  3. uvc-camera rtsp
uvc-camera rtsp
voxl
9 Posts 2 Posters 1.2k Views 1 Watching
  • 張為超張 Offline
    張為超張 Offline
    張為超
    Hello 😊 ,
    I'm trying to use rtsp to stream a uvc camera. After I finish the connection(using fast boot module) and setting(using voxl-uvc-server and streamer), i get a stream from my computer like following:
    Screenshot 2022-08-25 18:07:55.png
    Here's my voxl-streamer.conf about uvc:
    "uvc-generic": {
            "input": {
                "interface": "mpa",
                "mpa-camera": "uvc" },
            "output": {
                "stream": {
                    "rotation": 0,
                    "width": 640,
                    "height": 480,
                    "decimator": 2,
                    "bitrate": 1000000 } }
    My camera is logitech C930c and Luminous C30 and both have similar image.
    Any suggestion is welcome, big thanks : )
    • 張為超張 張為超
      Hello 😊 ,
      "uvc-generic": {
              "input": {
                  "interface": "mpa",
              "output": {
                  "stream": {
                      "rotation": 0,
                      "width": 640,
                      "height": 480,
                      "decimator": 2,
      @張為超 This looks like a mismatch in video format. There are some helpful debugging tips here: https://docs.modalai.com/voxl-uvc-server/#helpful-tips. Can you show the output when you run voxl-uvc-server -s and also voxl-uvc-server -d -v?
      • 張為超張 Offline
        張為超張 Offline
        張為超
        wrote on last edited by 張為超
        Thanks for answering me.😊
        here's output for voxl-uvc-server -s :
        voxl:~$ voxl-uvc-server -s
        *** START DEVICE LIST ***
        Found device 1
        Got device descriptor for 046d:0891 E1127E0E
        Found device 046d:0891
        DEVICE CONFIGURATION (046d:0891/E1127E0E) ---
        Status: idle
        VideoControl:
        	bcdUVC: 0x0100
        VideoStreaming(1):
        	bEndpointAddress: 129
        	Formats:
        	UncompressedFormat(1)
        		  bits per pixel: 16
        		  GUID: 5955593200001000800000aa00389b71 (YUY2)
        		  default frame: 1
        		  aspect ratio: 0x0
        		  interlace flags: 00
        		  copy protect: 00
        			FrameDescriptor(1)
        			  capabilities: 00
        			  bit rate: 24576000-147456000
        			  max frame size: 614400
        			  default interval: 1/30
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(2)
        			  capabilities: 00
        			  bit rate: 1536000-9216000
        			  max frame size: 38400
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(3)
        			  capabilities: 00
        			  bit rate: 2027520-12165120
        			  max frame size: 50688
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(4)
        			  capabilities: 00
        			  bit rate: 4608000-27648000
        			  max frame size: 115200
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(5)
        			  capabilities: 00
        			  bit rate: 6144000-36864000
        			  max frame size: 153600
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(6)
        			  capabilities: 00
        			  bit rate: 8110080-48660480
        			  max frame size: 202752
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(7)
        			  capabilities: 00
        			  bit rate: 8140800-48844800
        			  max frame size: 203520
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(8)
        			  capabilities: 00
        			  bit rate: 10368000-62208000
        			  max frame size: 259200
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(9)
        			  capabilities: 00
        			  bit rate: 18432000-110592000
        			  max frame size: 460800
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(10)
        			  capabilities: 00
        			  bit rate: 28672000-172032000
        			  max frame size: 716800
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(11)
        			  capabilities: 00
        			  bit rate: 38400000-184320000
        			  max frame size: 960000
        			  default interval: 1/24
        			  interval[0]: 1/24
        			  interval[1]: 1/20
        			  interval[2]: 1/15
        			  interval[3]: 1/10
        			  interval[4]: 1/7
        			  interval[5]: 1/5
        			FrameDescriptor(12)
        			  capabilities: 00
        			  bit rate: 32563200-195379200
        			  max frame size: 814080
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(13)
        			  capabilities: 00
        			  bit rate: 41472000-124416000
        			  max frame size: 1036800
