  3. Flight Core PWM ESC Calibration
5 Posts 3 Posters 1.1k Views 2 Watching
  • K Offline
    K Offline
    kiprock
    wrote on last edited by kiprock
    Trying to follow the recommended documentation for ESC calibration
      You should hear a second jingle.
      Wait for the second calibration jingle to complete.
      After the second jingle stops, press [ENTER] to proceed
    There is never a second jingle.. I am not sure the calibration completed. The drone is shaking violently with the voxl flight core, but flies stable with a PX4. I switched back and forth to be sure that the extra weight is not an issue.
      Hi @kiprock,
      I've not had oscillations myself from ESC cal issue, more generally from PID tunings (I experienced the same when I tested on a tiny frame and had the m500 PID settings still on board). I really lower all PID settings (roll,pitch,yaw) and then slowly bring everything up.
      Other's might chime in that are much better at tuning than myself, but here's an example of a smaller frame's settings (https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/platforms/v1.10/useeker_v1_config.params#L88)
      Are you using the FlightCore FW that shipped with the unit or did you update it? We noticed that with v1.11 there was a change and there's this script that seems to work better.
      One way around the ESC calibration is if the ESCs support DShot to use that as it's a 'digital' interface.
      John MccartyJ 1 Reply Last reply
      • John MccartyJ Offline
        John Mccarty
        • modaltbM modaltb
          Hi @kiprock,
          John Mccarty
          hello I have the same issue on (hexacopterx) there is no second jingle I waited around 10 minnutes but it still doesnt second jingle.After this calibration just 2 motors are working.What can I do do you have any experience about esc calibration of hexacopterx on voxl?I am using tmotor esc.
            Hi @John-Mccarty , checking in to see if you've progressed at all through this? The process is a little picky and sometimes requires a few tried.
