  3. How can I upload a python code to my m500 with voxl mavsdk
10 Posts 2 Posters 912 Views 2 Watching
  • José QuintanillaJ Offline
    José Quintanilla
    So I recently was able to use the sdk function on my m500 drone, and I want to modify one of the codes in my computer and then try it on my drone, but I don't really know how to upload the new code to the docker image, Does anyone know how to do it?
    • tomT Offline
      @José-Quintanilla You'll want to mount whatever directory or files you want inside the container using something like: docker run -v /host/directory:/container/directory
      José QuintanillaJ 1 Reply Last reply
      • tomT Offline
        @José-Quintanilla https://docs.docker.com/storage/bind-mounts/
          José Quintanilla
          @tom and I can do that from my computer using the adb shell? Im kinda new at this
          • tomT Offline
            @José-Quintanilla You'd just modify this command that you're using: docker run -it --rm --privileged --net=host gcr.io/modalai-public/voxl-mavsdk-python:v1.1 /bin/bash
            You can push your script to the VOXL with adb push FILE_NAME PATH_ON_VOXL and then add the -v option to the docker command to point to where the script lives on VOXL and where you'd like it to live inside the docker container
              José Quintanilla
              I still don't get it
                José Quintanilla
                so instead of docker run -it --rm --privileged --net=host gcr.io/modalai-public/voxl-mavsdk-python:v1.1 /bin/bash it woul be: docker run -v --rm --privileged --net=host gcr.io/modalai-public/voxl-mavsdk-python:v1.1 /bin/bash?
                • tomT Offline
                  @José-Quintanilla No, look at the doc page I sent, you have to specify the location of the file on VOXL and well as where you'd like it to mount inside the container. This is a very common docker use-case and there is plenty of documentation out there to show you how to do it.
                    José Quintanilla
                    wrote on last edited by José Quintanilla
                    #9
                    Hi tom, do you have another source I can look up? I still can't seem to understand how to do it
                    • tomT Offline
                      @José-Quintanilla https://www.baeldung.com/ops/docker-mount-single-file-in-volume