        			  default interval: 1/15
        			  interval[0]: 1/15
        			  interval[1]: 1/10
        			  interval[2]: 1/7
        			  interval[3]: 1/5
        			FrameDescriptor(14)
        			  capabilities: 00
        			  bit rate: 47185920-141557760
        			  max frame size: 1179648
        			  interval[0]: 1/15
        			  interval[1]: 1/10
        			  interval[2]: 1/7
        			  interval[3]: 1/5
        			FrameDescriptor(15)
        			  capabilities: 00
        			  bit rate: 73728000-147456000
        			  max frame size: 1843200
        			  default interval: 1/10
        			  interval[0]: 1/10
        			  interval[1]: 1/7
        			  interval[2]: 1/5
        			FrameDescriptor(16)
        			  capabilities: 00
        			  bit rate: 114688000-172032000
        			  max frame size: 2867200
        			  default interval: 1/7
        			  interval[0]: 1/7
        			  interval[1]: 1/5
        			FrameDescriptor(17)
        			  capabilities: 00
        			  bit rate: 165888000-165888000
        			  max frame size: 4147200
        			  default interval: 1/5
        			  interval[0]: 1/5
        			FrameDescriptor(18)
        			  capabilities: 00
        			  bit rate: 238878720-238878720
        			  max frame size: 5971968
        			  interval[0]: 1/2
        			FrameDescriptor(19)
        			  capabilities: 00
        			  bit rate: 283115520-283115520
        			  max frame size: 7077888
        			  interval[0]: 1/2
        	MJPEGFormat(2)
        		  bits per pixel: 0
        		  GUID: 4d4a5047000000000000000000000000 (MJPG)
        		  default frame: 1
        		  aspect ratio: 0x0
        		  interlace flags: 00
        		  copy protect: 00
        			FrameDescriptor(1)
        			  capabilities: 00
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(2)
        			  capabilities: 00
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(3)
        			  capabilities: 00
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(4)
        			  capabilities: 00
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(5)
        			  capabilities: 00
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(6)
        			  capabilities: 00
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(7)
        			  capabilities: 00
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(8)
        			  capabilities: 00
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(9)
        			  capabilities: 00
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(10)
        			  capabilities: 00
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(11)
        			  capabilities: 00
        			  bit rate: 38400000-230400000
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(12)
        			  capabilities: 00
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(13)
        			  capabilities: 00
        			  bit rate: 41472000-248832000
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(14)
        			  capabilities: 00
        			  bit rate: 47185920-283115520
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(15)
        			  capabilities: 00
        			  bit rate: 73728000-442368000
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(16)
        			  capabilities: 00
        			  bit rate: 114688000-688128000
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        			FrameDescriptor(17)
        			  capabilities: 00
        			  bit rate: 165888000-995328000
        			  interval[0]: 1/30
        			  interval[1]: 1/24
        			  interval[2]: 1/20
        			  interval[3]: 1/15
        			  interval[4]: 1/10
        			  interval[5]: 1/7
        			  interval[6]: 1/5
        END DEVICE CONFIGURATION
        *** END DEVICE LIST ***
        voxl-uvc-server -d -v :
        voxl:~$ voxl-uvc-server -d -v 046d
        Enabling debug messages
        voxl-uvc-server starting
        Vendor ID 0x046d chosen
        Image resolution 640x480, 30 fps chosen
        UVC initialized
        Device 046d:0000 found
        Device opened
        uvc_get_stream_ctrl_format_size succeeded for format 0
        Streaming starting
        Got frame callback! frame_format = 3, width = 640, height = 480, length = 614400, ptr = (nil)
         * got image 30
         * got image 60
         * got image 90
         * got image 120
        I use gstream to watch rtsp from laptop by using:
        gst-launch-1.0 -v playbin uri=rtsp://192.168.8.1:8900/live uridecodebin0::source::latency=0
        Maybe here's the problem? But I also check VLC media player and got pretty much same image.
