  3. ESC feedback
ESC feedback
Scheduled Pinned Locked Moved ESCs, Sensors and Accessories
esc
6 Posts 3 Posters 2.2k Views 1 Watching
  • ModeratorM Offline
    Question from customer - the modalai esc is working fine when commanded, but the RPM and voltage feedback is not available. I have attached a screenshot of the modalai_esc status which shows the feedback isn't coming in. I checked the connections, they seem fine.
      Hello, thanks for reporting. Good news is we already have a fix in for via this commit:
      https://github.com/modalai/px4-firmware/commit/577fec3b9a843b709086fc07b913b2c194367e10
      It's slated to release in our next platform release (platform release 0.9), I can't mention the release date, as the release gods will then delay it... but we are getting close!!!!!
      There are pre-release channels available for developers, captured here: https://docs.modalai.com/configure-pkg-manager/#dev
      • vivek rkV Offline
        vivek rkV Offline
        vivek rk
        Hey, thanks for that. I was able to pull the voxl-dev branch and got it working on the VOXL2, I can see the feedback of the RPM on the mavlink topic SERVO_OUTPUT_RAW. But the frequency is at 10Hz.
        When I try to use the following command
        mavlink stream -u "port_number" -s SERVO_OUTPUT_RAW -r 100
        I get an error stream SERVO_OUTPUT_RAW not found
        From the uart_esc code in px4-firmware I see that the uorb topic thats being used for RPM information is ESC_STATUS. And doing the following commands yields no result. The frequency is still 10Hz
        mavlink stream -u "port_number" -s ESC_STATUS -r 100
        mavlink stream -u "port_number" -s ESC_INFO -r 100
        Is there anything I can do to increase the frequency of the message ?
          Sorry for the lag, what if you use px4-listener esc_status ?
          If it's showing up there, likely we need to modify something to get this offboard....
          • vivek rkV Offline
            vivek rkV Offline
            vivek rk
            So when i try px4-listener it says command not found.
            The command that works is
            listener esc_status
            This produces the following resutls
            never published
            But after some investigation, the uorb topic with the rpm information is
            actuator_outputs
            I can read the output
            This topic is being published at 500Hz
            I tried to increase the rate of the following mavlink topics
            mavlink stream -u 15446 -s actuator_output -r 100
            mavlink stream -u 15446 -s ACTUATOR_OUTPUT -r 100
            mavlink stream -u 15446 -s actuator_outputs -r 100
            mavlink stream -u 15446 -s ACTUATOR_OUTPUTS -r 100
            Which results in the following error message
            ERROR [mavlink] stream ACTUATOR_OUTPUTS not found (same for all other)
            • vivek rkV Offline
              vivek rkV Offline
              vivek rk
              Fixed the problem, the mavlink stream name is SERVO_OUTPUT_RAW_0.
              changing that to 200Hz gives us the RPM feedback at 200Hz on mavros
