  3. Tflight server multiple model
3 Posts 2 Posters 789 Views
  • Tamas Pal 0T Offline
    Tamas Pal 0
    Please share the configuration file (voxl-tflite-server.conf) to run multiple models together
      Hey @Tamas-Pal-0,
      Have you read through the docs here: https://docs.modalai.com/voxl-tflite-server/#running-multiple-models?
      Basically, you start an instance of the tflite-server, then re-edit the config file and start the next instance...and so on.
      Here is an example of what the first instance's config file could be:
              "skip_n_frames":        0,
              "model":        "/usr/bin/dnn/yolov5_float16_quant.tflite",
              "input_pipe":   "/run/mpa/stereo/",
              "delegate":     "gpu",
              "allow_multiple":       true,
              "output_pipe_prefix":   "yolo"
      After the first model is running, I edited the config to this for second instance:
              "skip_n_frames":        0,
              "model":        "/usr/bin/dnn/fastdepth_float16_quant.tflite",
              "delegate":     "gpu",
              "output_pipe_prefix":   "fastdepth"
      The, I started up another tflite-server via the cmd line.
      Output of both running:
      • ? A Former User
        Hey @Tamas-Pal-0,
                "skip_n_frames":        0,
                "delegate":     "gpu",
                "skip_n_frames":        0,
                "delegate":     "gpu",
        Tamas Pal 0
        @Matt-Turi Thanks !!
