  2. VOXL Dev Kits
  3. VOXL-CAM
  4. Tilting the VOXL CAM forward
Scheduled Pinned Locked Moved VOXL-CAM
3 Posts 2 Posters 994 Views
  • Sem AndewegS Offline
    Sem Andeweg
    The full VOXL CAM will be angled 15 degrees forward, so this means the VOXL as well as the global shutter camera will be tilted forward. The flight core is already fixed. But we now need to change extrinsics file. /etc/modalai/extrinsics.conf
    I have read the whole https://docs.modalai.com/configure-extrinsics/ and seen the video. But cannot really confirm if I'm doing a good job. Could someone please help me with this? I dont know what ''RPY_parent_to_child" I need to change. And if you know to what XYZ value, please do .
    • Steve TurnerS Offline
      Steve Turner
      @Sem-Andeweg
      I don't work for ModalAI but can try to help.
      You need to adjust the IMU0, and IMU1 to body RPY at minimum, which stands for Roll, Pitch, Yaw.
      If you look at the Seeker example at https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-tools/-/blob/master/misc_files/usr/share/modalai/extrinsic_configs/seeker_v1_voxlcam.conf#L64
      you'll see the VOXL is rotated 90 degrees "up" and yawed 90 degrees right. From there the tracking camera is then rotated "down" 45 degrees to account for the VOXL CAM being mounted on the front of the Seeker and its orientation relative to the VOXL inside the camera housing.
      Hope this helps a bit, definitely watch the video at https://docs.modalai.com/configure-extrinsics/
        Sem Andeweg
        Hey @Steve-Turner, thanks for your answer, I will take a look into it!
