr/include    /modal_pipe_deprecated.h:749):
      pipe_sink_close_channel(FROM_PX4_SHELL_CH);
    src/CMakeFiles/voxl-vision-px4.dir/build.make:326: recipe for target 'src/CMakeFiles/voxl-vision-px4.dir/px4_shell.c.o' failed
    make[2]: *** [src/CMakeFiles/voxl-vision-px4.dir/px4_shell.c.o] Error 1
    CMakeFiles/Makefile2:85: recipe for target 'src/CMakeFiles/voxl-vision-px4.dir/all' failed
    make[1]: *** [src/CMakeFiles/voxl-vision-px4.dir/all] Error 2
    Makefile:127: recipe for target 'all' failed
    make: *** [all] Error 2
      The dependencies will likely need to line up with that version of voxl-vision-px4. voxl-suite contains all of the different packages. So installing a specific version of voxl-suite that matches voxl-vision-px4 should help.
      To switch to stable channel:
      yocto:/# vi /etc/opkg/opkg.conf
      uncomment the stable branch, and comment out the dev branch at the bottom of this file.
      yocto:/# opkg update
      • S Offline
        S Offline
        shlee853
        Hi chad,
        opkg.conf is already uncommented with stable option.
        I think there's no stable option on version 06.8.
        But, I copied latest install_build_deps.sh and excuted with stable option. I compiled all correctly with errors.
        but, there're still errors on build process.
        -- Configuring done
        -- Generating done
        [ 14%] Building C object src/CMakeFiles/voxl-vision-px4.dir/transform_ringbuf.c.o
        [ 19%] Building C object src/CMakeFiles/voxl-vision-px4.dir/adsb_uart.c.o
        [ 23%] Building C object src/CMakeFiles/voxl-vision-px4.dir/main.c.o
        [ 28%] Building C object src/CMakeFiles/voxl-vision-px4.dir/fixed_frame_pipe.c.o
        /home/root/src/main.c:44:24: fatal error: modalai_vl.h: No such file or directory
         #include <modalai_vl.h>
        compilation terminated.
        src/CMakeFiles/voxl-vision-px4.dir/build.make:86: recipe for target 'src/CMakeFiles/voxl-vision-px4.dir/main.c.o' failed
        make[2]: *** [src/CMakeFiles/voxl-vision-px4.dir/main.c.o] Error 1
        bash-4.3#
        There's no file 'modalai_vl.h.' what is this for? I cannot find this file.
          Looks like you are missing this package
          http://voxl-packages.modalai.com/stable/modalai-vl_0.1.3.ipk
          S 1 Reply Last reply
          • Chad SweetC Chad Sweet
            S Offline
            S Offline
            shlee853
            @Chad-Sweet I installed this package manually
            opkg install moal...ipk
            But, still has error on installing
            Can you provide version 0.6.8 that can build completely?
            Or please try to compile and verify it?
              Do you need to build it, or can you just install voxl-suite 0.2.0 to get the features you are looking for?
                This script should show you how to install a specific version of voxl-suite https://gitlab.com/voxl-public/utilities/voxl-suite/-/blob/master/tools/online-install.sh
                  S Offline
                  S Offline
                  shlee853
                  @Chad-Sweet I wanna chage voxl-vision-px4 source code in 0.6.8 and build by myself.
                    The I would install voxl-suite 0.2.0 and then build against that. All of the proper dependencies should be there
                      S Offline
                      S Offline
                      shlee853
                      @Chad-Sweet said in Errors on build processing for voxl-vision-px4:
                      against
                      OK I'll check it
                      Thanks for your fast reply.
