    Voxl2 + flight core in custom frame
    • Tamas Pal 0T
      Tamas Pal 0
      I am using voxl2 with flight core in a custom frame with a TOF sensor. I understand that I have to change the coordinates in extrinsics.conf file. Please give me a detailed answer what all changes I have to make in extrinsics.conf file for imu positions (which imu is for qvio and flight-core etc.). Is there anything else that I have to change other than extrinsics and mavlink configuration file for this set up?
      • Steve TurnerS
        Steve Turner
        Extrinsics and QVIO server configuration will determine camera orientation and which IMU to use respectively.
        https://docs.modalai.com/configure-extrinsics/
        https://gitlab.com/voxl-public/voxl-sdk/services/voxl-qvio-server/-/blob/master/server/config_file.h#L51
        You will need to measure from the IMU (Parent) to child (camera) for translation in meters and also the roll, pitch, and yaw in degrees. I recommend watching the video on the configure extrinsics page.
        Tamas Pal 0T 1 Reply Last reply Reply Quote 1
        • Tamas Pal 0T
          Tamas Pal 0 @Steve Turner
          @Steve-Turner Which imu should be used for imu_px4 in extrinsics file ? Will it be the same as voxl2's imu_px4 or it will be flight-core's imu?
          • Steve TurnerS
            Steve Turner
            Will be the VOXL2 IMU's.
            https://docs.modalai.com/configure-extrinsics/#voxl2 recommends using imu_apps for configuration.
            Tamas Pal 0T 1 Reply Last reply Reply Quote 0
            • Tamas Pal 0T
              @Steve-Turner Thanks
