  3. voxl-cam camera-server crash
voxl-cam
4 Posts 2 Posters 1.2k Views 1 Watching
  • patrickpoirierP Offline
    patrickpoirier
    I just received the unit and after powering it I could connect to the GUI and see different cameras and point cloud.
    After reboot it appears the camera server do not restart
    voxl-camera-server | Enabled | Not Running |
    When I launch manually , I get
    voxl-camera-server
    WARNING Failed to set priority, errno = 1
    This may be because the FIFO scheduler is not available when running in a console.
    It should work properly when run as a systemd background process on boot.
    WARNING: failed to set scheduler
    ERROR: Recieved Fatal error from camera: stereo_child
    ERROR: Sending request 3, ErrorCode: -ENODEV
    WARNING: Thread: stereo_child request thread recieved ESTOP
    WARNING: Thread: tracking result thread recieved ESTOP
    WARNING: Thread: stereo_child result thread recieved ESTOP
    WARNING: Thread: tof result thread recieved ESTOP
    WARNING: Thread: stereo result thread recieved ESTOP
    WARNING: Thread: stereo request thread recieved ESTOP
    WARNING: Thread: tof request thread recieved ESTOP
    WARNING: Thread: tracking request thread recieved ESTOP
    ------ voxl-camera-server INFO: Camera server is now stopping
    WARNING: Deleting buffers: 3 of 16 still in use
    WARNING: Deleting buffers: 5 of 16 still in use
    WARNING: Deleting buffers: 1179655 of 1179668 still in use
    Segmentation fault:
    Fault thread: voxl-camera-ser(tid: 3439)
    Fault address: 0xa
    Address not mapped.
    Segmentation fault
    Any suggestion ?
      patrickpoirier
      Update
      After a few hours sitting on bench it could make it restart
      After 20 minutes I launched a reboot and it could not restart camera server
      87420496-3c09-47c8-8150-b5b76af24ad7-image.png file:///home/msi/Pictures/Screenshot%20from%202023-02-20%2008-04-14.png
      The camera is cooled by a fan and temperature is about 35degs c
        Hi @patrickpoirier ,
        To make sure we're understanding, the hardware on a bench will work at first, but over time (20+ minutes) you are consistently having a failure, but leaving the unit off after it fails for some time, the issue then goes away?
        (edit: saw this is a VOXL-CAM, disregard earlier query about HW).
          patrickpoirier
          @modaltb
          I sent it for repair
          You fond an issue with bad connexion on camera
          I received it back
          It is working OK
          BUT
          I have an other issue regarding connecting to ArduPilot
          It seems it is having issue with MavLink Message :
          voxl-mavlink-server[3036]: ERROR message magic number wrong #284
          And it seems to reconnect under a different ID
          Do you have a clue?
          Do you want me to open a new issue so we can follow more efficiently ?
          Regards
