  3. Cannot connect QGroundControl to internal PX4 (VOXL2)
3 Posts 2 Posters 745 Views 2 Watching
  • M Offline
    M Offline
    mlarsen
    Hi All,
    I can't get QGroundControl to connect to the internal PX4. I ran voxl-vision-px4 to setup the mavlink connection. voxl inspect shows the following.
    Service Name | Enabled | Running | CPU Usage
    docker-autorun | Disabled | Not Running |
    docker-daemon | Disabled | Not Running |
    modallink-relink | Disabled | Not Running |
    voxl-camera-server | Enabled | Not Running |
    voxl-cpu-monitor | Disabled | Not Running |
    voxl-dfs-server | Disabled | Not Running |
    voxl-imu-server | Enabled | Running | 0.0
    voxl-mavlink-server | Enabled | Running | 0.0
    voxl-modem | Disabled | Not Running |
    voxl-portal | Disabled | Not Running |
    voxl-px4-imu-server | Disabled | Not Running |
    voxl-px4 | Enabled | Running | 0.0
    voxl-qvio-server | Disabled | Not Running |
    voxl-remote-id | Disabled | Not Running |
    voxl-softap | Disabled | Not Running |
    voxl-static-ip | Disabled | Not Running |
    voxl-streamer | Disabled | Not Running |
    voxl-tag-detector | Disabled | Not Running |
    voxl-tflite-server | Disabled | Not Running |
    voxl-time-sync | Disabled | Not Running |
    voxl-vision-px4 | Enabled | Not Running |
    voxl-wait-for-fs | Enabled | Completed |
    The voxl-vision-px4.conf shows:
    "config_file_version": 1,
    "qgc_ip": "10.4.107.57",
    "en_secondary_qgc": false,
    "secondary_qgc_ip": "192.168.1.214",
    "qgc_udp_port_number": 14550,
    "udp_mtu": 512,
    "en_localhost_mavlink_udp": true,
    "localhost_udp_port_number": 14551,
    "vio_pipe": "qvio",
    "en_vio": true,
    "en_send_vio_to_qgc": false,
    "vio_warmup_s": 3,
    "send_odom_while_failed": false,
    "horizon_cal_tolerance": 0.5,
    "offboard_mode": "off",
    "follow_tag_id": 0,
    "figure_eight_move_home": true,
    "collision_sampling_dt": 0.1,
    "max_lookahead_distance": 1,
    "en_tag_fixed_frame": false,
    "fixed_frame_filter_len": 5,
    "en_transform_mavlink_pos_setpoints_from_fixed_frame": false,
    "en_voa": true,
    "en_send_voa_to_qgc": false,
    "voa_upper_bound_m": -0.15000000596046448,
    "voa_lower_bound_m": 0.15000000596046448,
    "voa_memory_s": 1,
    "voa_inputs": [{
    "enabled": true,
    "type": "point_cloud",
    "input_pipe": "dfs_point_cloud",
    "frame": "stereo_l"
    "enabled": true,
    "input_pipe": "stereo_front_pc",
    "frame": "stereo_front_l"
    "enabled": true,
    "input_pipe": "stereo_rear_pc",
    "frame": "stereo_rear_l"
    "enabled": true,
    "type": "tof",
    "input_pipe": "tof",
    "frame": "tof"
    "enabled": true,
    "type": "rangefinder",
    "input_pipe": "rangefinders",
    "frame": "body"
    and the IP is correct. Nothing shows up at the QGroundControl client side.
      Can you ping 192.168.1.214 from the computer that you are running QGC to make sure there is proper network connectivity between the two?
      M 1 Reply Last reply
      • Chad SweetC Chad Sweet
        M Offline
        M Offline
        mlarsen
        @Chad-Sweet I haven't tried. However, I manage to get it working by doing a factory reset configuration of the VOXL2. Don't know why it made a difference though.