        • 張為超張 張為超
          Found device 1
          Status: idle
          VideoControl:
          	bcdUVC: 0x0100
          VideoStreaming(1):
          	Formats:
          		  bits per pixel: 16
          		  default frame: 1
          		  aspect ratio: 0x0
          		  interlace flags: 00
          		  copy protect: 00
          			FrameDescriptor(1)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(2)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(3)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(4)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(5)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(6)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(7)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(8)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(9)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(10)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(11)
          			  capabilities: 00
          			  interval[0]: 1/24
          			  interval[1]: 1/20
          			  interval[2]: 1/15
          			  interval[3]: 1/10
          			  interval[4]: 1/7
          			  interval[5]: 1/5
          			FrameDescriptor(12)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(13)
          			  capabilities: 00
          			  interval[0]: 1/15
          			  interval[1]: 1/10
          			  interval[2]: 1/7
          			  interval[3]: 1/5
          			FrameDescriptor(14)
          			  capabilities: 00
          			  interval[0]: 1/15
          			  interval[1]: 1/10
          			  interval[2]: 1/7
          			  interval[3]: 1/5
          			FrameDescriptor(15)
          			  capabilities: 00
          			  interval[0]: 1/10
          			  interval[1]: 1/7
          			  interval[2]: 1/5
          			FrameDescriptor(16)
          			  capabilities: 00
          			  interval[0]: 1/7
          			  interval[1]: 1/5
          			FrameDescriptor(17)
          			  capabilities: 00
          			  interval[0]: 1/5
          			FrameDescriptor(18)
          			  capabilities: 00
          			  interval[0]: 1/2
          			FrameDescriptor(19)
          			  capabilities: 00
          			  interval[0]: 1/2
          	MJPEGFormat(2)
          		  bits per pixel: 0
          		  default frame: 1
          		  aspect ratio: 0x0
          		  interlace flags: 00
          		  copy protect: 00
          			FrameDescriptor(1)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(2)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(3)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(4)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(5)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(6)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(7)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(8)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(9)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(10)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(11)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(12)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(13)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(14)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(15)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(16)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          			FrameDescriptor(17)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  interval[1]: 1/24
          			  interval[2]: 1/20
          			  interval[3]: 1/15
          			  interval[4]: 1/10
          			  interval[5]: 1/7
          			  interval[6]: 1/5
          UVC initialized
          Device opened
          Streaming starting
           * got image 30
           * got image 60
           * got image 90
           * got image 120
          @張為超 I don't see anything incorrect. Can you also show output when manually launching voxl-streamer with the -d option?
          張為超張 1 Reply Last reply
            張為超張 Offline
            張為超張 Offline
            張為超
            @Eric-Katzfey hello,sorry for responding late.
            here's output for voxl-streamer -d :
            voxl:~$ voxl-streamer -d
            Using configuration file /etc/modalai/voxl-streamer.conf
            MPA interface chosen
            Input pipe name /run/mpa/uvc/
            Output stream width 640
            Output stream height 480
            Output stream bitrate 1000000
            Output stream rotation 0
            Output frame decimator 2
            No image overlay specified
            Camera server Connected
            Meta data from incoming frame:
            	magic_number 0x564F584C
            	timestamp_ns: 67575140926
            	frame_id: 720
            	width: 640
            	height: 480
            	size_bytes: 614400
            	stride: 1280
            	exposure_ns: 100
            	gain: 100
            	format: 8
            Input parameters initialized
            Made rtsp_server
            Created RTSP server main loop context
            Created RTSP server main loop source for callback
            Got 2 from gst_rtsp_server_attach
            Stream available at rtsp://127.0.0.1:8900/live
            A new client has connected to the RTSP server
            Creating media pipeline for RTSP client
            Made empty pipeline
            Made app_source
            Made parser_queue
            Made raw_video_parser
            Made scaler_queue
            Made scaler
            Made converter_queue
            Made video_converter
            Made rotator_queue
            Made video_rotate
            Made video_rotate_filter
            Made encoder_queue
            Made omx_encoder
            Made rtp_filter
            Made rtp_queue
            Made rtp_payload
            Made video_info
            Made video_caps
            • 張為超張 張為超
              	frame_id: 720
              	width: 640
              	height: 480
              	size_bytes: 614400
              	stride: 1280
              	exposure_ns: 100
              	gain: 100
              	format: 8
              Made rtsp_server
              Made empty pipeline
              Made app_source
              Made parser_queue
              Made scaler_queue
              Made scaler
              Made rotator_queue
              Made video_rotate
              Made encoder_queue
              Made omx_encoder
              Made rtp_filter
              Made rtp_queue
              Made rtp_payload
              Made video_info
              Made video_caps
              @張為超 Everything still looks normal. We will order a couple of Logitech C930e and see if we can recreate your issue.
              張為超張 2 Replies Last reply
                張為超張 Offline
                張為超張 Offline
                張為超
                  張為超張 Offline
                  張為超張 Offline
                  張為超
                  @Eric-Katzfey Hey, I just update my voxl-platform from 3.6.0 to 3.8.0 and reinstall some package include uvc-server.
                  And I find out that the image become nice and clear. So I guess the problem is solved for me. Hope you guys still have time to refund C930e. Really big thanks for helping me to resolve problem. Cheers 😃
                  • 張為超張 張為超
                    @張為超 Great, glad to hear it is working for you now!
