  3. Can't run voxl-qvio-server
7 Posts 2 Posters 1.5k Views 1 Watching
  • A Offline
    afdrus
    I am using stable release on voxl2, but I am not able to run voxl-qvio-server, despite the installation via apt and the binary is present in /usr/bin/ I get the following error:
    voxl-qvio-server: error: No such file or directory
    • A afdrus
      @afdrus Are you able to run voxl-configure-qvio-server?
      Can you post the output of voxl-version
      A 1 Reply Last reply
        afdrus
        @tom Thanks for your reply!
        here's the output of voxl-version:
        system-image: 1.4.1-M0054-14.1a-perf
        kernel:       #1 SMP PREEMPT Thu Oct 13 17:48:16 UTC 2022 4.19.125
        hw version:   M0054
        voxl-suite:   0.9.5
        Packages:
        Repo:  http://voxl-packages.modalai.com/ qrb5165 stable
        Last Updated: 2023-06-19 10:19:04
        List:
        	libmodal-cv              0.2.3
        	libmodal-exposure        0.0.7
        	libmodal-journal         0.2.1
        	libmodal-json            0.4.3
        	libmodal-pipe            2.8.2
        	libqrb5165-io            0.1.0
        	libvoxl-cci-direct       0.1.5
        	libvoxl-cutils           0.1.1
        	qrb5165-dfs-server       0.1.0
        	qrb5165-imu-server       0.5.0
        	qrb5165-system-tweaks    0.1.5
        	qrb5165-tflite           2.8.0-2
        	voxl-bind                0.0.1
        	voxl-camera-calibration  0.2.3
        	voxl-camera-server       1.3.5
        	voxl-ceres-solver        1.14.0-9
        	voxl-cpu-monitor         0.3.0
        	voxl-docker-support      1.2.4
        	voxl-eigen3              3.4.0
        	voxl-gphoto2-server      0.0.10
        	voxl-jpeg-turbo          2.1.3-4
        	voxl-libgphoto2          0.0.4
        	voxl-libuvc              1.0.7
        	voxl-logger              0.3.4
        	voxl-mavlink             0.1.0
        	voxl-mavlink-server      0.3.0
        	voxl-modem               0.16.1
        	voxl-mongoose            7.7.0-1
        	voxl-mpa-to-ros          0.3.6
        	voxl-mpa-tools           0.7.6
        	voxl-opencv              4.5.5-1-202305271610
        	voxl-portal              0.5.0
        	voxl-px4                 1.12.31
        	voxl-px4-imu-server      0.1.2
        	voxl-qvio-server         0.8.2
        	voxl-remote-id           0.0.5
        	voxl-streamer            0.4.1
        	voxl-suite               0.9.5
        	voxl-tag-detector        0.0.4
        	voxl-tflite-server       0.3.1
        	voxl-utils               1.2.2
        	voxl-uvc-server          0.1.3
        	voxl-vision-px4          1.4.0
        	voxl2-system-image       1.4.1-r0
        	voxl2-wlan               1.0-r0
        output of bash: voxl-configure-qvio-server is the following:
        bash: voxl-configure-qvio-server: command not found
        • A afdrus
          hw version:   M0054
          voxl-suite:   0.9.5
          Packages:
          List:
          	libmodal-cv              0.2.3
          	libmodal-json            0.4.3
          	libmodal-pipe            2.8.2
          	libqrb5165-io            0.1.0
          	voxl-bind                0.0.1
          	voxl-eigen3              3.4.0
          	voxl-libuvc              1.0.7
          	voxl-logger              0.3.4
          	voxl-mavlink             0.1.0
          	voxl-modem               0.16.1
          	voxl-portal              0.5.0
          	voxl-px4                 1.12.31
          	voxl-streamer            0.4.1
          	voxl-suite               0.9.5
          	voxl-utils               1.2.2
          	voxl2-wlan               1.0-r0
          afdrus
          @tom
          Also, I just noticed that, for some reasons, the interpreter which is needed to execute the binary file voxl-qvio-server (i.e. ld-linux.so.3) is missing (even though it should be in the /lib/ directory).
          • A afdrus
            @tom
            @afdrus You can try reflashing the 0.9.5 SDK release to get back to a known good state. However, in general, voxl-qvio-server isn't really meant to be run manually through the command line.
            Services on voxl are meant to be setup through configuration scripts, i.e.voxl-configure-mpa.
            Then the status of the service can be checked with systemctl status voxl-qvio-server
              afdrus
              @tom Thank you for the reply. Is there any documentation where I can find how to reflash the 0.9.5 SDK release?
              The output of the status of the service is the same even after re-configuring via voxl-configure-mpa
              voxl2:/$ systemctl status voxl-qvio-server
              ● voxl-qvio-server.service - voxl-qvio-server
                 Loaded: loaded (/usr/bin/voxl-qvio-server; enabled; vendor preset: enabled)
                 Active: failed (Result: exit-code) since Fri 2023-06-23 09:38:50 UTC; 1min 0s ago
                Process: 1496 ExecStart=/usr/bin/voxl-qvio-server (code=exited, status=203/EXEC)
               Main PID: 1496 (code=exited, status=203/EXEC)
              Jun 23 09:38:50 m0054 systemd[1]: Started voxl-qvio-server.
              Jun 23 09:38:50 m0054 systemd[1496]: voxl-qvio-server.service: Failed to execute command: No such file or directory
              Jun 23 09:38:50 m0054 systemd[1496]: voxl-qvio-server.service: Failed at step EXEC spawning /usr/bin/voxl-qvio-server: No such file or directory
              Jun 23 09:38:50 m0054 systemd[1]: voxl-qvio-server.service: Main process exited, code=exited, status=203/EXEC
              Jun 23 09:38:50 m0054 systemd[1]: voxl-qvio-server.service: Failed with result 'exit-code'.
              • A afdrus
                afdrus
                @tom nevermind I found out the documentation here, and by reflashing the platform everything worked again! Thank you for the support!
